Loader pressure vs lifting gains - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 09-18-2019, 02:39 PM Thread Starter
I've been searching for a while with no luck...
I remember seeing a basic calculation to determine the lifting capacity of a 40 loader at increased pressures, but can't seem to find it again.
Any help would be appreciated.
Thanks.
--Alex
alexo35 is offline
post #2 of 8 Old 09-18-2019, 05:33 PM
20,000 Posts & Climbing
Re: Loader pressure vs lifting gains
It takes a specific amount of pressure to raise the empty bucket of a loader. Once that pressure is known, a ball park estimate of addition lifting force applied to the payload by the higher pressure can be calculated by using the leverage ratio based on the location of the 3 pins on the arm, or two pins on the arm and the center of the bucket.
Cylinder lifting force:
- Cylinder bore area X Pressure X The Sine of the angle between the cylinder centerline and the line between the cylinder pin on the arm and the post pin on the arm.
Leverage ratio:
- The horizontal distance between the post pin and the cylinder pin on the arm / the horizontal distance between the post pin and the bucket pin, or center of the bucket.
Measure the horizontal distances using a plumb bob dropped from the center of the pins to a length of lumber.
Discount the pressure for lifting the empty bucket from the anticipated pressure available and use the result for the force calculations. Keep in mind that the force calculations are for ONE cylinder. There are two cylinders on a loader. The result after doing the leverage calculations is the estimated payload that can be lifted.
Note that the calculations change as the load is lifted. They're only good for one lift position due to the changing angle between the arm and cylinder, and the changing leverage ratios.
The math is simple. Applying it, not so much.
TUDOR is online now
post #3 of 8 Old 09-19-2019, 03:12 PM Thread Starter
So if I understand you correctly, you're saying I should set it at 1450 and try it?
--Alex
alexo35 is offline
post #4 of 8 Old 09-19-2019, 06:03 PM
Maximum pressure for a K92 auxiliary pump is 1502 psi. Anything below that is acceptable. Most who have added shins have set theirs at 1250-1400 psi.
TUDOR is online now
post #5 of 8 Old 09-20-2019, 07:58 AM Thread Starter
I checked my new to me 445 with the 40 loader and it is relieving at 1300 psi.
I am hitting the hydraulic limit of the loader on a regular basis. Mostly doing brush removal with the ratchet rake, or moving my spoil piles.
So the question was really, is it worth the effort to go from 1300 to 1450 psi. It sounds like the easy solution is just to re-shim the valve and see what she'll do.
To be honest, I'm really just disappointed that I missed out on that "oh wow" moment going from stock pressure to 1300. lol
--Alex
alexo35 is offline
post #6 of 8 Old 09-20-2019, 06:24 PM
--Alex
It might not be as big, but you'll still have an "Oh WOW!"
TUDOR is online now
post #7 of 8 Old 09-28-2019, 01:13 AM
sponfit's Avatar
The 445 has the k91 not the k92. Not sure if the max pressure is any different though.
sponfit is offline
post #8 of 8 Old 10-06-2019, 06:53 PM
Yeah go from 1300 to 1500, you'll get your own "oh wow." My x595 is set a bit higher than that even, and I got an oh wow from the guys whose van I lifted the back end of the other day so they could change a tire.
eKretz is offline
