Auto Connect - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 09-18-2019, 07:18 AM Thread Starter
Ehammond's Avatar
Auto Connect
Recently bought a 2 year old X750 with drive over deck. Looking at adding the auto connect to keep from having to lay down and connect the drive shaft. Anyone else have this feature?? Pros - Cons? Thanks in advance for the information!!!!
John Deere 955 60" Deck
Westendorf FE Loader
John Deere 455 60" Deck
John Deere X750 54" Deck
Front Mounted JD Thatcher
4' Tow Type Plugger Aerator
King Kutter 5' Tiller
King Kutter 5' LS Box
Ferris IS1000 21/48 Zero Turn Mower W/10' fold up mounted sprayer
Allis Chalmers 6060
Howse 10' Rotary Cutter
Ehammond is offline
post #2 of 8 Old 09-18-2019, 09:19 AM
RT3360's Avatar
Re: Auto Connect
I have it on my X738 and my son has it on his X730. Both work as advertised. I’ve only had an issue once when I took the deck off in soft ground. They’re not flawless, but are a lot better than crawling under the tractor, which would tend to make me never want to take the deck off.
By the way, if you use your tractor for snow duty, the auto-connect is stowed up inside the frame on a hanger and needs to be connected BEFORE attaching the deck. Guess how I know.
Craftsman DLT2000, 48”
Ariens ST824 snowblower
RT3360 is offline
post #3 of 8 Old 09-18-2019, 11:48 AM
Carlos's Avatar
Re: Auto Connect
I am still coming to terms with the auto-connect on my X750. Use the differential lock when driving up onto the deck. My deck was not even close to being level. Not sure what the previous owner was thinking. Or if it had even been adjusted. It helps.
I need to double-check the height of the auto-connect as it has not gone smoothly.
Seems I need to monkey with the spring loaded locks. Maybe if I do it enough times and slightly tweak adjustments, that will go better.
Beats grabbing a greasy driveshaft locking ring while trying to get a heavy deck in just the right place. And don't forget to grease that driveshaft. Harder to do under the tractor.
Carlos is offline
post #4 of 8 Old 09-18-2019, 04:22 PM
inspectorudy's Avatar
Re: Auto Connect
Having owned nearly every type of small JD, the new system with the belt drive is a huge improvement over the driveshaft models. Putting on a 60-inch deck on a 4x5 series is about as bad a job as there is. I wonder if the guys at JD ever had to do it? The auto-drive on feature seems like a great idea and I hope it works for you.
inspectorudy is offline
post #5 of 8 Old 09-19-2019, 07:40 PM
drs455aws's Avatar
Re: Auto Connect
Got it on my X739. Highly recommend it. I use three small pieces of rubber drawer liner to keep it from sliding on garage floor when driving onto to deck. When it was new I had to adjust the height stop bolt a little, but after that it worked perfect. Usally once I have the front wheels over deck I will take a quick look underneath and check my side to side alignment before driving foward the rest of way and latching it in. Taking deck on and off goes quick and easy.
drs455aws is offline
post #6 of 8 Old 09-19-2019, 07:55 PM
Re: Auto Connect
Had it on my X738 before we moved down here. It worked well.
DoItMyself is offline
post #7 of 8 Old 09-22-2019, 08:39 AM Thread Starter
Ehammond's Avatar
Re: Auto Connect
We don't do a lot of snow duty here in North Alabama, but I normally take the deck off twice a year doing maintenance on it!!!!
Allis Chalmers 6060
Ehammond is offline
post #8 of 8 Old 09-22-2019, 08:40 AM Thread Starter
Ehammond's Avatar
Re: Auto Connect
Found one on ebay at a very good price!!!
Allis Chalmers 6060
Ehammond is offline
