Ignition switch? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 09-18-2019, 05:43 AM Thread Starter
Ignition switch?
X495 starter engages in the ACC position (first switch click). Engine does start but the starter never kicks off. The only way I've been able to disengage the starter is to physically unplug it. First thought is a bad ignition switch. The yellow light indicating the blades are running while in reverse also remains always on even though its not in reverse nor are the blades running. Before I buy a new ignition switch for $172 +tax, I would like to hear your opinions.
Timmyb74 is offline
post #2 of 6 Old 09-18-2019, 07:52 AM
burned300's Avatar
Re: Ignition switch?
two things to try, unplug dash & see what happens, 2nd make sure the control board from the key switch has a good ground, ( sounds easy ) incase you're wondering, the starter relay is part of the control board, so it's not serviceable unless your really good.
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #3 of 6 Old 09-18-2019, 05:04 PM Thread Starter
I'm not having any luck unplugging the dash. What do the red and green LEDs indicate? Both are ON when the switch is ON. All the dash lights are on when the starter is unplugged and the switch is in the ACC position.
Timmyb74 is offline
post #4 of 6 Old 09-19-2019, 07:54 PM
burned300's Avatar
The dash should unplug pretty easy. The red light on means the pto is ready to use, so if brake pedal or rev pedal are pressed light goes off. the green light on means someone is sitting on the seat.
1970 112
1975 200
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
Brinly cat 0 plow
post #5 of 6 Old 09-20-2019, 05:33 AM Thread Starter
Thanks for the info. I bit the bullet and purchased a new switch/module. It was a pain to install, but everything now works properly. Thanks for your help from Columbus, Ohio. I'm from Darke county. Go Bucks!
Timmyb74 is offline
post #6 of 6 Old 09-20-2019, 04:16 PM
burned300's Avatar
Glad it all worked out! Now we all need to see a pic of your X495
1970 112
1975 200
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
Brinly cat 0 plow
