40 Loader work lights - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 09-17-2019, 10:40 AM Thread Starter
I'd like to add a pair of work lights to my loader. Is there a factory plug in for them, or are people tapping the headlight circuit?
Thanks.
--Alex
alexo35 is offline
post #2 of 9 Old 09-17-2019, 02:42 PM
AKA Moses Lawnagan
KHodges's Avatar
Re: 40 Loader work lights
Thanks.
--Alex
I put work lights on top of the "goal posts" on my 45 loader, and just tapped into the headlight circuit. Where the connector is that you have to disconnect when removing the hood, I spliced a second connector in parallel for the work lights. When I have the loader in place, I disconnect the headlights and plug in the work lights, and they will operate off the headlight switch. having both sets on at the same time overloads the circuit and blows fuses, plus the bucket blanks out the regular headlights, so I disconnect them.
'09 JD 2520, CX200 loader and 62D deck
LP RTR0550 rototiller
?? 60" box blade
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
'08 X748SE, gone but not forgotten
KHodges is online now
post #3 of 9 Old 09-18-2019, 08:26 AM
In the late 1990s I added the factory light kit to my 40 Loader (on a 455) and it tapped into the headlight wiring.
Sent from my Moto Z (2) using MyTractorForum Free App mobile app
Ken
1995 John Deere 455 (Diesel)
54" mower deck
Model 40 Loader
Rear 540 RPM PTO
Ruegg Cat 1 3-point hitch
54" front blade
47" snowblower
51" broom
647 Tiller
3 cubic foot Tractor Trunk
Click-N-Go brackets
itsagaas is offline
post #4 of 9 Old 09-18-2019, 08:49 AM
RT3360's Avatar
Use LED work lights to reduce current and change existing headlights to LED makes it so you can tap pigtail w/connector into headlight circuit, won’t blow fuses, eliminates the need to unplug existing light circuit connector. Most connectors are usually only rated for about 500 insertions. Depending on how often you take your loader ON/OFF will determine how long it will last.
Found these lights recently that might work for you.
https://www.amazon.com/dp/B07DHNFXKL...v_ov_lig_dp_it
I did similar to this on my X738 for my cab for snow removal duty, but the lights I used were much lower output.
Craftsman DLT2000, 48”
Ariens ST824 snowblower
RT3360 is offline
post #5 of 9 Old 09-19-2019, 10:59 AM
Save yourself later regrets, DO NOT go cheap on the wiring or connectors. Buy marine grade wiring, connectors and switches. Use plenty of tie downs too.
This is from me, writing this from the wiring "heartbreak hotel" .
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Alien5044 is offline
post #6 of 9 Old 09-24-2019, 12:21 PM Thread Starter
So I'm ordering parts for this while I'm on the road away from the machine.
It looks like the headlight harness is yellow and black 18ga. Does that sound right?
Thanks.
--Alex
alexo35 is offline
post #7 of 9 Old 09-24-2019, 11:06 PM
RT3360's Avatar
Thanks.
--Alex
Sounds about right. My X738 I think has a 10A fuse for the lighting circuit.
RT3360 is offline
post #8 of 9 Old 09-26-2019, 08:24 PM
TJR345's Avatar
I add LED lights to my 45 loader and used the accessory switch on the tractor.I only use the lights in the winter. The lights are magnet mount. I use 2 wire with weather covers on the connectors.
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow bagger
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
Frontier SS1036B Spreader
TJR345 is offline
post #9 of 9 Old 10-02-2019, 08:02 AM Thread Starter
I finally have all the materials to get the lights mounted and wired.
I'd like to have a single plug-in for the lights near the hydraulic connections so that all loader connections are in the same location. This means I would need to cross the top of the loader to get to the right light.
I'm thinking of routing the wiring through the horizontal brace between the goal posts. Other than removing that brace in the future to blast and paint it, in which case I'll rewire it, does anyone see an issue with going through it?
--Alex
alexo35 is offline
