Towable Boom Lift - X500 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 09-17-2019, 10:17 AM Thread Starter
Question Towable Boom Lift - X500
I plan on renting a 35ft JBL Towable Boom lift to complete a prefab chimney sticking 12 feet out of my 12/12 pitch roof. I have to get up about 26ft vertical, and about 5ft horizontal.
I plan to use my X500 to pull it into position as the spot I have to operate from is pretty flat, but a bit narrow for backing the truck in. A couple of questions for the team:
1. At about 250 lbs tongue weight, and me at about 190, if I'm careful, is it reasonable that the X500 would be able to muscle this into position? All I really need is to move it, and direct it into it's spot.
2. Has anyone used this man lift, and if so, what is your opinion.
Thanks for any comments.
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Last edited by Alien5044; 09-17-2019 at 10:19 AM. Reason: That is JLG not JBL. A boom lift, not speakers...ugh..
Alien5044 is offline
post #2 of 18 Old 09-17-2019, 10:20 AM Thread Starter
Re: Towable Boom Lift - X500
Not sure what happened to my edit, but I meant to say JLG Towable boom lift, not JBL which are speakers.....
Cyclone Rake
Stihl BR 600
post #3 of 18 Old 09-17-2019, 10:37 AM
20,000 Posts & Climbing
No problem for the tractor moving that load.
No experience on that man lift.
TUDOR is online now
post #4 of 18 Old 09-17-2019, 01:07 PM
Regardless the tounge weight. If it needs to be pulled across any slopes how you going to stop it? On level smooth ground you should be ok.
Just remember that lift weights is a lot more than the X500.
Ariens93GT20 is offline
post #5 of 18 Old 09-17-2019, 02:57 PM
Nouveau Redneck's Avatar
If the tongue weight is approximately 10% of the overall weight of the tow-able implement, as it should be, then the whole thing should only weigh around 2500 lbs. I pulled a 3600 lb. commercial wood chipper that had about 320 lbs. of tongue weight around my hilly property with my JD X500 and it didn't have any problems. Just go slow, and even slower on hills.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #6 of 18 Old 09-17-2019, 03:03 PM
joecdeere's Avatar
35' JLG weights 3500 lbs, if it's not dead flat and dry, you are gonna get hurt! it would pull it with some effort, but stop it without running over you? please re-think this!
1948 Allis UC Hi-Crop Cane
1941 Allis WC
1948 Allis G
1948 Allis G
1949 Allis G
1954 Allis G
1959 Ferguson TO-35
1972 MF 135
1979 Power King 2418
1989 Ford 345C TLB
joecdeere is offline
post #7 of 18 Old 09-17-2019, 08:37 PM
Read my post above yours. I pulled a 3600 lb. commercial wood chipper all over my property up and down some pretty steep hills with my X500 and never had a problem going or stopping. I just never went very fast and even slower down hills. On a slight downhill slope it would stop on its own if I just lifted my foot off of the forward pedal. I planned ahead and never needed to try to stop on any steeper downhill slopes, I just went down them real slow and didn't try to stop until I got to the bottom.
Nouveau Redneck
Sean in PA
post #8 of 18 Old 09-17-2019, 09:16 PM
If the hydro can accelerate the load, it can also decelerate the load. Weight transfer going down hill, or when decelerating, automatically adds weight to the tractor's drive tires for better traction. Just don't put the drive control in neutral when decelerating or the rear wheels will stop turning and skid. Simply reduce the amount of forward speed on the drive control until the load is almost stopped before putting it in the neutral position.
It takes surprisingly little effort to move a 3500 lb load on wheels. An X5xx can move that load at engine idle on smooth ground. A 12 year old kid can move it all by himself on a level paved surface. A half dozen kids can get it rolling at a good clip in fairly short order. The only thing to remember is that it takes just as much time and effort to stop.
The US navy used to use JD 120s and 140s to tow fighter planes around on the decks of aircraft carriers. Those puppies weighed quite a bit more than 3500 lb. In fact, the armament load alone weighed more than 3500 lb.
TUDOR is online now
post #9 of 18 Old 09-17-2019, 09:32 PM
oldgibsonguy's Avatar
The OP won't have any issues with an X5xx pulling or stopping with the load. However, it's important to remember that the tractor should stay in gear (forward motion) when moving down hills. Taking your foot completely off of the pedal is not an option.
John Deere X738 4wd
48" mower deck
oldgibsonguy is offline
post #10 of 18 Old 09-17-2019, 09:43 PM
I don't think 3500 lbs. will touch the lift. The rental agency will know what it weighs. But there must have been a reason they required a minim 3/4 ton truck just to pull the last one rented off the lot.
post #11 of 18 Old 09-17-2019, 10:06 PM
joecdeere's Avatar
Sean, I read and respect your post, I'm just one of those people that believe something of that size should be towed with something large enough to control it in all situations, an x5xx series has great brakes, but brakes only stop the tires, not the machine,
I don't know the OP, his skill level, or his site conditions, but too late isn't the time to find out there's a problem. They pull easy, I've rented one several times from HD, I move it around with my 40 HP Massey which handles it with ease. I like me, I'm one of my favorite people, and I guess as I age I slowly have become cautious. Good luck with your project, those lifts are great tools, you will find it saves lots of time and ladder moving!
1941 Allis WC
1948 Allis G
1948 Allis G
1949 Allis G
1954 Allis G
1959 Ferguson TO-35
1972 MF 135
1989 Ford 345C TLB
post #12 of 18 Old 09-17-2019, 10:37 PM
35 Ft lift Machine Weight: 3400 lb / 1542.21 kg
post #13 of 18 Old 09-18-2019, 02:10 AM
A pickup can easily travel at 75 mph down the turnpike. GTs are somewhat limited for speed.
Mmm. Over the road transports have a 21,000 lb tractor and sometimes a 119,000 lb trailer and payload for a load to tractor weight ratio of 5.7:1
An X500 has a weight of 647 lb. The same ratio gives it a hauling capacity of 3666 lb.
Everything is relative.
Try this X710 on for size with a 14:1 ratio.
Nobody starts off knowing everything. We all start with a zero knowledge base and try things to see what works. One of the main benefits of a forum such as MTF is for those just starting out to learn from the experience of those who have already tried the same thing. Those willing to try new things, and learn from others, I hold in high regard. The ones that don't try, learn nothing.
I've spent over 40 years experimenting and pushing the limits for what LTs and GTs could do, and I have often found those limits. But they are so far beyond what I believed possible when I started that I am totally impressed with their capabilities.
With all that said, a modicum of common sense and a smattering of understanding of the physical laws of nature are necessary to keep the experimenting from turning into disasters. Baby steps, fellows, baby steps.
TUDOR is online now
post #14 of 18 Old 09-18-2019, 08:04 AM
blinged out
donmac's Avatar
you might tow it around on flat ground going forward, but an x500 will not back it up any type of slope!the reverse hyd. torque is weak!
somebody tell me I'm wrong, please!
donmac is offline
post #15 of 18 Old 09-18-2019, 12:08 PM
jgayman's Avatar
I know it's not a 3500 lb. lift but I've never noticed any difference with my X500 going forwards or backwards when using my 920 lb. lawn roller - even when backing up a hill.
jgayman is offline
