x585 I pull mower engagement switch - nothing happens - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 09-10-2019, 05:07 PM Thread Starter
Here's the thing. I replaced the switch, but still nothing happens. I didn't think it was the switch to begin with because it was practically new. What else could it be? I know there are other safety features but not sure where to start. Any suggestions will be greatly appreciated.
pschmeer is offline
post #2 of 7 Old 09-10-2019, 05:27 PM
burned300's Avatar
Re: x585 I pull mower engagement switch - nothing happens
time for a test light, unplug pto, assuming seat switch is still in play, have someone sit on seat, park brake released & check for power & ground at PTO connector.
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #3 of 7 Old 09-10-2019, 05:29 PM
inspectorudy's Avatar
One of the first things to check is the wire going from the frame rail to the PTO. It has a small two-wire connector that can be pulled apart if you ran over a big stick or something like that. After that it can get really tricky. If the reverse position switch is out of adjustment it will prevent the PTO from engaging. Or the neutral switch can do the same thing. Look to see if the red and green LED's on the PCB are on with the tractor running. If not then the safety circuit is not complete. One easy way to check the position switches is with your toe. While sitting on the tractor with it running lift up on the reverse pedal and see if the PTO will engage. Don't raise it very much but enough to see if it is that switch. Same thing with the forward pedal. Push it down a hair and then lift it up a hair while trying to engage the PTO.
inspectorudy is offline
post #4 of 7 Old 09-10-2019, 06:52 PM
AKA Moses Lawnagan
KHodges's Avatar
Also, check to see if the parking brake lockout switch is stuck in the closed position.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #5 of 7 Old 09-10-2019, 07:59 PM
mowergene's Avatar
Don't forget to check fuses.
In the past:
In use:
mowergene is online now
post #6 of 7 Old 09-11-2019, 07:00 AM
wirlybird's Avatar
Send a message via AIM to wirlybird Send a message via MSN to wirlybird Send a message via Yahoo to wirlybird
One thing I find on mine when the PTO gets fussy is this.
When I back out of the garage or back up for anything sometimes it will not engage until I hit the forward peddle a bit. Sometimes it take s a few tries.
The other thing I have noticed is that after a good washing the PTO does not like to engage or stay engaged.
wirlybird is offline
post #7 of 7 Old 09-11-2019, 08:53 AM
On my x485 sometimes, I have to tap my brake a few times, it's like it's not coming all the way up, so I tap it and it must pop up a little more and the PTO works.
Zebra5 is offline
