John Deere 345 starting issue - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 21 Old 09-03-2019, 01:36 PM
gt275's Avatar
Re: John Deere 345 starting issue
Originally Posted by 240vtx View Post
I know of a idle speed screw and a idle mixture screw that usually has a limiter cap to limit adjustments. I know of no other adjustment screws on modern mower engines.
Those are located on the top of the carb. The adjustment screw that I'm referring to is on the back side of the throttle plate. Only on engines with a single lever for throttle and choke.
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
1998 345 (08/19 627hrs) 18hp V-twin liquid cooled Kawasaki, 54" deck.
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is online now
post #17 of 21 Old 09-04-2019, 07:39 PM Thread Starter
While waiting on my parts to arrive, I was doing some cleaning around the tractor and was wondering if anyone knows what the green and red leds mean. They both light up so I assume thats a good thing.
Tuner571 is offline
post #18 of 21 Old 09-05-2019, 12:16 AM
inspectorudy's Avatar
If I remember correctly the green means that you have power to the PC board and the red means that all of the interlocks are correct and that you can start the engine. If the red is not on then you cannot start the engine. Things like in reverse or the PTO switch is on etc.
inspectorudy is offline
post #19 of 21 Old 09-05-2019, 11:07 AM
lets see...first the engine did start and run for a short period and now the starter won't stop cranking the engine. Could it be a faulty ignition switch??
JSmith is offline
post #20 of 21 Old 09-05-2019, 06:01 PM Thread Starter
Something like that, the previous owner said it would run for a bit then shut down. It got progressively worse until he called it quits. He never made mention of the continuous cranking issue.
Good news though, just received the new solenoid today and that fixed the cranking issue. Hopefully the time delay module is the cause of my no spark issue and this thing will run!
Thanks for all the tips so far!
Tuner571 is offline
post #21 of 21 Old 09-06-2019, 08:38 AM
RT3360's Avatar
I love it when you figure things out. Good job 👍. Im sure the other one is soon to come.
Craftsman DLT2000, 48
Ariens ST824 snowblower
RT3360 is offline
