2002 X585 Evaluation - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 08-28-2019, 10:56 PM Thread Starter
HD
HDmstng's Avatar
As the title states, I found a 2002 X585 for sale that I'd like to go look at for an upgrade to my 318. It has a 62" deck, a 4 way blade and wagon with only about 300 hours on it. It isn't listed as 4wd, but from my understanding all the x585's are 4wd. How do they cut, would a smaller deck size be better?
Thanks,
HD
1985 John Deere 318
1973 Troy Bilt Horse I Tiller
HDmstng is online now
post #2 of 14 Old 08-29-2019, 06:14 AM
burned300's Avatar
Re: 2002 X585 Evaluation
The 62 is too wide for its on good, too easy to shave some dirt. Out in the flat its great! I love mine. Id cut seller s grass for 1/2 hour or more to warm up engine to make sure it runs right. And yes all x585 are 4x4 with a handle by drivers seat to engage
Sent from my iPhone using Tapatalk Pro
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #3 of 14 Old 08-29-2019, 10:14 AM
AKA Moses Lawnagan
KHodges's Avatar
How much grass do you have to mow, and how uneven is the lawn? I tend to agree with burned, the 62 is a lot of deck to fit in an undulating lawn without leaving high or scalped spots. That said, 300 hrs is short time for a 17 year old tractor, if the price is right, go for it, considering the blade and wagon. I'd hope for maintenance records, the low time makes me wonder why it wasn't used more, and it's also not really enough time for a hidden issue to pop up from use. I'm not that familiar with the gas engine.
I'd also hang on to the 318 if it's in pretty good shape and you have room the keep them both. Selling it would get you just enough for a down payment anyway, and they're very collectable. At least keep it long enough to find a 54" deck for the X585, and sell the 62".
'09 JD 2520, CX200 loader and 62D deck
LP RTR0550 rototiller
?? 60" box blade
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
'08 X748SE, gone but not forgotten
KHodges is online now
post #4 of 14 Old 08-29-2019, 11:03 AM
wirlybird's Avatar
Send a message via AIM to wirlybird Send a message via MSN to wirlybird Send a message via Yahoo to wirlybird
I agree on the deck. I have the 54" on my X585 and it is more than enough for the 3+ acres I do. My area is uneven to say the least and it performs well.
wirlybird is offline
post #5 of 14 Old 08-29-2019, 11:47 AM
badgerland01's Avatar
Many hour meters have been changed on these machines due to faulty gas tank level indicators and several other reasons. I would be sceptical of the 300 hrs.
X749 "H-3 EDITION"
GX345
badgerland01 is online now
post #6 of 14 Old 08-29-2019, 12:07 PM Thread Starter
HD
HDmstng's Avatar
It is probably too much for my smallish yard, but the blade is nice for snow and would eventually like to add a loader for yard work. Not to mention foot controls!
There is a pickup pending, so it may already be gone. The pictures show a pretty small yard and I'd bet they inherited the tractor.
My 318, as you can see, needs some engine work. Compression is only 75 psi in both cylinders and still need to do a leak down test. Last summer lost power and then smelled gas. Restarted and had flames coming out of the exhaust. It still ran, but didn't trust it once the flames started. Figure rings and valves are shot. I'm okay with swapping out parts, but have never done an engine rebuild. Repower is also an option and then a leisurely rebuild of the onan.
Sent from my SM-G950U using Tapatalk
1985 John Deere 318
post #7 of 14 Old 08-29-2019, 01:44 PM
JD X585 owner
gtunney's Avatar
I have an x585 with the 54c deck and very pleased with it. This is my 3rd year with it. Got it with 560 hours and at 760 now. Also have 45 loader, 47 blower, power flow with 14 bushel bagger, front dethatcher, and just added a Ruegg 3pt hitch. Great machine.
Sent from my SCH-I545 using Tapatalk
My toys
2002 JD X585
45 Loader, 47 Blower, 54C Deck, 14 Bushel bagger & Power Flow, 13 Steel Dump Cart, JD Front Mount Thatcher, 36" steel roller, Ohio Steel 42CP Aerator
2003 New Holland TC29D
Technically the TC29 is my Dad's and lives with him 6 miles from me. I own the backhoe unit since that's the 1/3rd I paid for as I insisted he would want/need it eventually.
Previous
2005 JD L118 Lawn Tractor (sold 21 Feb 2016)
gtunney is offline
post #8 of 14 Old 08-29-2019, 02:33 PM Thread Starter
HD
HDmstng's Avatar
Thanks for the tip. They did mention their gas tank level indicator doesn't work so they just keep the tank full. If they didn't fix the level indicator, would it just stop counting hours? Or is it when they get replaced the hours get reset?
1985 John Deere 318
post #9 of 14 Old 08-29-2019, 08:08 PM
mikgran's Avatar
The hour meter on my X485 works when it feels like it. In June of 2016 at time of purchase it read 471 hrs. It now reads 483hrs. The Hobbs analog meter I installed under the hood shows Ive put about 175 hrs on it.
My point is, as others have said, be wary of the hour meter. Someone could have recently repaired it. Id be looking at things like overall appearance, front tire wear, steering play, etc. and definitely inquire about service records.
Good luck!
2004 X485- 54 deck, 47 blower
1977 210
1970 110H
1991 Ariens YT12H w/bagger
1986 Kubota B7200HST
mikgran is offline
post #10 of 14 Old 08-30-2019, 06:41 AM
burned300's Avatar
If only the fuel gauge is bad, the float can be off if the arm.
1970 112
1975 200
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
Brinly cat 0 plow
post #11 of 14 Old 08-30-2019, 06:56 AM
Check around the transmission for leaks at any point where there are shafts coming out. I had to pull mine to replace all seals a couple of years back, on my 2005. Also make sure 4WD engages properly, the shift fork can get worn. Also check that differential lock works properly. The rubber fuel line inside of the tank should probably be checked/replaced. Those are the main problem areas I have seen. Otherwise make sure it runs good.
tractorPete is offline
post #12 of 14 Old 08-30-2019, 08:01 AM
wirlybird's Avatar
Since the dash/instruments were brought up -
Aside from the Hobbs see if there is anything else odd going on. You mention fuel but also see how the temp gauge reads.
With the machine/key in the "on" position turn the lights on one step at a time and watch the dash/instruments as you turn the switch for odd behavior like the needles jumping around or changing position.
Do the same thing with the machine running.
If the dash/instruments are having issues it may be a bargaining chip since a new cluster is now upwards of $1000.
Usually though it is a pretty easy fix if you are handy with a soldering iron.
The instruments on mine were in full blow whacked out mode when I bought the machine but an hour of removing the panel, soldering and clean up and it is back to perfect with the exception of the Hobbs which I don't care so much about.
post #13 of 14 Old 08-31-2019, 01:50 PM
gt275's Avatar
Sorry to go off topic, but what needs soldering on the panel?
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
1998 345 (08/19 627hrs) 18hp V-twin liquid cooled Kawasaki, 54" deck.
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is online now
post #14 of 14 Old 08-31-2019, 02:45 PM
RBRONKEMA GHTFD's Avatar
I have a x585 and have had it for almost 5 years now. The thing is a beast. The only things I have done to it are basic maintenance, and replaced the fuel return hose due to dry rot. I did recently have a knuckle seal go out in the front axle, but it is to be expected for a machine that is 17 years old. In my signature you can see all the stuff I have for it, and use it all too. I recently bought a x748 that I am in the process of finishing up so I can move the loader to and leave the x585 for mowing duties as I am not a fan of swapping attachments all the time. Ultimately I have been very happy with it and wouldn't think twice about buying another one.
07 John Deere X748
54c Deck
Cat. 1 Limited 3pt. hitch
540 Rear PTO
03 John Deere X585
54c Deck w/14 bushel bagger
45 Loader
47 Snowblower
51 Rotary Broom
54 Push Box
Curtis Cab
John Deere 10p Cart
Land Pride CAO556 Aerator
Sold
John Deere x475
48c deck
47 quick hitch blower
02 John Deere x585 rescue project.
RBRONKEMA GHTFD is online now
