Power Flow vs dedicated leaf blower vs other? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 32 Old 08-14-2019, 02:59 PM Thread Starter
intheburbs's Avatar
Moved into a new house last year, and now I have a couple of acres of grass, with lots of trees on and bordering the property. I'm trying to figure out the best leaf cleanup method/tools, and would like others' opinions...
I'm considering a few options:
1) Dedicated commercial-level walk-behind leaf blower. I know this will be a 100% solution. Something like this - Billy Goat F902H Force Blower with 262 cc Honda GX Engine- $1500 I have woods on the back third of my property, so I can just blow the leaves into the woods.
2) Power Flow system for my 425. Cost new will be about $1700. But will this be effective for cleanup? Or will I just drive 50 feet and have to constantly empty it? How effective is it at picking up leaves? What if they're packed down or wet? I like the idea of something that would just be a "bolt-on" to my existing equipment and not another separate engine/device to maintain.
3) Other? I've seen some mention something like the DR leaf vac or Cyclone Rake. Any opinions or experience?
Thanks in advance.
John Deere 425 - 54" Deck - 54" plow blade
intheburbs is offline
post #2 of 32 Old 08-14-2019, 03:28 PM
Re: Power Flow vs dedicated leaf blower vs other?
"It depends".
The walk-behind unit probably isn't going to particularly effective with wet, matted leaves. And also if the pile gets too big.
I would go with 2 or 3. If you have a lot of leaves to pick up, then get something from 3 (a tow-behind unit), they can hold a much larger volume so you are dumping less frequently. I've used both a OEM bagger (powered bagger with a Gravely ZT XL 42) and a DR power tow-behind unit (actually, I just used the motor/fan, fabbed up a mount for it on my 52" Snapper walkbehind mower with the gravely bags) and they both work about the same for picking stuff up. They work great for both spring and fall cleanup.
For either of them (OEM bagger or tow behind), I would recommend getting or even making a metal liner for the fan/blower housing (even if the housing is metal already). Rocks can damage the housing, and it's cheaper to replace the liner if necessary than the housing. Note, I used both units a lot, and it would be considered abuse what I put through them...
For the tow-behind units, there are two "styles", one is a regular trailer-style, and the other is where it's connected so the trailer stays inline with the tractor (even when cornering). Which style you want/use depends on what you like and how many obstacles you have to mow around.
dave_r is offline
post #3 of 32 Old 08-14-2019, 04:26 PM
Power vacuum is the only way to go plus mulching blades to pick up alarger area with out dumping. I built my vacuum thirty years back and have improved it several times. Air speed is more importian then horse power on a blower system. I built my blower and use larger vanes then the one I got the pattern from. I know some brands offer bigger engines and bigger hoses. I have always used 4 HP and 6" hoses. The pick-up shute bigger is better, doesn't clog as often. The engine and blower is attached on a receiver hitch.
Here is a couple of pictures:
DonF is offline
post #4 of 32 Old 08-14-2019, 04:34 PM
Kish JD 318/420/430
RussKish's Avatar
Nice home built unit!!!!!! Is it manual or have you added a lift mechanism?
Russ
Proud Owner of: 318/420/430
RussKish is online now
post #5 of 32 Old 08-14-2019, 06:01 PM
I believe this Trac Vac will do the job.
https://www.mytractorforum.com/83-sa...pstate-ny.html
NYKen is offline
post #6 of 32 Old 08-14-2019, 06:04 PM
Have Dog - Will Travel
Jere39's Avatar
This Trac-Vac does a pretty good job. In my case, the leaves never really stop falling, and it takes me long enough to complete a clean-up that I have never had a leaf free lawn.
Jere39 is online now
post #7 of 32 Old 08-14-2019, 08:10 PM
Parts collector
mopar65pa's Avatar
I had a home built system similar to the one above until the engine seized. I bought a trac-vac system that mounted on the rear hitch, worked well but has a small box and I had to empty often. I just picked up a power flow with 3 times the cargo space that I'm in the process of getting a pull for.
High lift blades and a power flow will work great.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is online now
post #8 of 32 Old 08-14-2019, 08:41 PM
Professional Homeowner
steddy's Avatar
IF you have a place to blow them and it isnít too far away from where theyíre laying, commercial grade blower 100%. If you have a fairly nearby destination, nothing is faster than a good strong blower, such as the Force you picked out (I have one like it).
If theyíre too far to blow, trac vac. Power flow is nice for thick grass because they donít clog, take awhile to fill up with just grass, and easier to wiggle in and out of tight spots when mowing.
Trac vac isnít specific to any particular tractor model.
steddy is online now
post #9 of 32 Old 08-14-2019, 08:43 PM
oldgibsonguy's Avatar
I suppose that you can spend plenty of money on a tow behind vacuum, but why not also look at a quality tow behind sweeper. I bought the JD 44" and can sweep better than 1/2 acre before I dump. Easy on, easy off, easy dump. Plus I can swing it out side of the tractor path and literally sweep while I mow.
https://www.lowes.com/pd/john-deere-...B&gclsrc=aw.ds
John Deere X738 4wd
48" mower deck
oldgibsonguy is offline
post #10 of 32 Old 08-14-2019, 09:08 PM
Don
The DR Power Vacs and Trac Vacs jack knifes when you back up. The Cyclone rake doesn't jack knifes when you back up. So, if you have to do a lot of backing up, get the Cyclone Rake. A sweeper probably jack knifes when you back up.
Don
My craftsman 917.27308 is online now
post #11 of 32 Old 08-14-2019, 09:30 PM
steddy's Avatar
Sweepers are indeed economical. However, if you need to make a lot of trips to the leaf dump if you have a large yard, you'll hate yourself. True, it helps to mulch them first, while at the same time windrowing them, but it could still be a lot of trips. That hopper fills up pretty fast. You could pull it with an ATV with smoother ride and faster ground speed and maybe quieter than a tractor, though.
On a trac vac or cyclone rake or powerflow, you may be limited to how fast/efficient your tractor is. If there's light leaf cover and you want all of them gone, blower might be quite a bit faster.
I may be just grasping at straws, but a trac vac or power flow system will really drink the fuel. When I run my either my belt drive deck driven power flow or when I had the 3pt PTO powerflow for my diesel SCUT, fuel consumption would double. Maybe that isn't a concern for you, I dunno.
I used to use trac vac style collection system, and it worked incredibly well except for the noise. It picked up pretty much every last leaf, but the little pieces of leaves seemed to bet tracked into the house easier than full sized leaves somehow. If there's lots of sticks, I had trouble with it clogging more often. Mine was home built and had a large hopper on it, so it would go a LONG time before needing emptied. Sure got heavy, though. A light duty hydrostatic machine wouldn't have pulled it up the hills I dealt with for very long before burning up the trans. I used it for a lot of years. If I had to bring it somewhere to do a small lawn on a small city or suburban lot, it fit on my 16' trailer even when hooked to the tractor. The hopper was large enough I could do pretty much the whole yard, then load the rig back on the trailer and dump the hopper when I got home. Those are the only yards I've found where the blower is not an advantage. You need to have somewhere to blow the leaves to, like a tree line. Otherwise you need some type of collection system.
I've also used blowers an large lawns (like at our church) to boow leaves into piles, blow or rake the piles onto a large (like 20x30) heavy duty tarp, then use an ATV to drag them to the leaf dump. That actually was pretty fast and efficient.
Overkill.
I love overkill.
I'm Ted.
(Click Here)
post #12 of 32 Old 08-14-2019, 09:33 PM
RBRONKEMA GHTFD's Avatar
This is how I combat mine. I took a walk behind blower with a bad motor and converted it to run off the tractors mid pto. I mounted it on my quick hitch.
07 John Deere X748
54c Deck
Cat. 1 Limited 3pt. hitch
540 Rear PTO
03 John Deere X585
54c Deck w/14 bushel bagger
45 Loader
47 Snowblower
51 Rotary Broom
54 Push Box
Curtis Cab
John Deere 10p Cart
Land Pride CAO556 Aerator
Sold
John Deere x475
48c deck
47 quick hitch blower
02 John Deere x585 rescue project.
RBRONKEMA GHTFD is offline
post #13 of 32 Old 08-14-2019, 10:01 PM
TJR345's Avatar
Got a used PF and chute from my dealer for a $100 and a few extra parts to mount it. Built a box for the 18 cart and can use it for more than leaf collection.
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow bagger
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
Frontier SS1036B Spreader
TJR345 is offline
post #14 of 32 Old 08-14-2019, 10:57 PM
FTWingRiders's Avatar
I get leaves.. seriously.. I'm surrounded my mature 60' Oaks and maples and my lawn is the collection bowl. I tried just my PF with MCS on my 455, but only got about 50' before it was full so I went with the DR vac. Its awesome. It really pulverizes the leaves and I can pick up an impressive amount of leaves before I have to dump it.
There different brands and models that all work well, but I'm a big fan of DR.
However if you have woods, down wind, that you can just blow them to thats another option..
Forrest
X748 2011 with 45 loader, 3PH, remote valve, rear hydro, 54" mulching deck, custom hard cab and R4's
455 with 48' deck with PF and Hydraulic tilt dump, 26" HDAP's, front 18" HDAPs on 10" wheels
John Deere Cab
54" deck
54" blower with metal Impeller, chute rotation and flapper mod, 36T sprocket.
Laded 26" HDAPs for winter duty
54" blade with extensions.
51" rotary broom
3 quick hitches
Front mount dethatcher
Titan forks
SOLD:425, X585
FTWingRiders is offline
post #15 of 32 Old 08-15-2019, 02:21 AM
I know the DR Power vacuum setup I have, it doesn't jacknife like a trailer, it has a fixed connection to the tractor, with wheels that swivel, so it stays squarely behind the tractor if you are turning or going in reverse. It probably depends on which model you get...
dave_r is offline
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
billski, RT3360
