-   John Deere Forum (https://www.mytractorforum.com/12-john-deere-forum/)
-   -   adding fuel gauge to 335 (https://www.mytractorforum.com/12-john-deere-forum/1334227-adding-fuel-gauge-335-a.html)
rockyrude 08-14-2019 11:19 AM
I have been toying with adding a fuel gauge to my 335. Has anybody done this or is the cost of parts not worth it?
inspectorudy 08-14-2019 11:36 AM
Re: adding fuel gauge to 335
They are available for about $20. It is the type that replaces the fuel cap and has the gauge in the top. If you are thinking about an electrical gauge then you would have to find a tank that comes with a sending unit built for it. Most of JD's fuel tanks are a peculiar shape and a normal symmetrical unit will not give accurate readings. And then there is the issue of how to install it into a tank if you try to use your current tank. You will have to cut a hole in the top of your tank and install the sending unit and then make sure that it does not impact the seat/fender. If it were me for the meager benefit that an electric gauge would offer, I would buy the screw-on cap style and call it a day.
rockyrude 08-14-2019 12:47 PM
Thanks, I figured that was how things went, had to ask.
Jimbochap 08-14-2019 07:00 PM
Clean the back of the tractor where you can see the level of fuel in the gas tank.
