Checking hydraulic pressure - "How to" and what gauge/setup to get - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 08-13-2019, 11:12 AM Thread Starter
MISparty's Avatar
Working on a 455
Having never done this before, I'm looking for some high-level info.
What kind of gauge/setup is best to get?
How and where do I check it? If it's just plugging it into a coupler - which one?
When I'm doing the shimming I'll have the seat pan off and diesel tank moved out of the way. Can i start the tractor and check pressure without reassembling everything?
JD 445 ~2001 w/ 60" deck. JD 3pt Hitch (SOLD)
1200hrs
JD 455 ~1998 w/ Rear PTO and 60" deck, and 47 blower. Ruegg Cat1 3pt Hitch. 40 Loader w/ loaded Duros
1700hrs
JD 455 - 1993 (1st year) w/ 60" deck.
1100hrs
MISparty is offline
post #2 of 7 Old 08-13-2019, 11:55 AM
jgayman's Avatar
Re: Checking hydraulic pressure - "How to" and what gauge/setup to get
Ken's Bolt On Grab Hooks makes a nice gauge that you can plug right in to one of your quick couplers.
Go to this link and scroll part way down the page.
Ken's Bolt on Grab Hooks <<Hydraulics>>
jgayman is offline
post #3 of 7 Old 08-13-2019, 03:13 PM
I bought this gauge along with a short hose and coupler from SurplusCenter and then a quick-attach fitting from the dealer. If it wouldn't have been for shipping costs the total outlay would have been about $30. Any similar gauge would work. Make sure the hose is long enough so you can hold it while operating your hydraulics, or at least position the gauge to be visible.
https://www.surpluscenter.com/Air-Pn...-21-1246-K.axd
As far as checking, normally you just plug it into one of your tractor's hydraulic circuits and then operate the control (i.e. your loader lift) and watch the peak pressure during active engagement. When done, shut off the tractor and cycle hyd circuit to relieve static pressure, then disconnect gauge.
If your tractor doesn't have quick-attach hyd circuits then things will be more complicated.
Rob
2016 x758 w/60" HC mower, 54" snowblower, MC519 bagger
2010 2520 w/61" H130 loader, TA 42" forks, KK 60" Pro tiller, iMatch quick hitch, KK middle buster
1996 345 - Traded
Other toys: Stihl BR600 backpack blower; McCulloch chainsaws: 10-10S, 700, 805, 10-10; JD trimmer
2520:_______________________x758:______________________Faithful 345:________________
BigBlue is offline
post #4 of 7 Old 08-15-2019, 03:46 PM Thread Starter
MISparty's Avatar
Thanks for the info!
Does anyone know the answer to the following:
1200hrs
1700hrs
1100hrs
MISparty is offline
post #5 of 7 Old 08-15-2019, 05:00 PM
RBRONKEMA GHTFD's Avatar
You will be fine cleaning everything. Make sure to do it before removing the old valve. This way you lessen the chance of introducing contaminants into the system.
07 John Deere X748
54c Deck
Cat. 1 Limited 3pt. hitch
540 Rear PTO
03 John Deere X585
54c Deck w/14 bushel bagger
45 Loader
47 Snowblower
51 Rotary Broom
54 Push Box
Curtis Cab
John Deere 10p Cart
Land Pride CAO556 Aerator
Sold
John Deere x475
48c deck
47 quick hitch blower
02 John Deere x585 rescue project.
RBRONKEMA GHTFD is offline
post #6 of 7 Old 08-15-2019, 09:30 PM
Just be certain to get a fluid filled (dampened) pressure gauge. Otherwise, you will go crazy watching the needle bounce around.
wooserco is offline
post #7 of 7 Old 08-15-2019, 11:44 PM
badgerland01's Avatar
Yes, you can easily drop the fuel tank back down and fire it up. No need to have the seat pan installed to start the tractor.
X749 "H-3 EDITION"
GX345
badgerland01 is offline
