1988 JD 180 - electrical - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 08-12-2019, 09:35 PM Thread Starter
Hi guys, gals, etc.....
I've had an intermittent issue with getting power to the starter. When I shut down in the evening, something happens that when I hop on in the morning to crank up...nothing to the starter.
However...as I lucked up on one day...if I leave the ignition key on and pull in the PTO to engage with a click; I can unengage the PTO and then turn off the ignition. At that point, I can key the ignition to start and have full cranking power.
The only thing I can see on the schematic appears to be the PTO/Safety Switch that is tied to not only the PTO clutch but the Seat Switch. It's a small device that I popped out of it's holder while changing out the drive belt last year as it's sitting on the chunk for the rear axle.
Not a big deal to pull off the body to pop it out and blow the debris off of it and the connectors...but wondered if anyone had run into this problem before.
Thanks!
Dan Turner
Conyers, Georgia
Dan Turner is online now
post #2 of 7 Old Yesterday, 04:08 PM
Re: 1988 JD 180 - electrical
It might not be the PTO cut out switch. Intermittent starting is a very common problem and the fix is to add a starter relay.
Google AM107421
https://www.amazon.com/HD-Switch-AM1...a-761938486072
Kurts Roberts Auziņš is offline
post #3 of 7 Old Yesterday, 06:14 PM Thread Starter
Thanks....I've been throwing around how culpable the PTO switch could be if everything is triggered in order to allow the starter to turn or the PTO to engage.
The starter relay may find neutral just by flipping through the PTO that is on the same switch circuit as the PTO switch.
I'm just glad I don't have to hook up a computer diagnosis on my old JD 180.
Again...thanks for the good tip...and link!
Dan Turner
Conyers, Ga
post #4 of 7 Old Today, 02:37 AM
MTF--A Step Above!
Brad's Avatar
There is an article in the Tech Exchange section on the Starter Assist Relay. Take a look there and see if that would solve the problem. Good luck! These can be frustrating.
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #5 of 7 Old Today, 06:51 AM Thread Starter
I enjoyed the YouTube demonstration of the "starter click relay" product! It brought about a few questions about the age of the harness and connectors that need to be looked at in the safety circuit. The 180 is built with a seat switch to not engage or disengage the PTO if the switch circuit is not complete. There's a small relay beneath the body that I found was pretty instrumental in the mower's operation for both the PTO as well as the starter circuit...as I had accidentally pulled a colored wire from one of the terminals while fussing with the main drive belt replacement last year. The belt was a grizzly bear service as I think I'd rather wrestle a ticked off Grizzly that replace that belt again. After all the effort to install which included dropping the PTO and then reinstalling and torquing everything back into place...the result was starter not engaging...no clicking or signs of any power to it.
Fortunately....after taking the body off to find where the loose colored wire had gone, the PTO safety relay was buried into the transmission (actually just mounted on top of the transmission...but buried under years of debris); putting it back together yielded completing the circuit that allowed the 12v to the solenoid.
It's pretty much the same symptoms that is happening today....the occasional no signs of life at the starter...no clicking in other words. I think I'm going to uncover that PTO safety relay and clean it up at the wire and connector ends to see if that procedure stops the intermittent starter circuit interruption. I've not looked around for the component to see if they're available. If the clean up works...the hunt will be on.
Again...thanks for the youtube demonstration on the starter relay booster....it had some great ideas and procedures for me to test through on the mower; but also it looks like a good component to add on for those cold starts that could use the boost.
post #6 of 7 Old Today, 12:15 PM
MTF--A Step Above!
Brad's Avatar
Sounds good, Dan. I'd say check any wiring connections and make sure no broken wires. Also, is the switch in good shape? Maybe a shot of electrical contact spray would help.
The fact that it is intermittent makes it harder to find but sort of rules out a totally broken wire or electrical component.
Keep us all updated. Love these projects (when they belong to someone else!!) when a solution is found.
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #7 of 7 Old Today, 03:43 PM Thread Starter
Hah!! That's what I used to say when one of my pals would be working on their "advanced years gear."<G
Something isn't tossing that relay...the PTO triggering with the ignition on points in the direction of the pto safety. It's not a huge ordeal to pull off the body in order to inspect it and wiring. I may reach up and trace a few leads for any insulation peeled off as it's in tight quarters to the belt and transmission sheave. In fact it was a drive belt replacement ordeal that alerted me to the location and how easy it was to pull the connector apart while I was trying to get the belt into the transmission pulley.
The starting circuit was dead from that point...and by reaching in, I was able to find the loose wire and ask myself...."self....what the heck is this?" I originally thought it was an "option" that was there for the 185 with the automatic trans. Bolting it all back together just to find that the starter circuit was kaput...I realized the loose wire was no longer optional. With the body on there's not enough clearance to re-install the connector...so, disassemble for the sake of one relatively short wire from the harness and the voltage became present at the solenoid. Having said that....what we should have done was take a paint brush and clear out all the build up of clippings and dust; hose it down with electrical cleaner and make sure it had a full connection again.
Throwing the body back on...without bolting it together this time, depressed the seat and turned the ignition and we were back in business. Or so I thought. Bolted back down and everything secured, climbed on with me and the crew holding a cold beverage and turned the ignition...dead at the starter again.
The clearance is so tight that when I cranked up, the belt found the wire close enough to snag it and drag it back off the relay. I reached underneath and found the same colored wire and broke the news to the guys and pretty much the entire side of the county. Babies started crying and women started to faint from the "words of disappointment."
Once more...off with the body and down on the transmission....got the compressor to blow the stuff off...completely which was the key. Shoving the connector back on while seated in the debris that I actually swept back under neath the male end of the relay caused the wire to be just in the wrong spot and a pretty sorry connection to boot. Lesson learned. Do it right the first time....which we did. I'll let you know the findings after I pull things apart and check the pto safety relay to see what may have happened in the interim.
I don't know if the pdf loaded for the JD180 elect.schematic...but this one will show you just how simple things were just 30 years ago.
It's not that I have an urge to tear things apart...but when they can use a little attention, I get as much ammo as I can before hand. My best example of this is my Hewlett Packard Design Jet 500...a large format printer for architectural drawings. I purchased it new in 2001 and every so often have to work with it to keep it going....my hands are a lot bigger than the little guys in Japan for servicing this critter. I learned to improvise and just like the John Deere service manual...when it says "remove bolt from spindle mandrel" it actually means....get your right angle grinder and cut off the bolt and nut. Ditto on the HP DJ 500....what they say to do wasn't meant for hands that go along with 280 lbs and 6'5" of me.
The challenges continue.<G
Thanks Brad! I'll be back in touch as soon as I can settle in to step the 180 through it's fix.
Dan Turner
Conyers, Ga
