Can I run an older deck on a newer mower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 08-09-2019, 11:48 PM Thread Starter
I'm trying to isolate a vibration on my new (to me) X340. I thought about switching decks to see if the problem goes away... at least then I'd know the problem was exclusive to the newer deck if the vibration went away when using the older deck. A knowledgable friend told me the problem might be the clutch; I'm thinking I might be able to rule that out by swapping decks.
I've currently got a 48C deck on a 1999 LX277, and I want to know if it will work on the 2009 X340. I know they can both run up to a 54 inch deck (the X340 has a 54 Edge on it now). I just don't know if older decks don't work with newer mowers. I figure they would all have the same mounts but things might change given different models and the passing of a decade.
Cobarchie is offline
post #2 of 22 Old 08-10-2019, 12:12 PM
AKA Moses Lawnagan
KHodges's Avatar
Re: Can I run an older deck on a newer mower
If you have both tractors and both decks, it's as simple a matter as trying the LX177's deck on the X340. if it fits the hangars and the belt is the right length, give it a whirl. Quicker than searching for a list of compatible decks. It's about ten minutes of work to remove or install a deck on those machines.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #3 of 22 Old 08-10-2019, 12:17 PM
inspectorudy's Avatar
Does it vibrate when the deck is not running? Release the tension on the deck drive belt to see if it is in the PTO while it is running. If not then it might be in the deck. Have you taken the deck off to check if everything looks normal? Maybe a broken blade or one that got bent badly or a string wrapped around one of the spindles? If not then take the blades off and run the deck again to see if the vibration is still there. If not then it is in the blades. If it is still there then it could be the deck drive belt that has stretched and is flapping as it turns. I've seen this on some older tractors and many times will leave a black mark on the deck where it is hitting. Buy a new set of blades and try it again if it went away without the blades. I would do this before trying a new deck. Good luck!
inspectorudy is online now
post #4 of 22 Old 08-10-2019, 12:22 PM
I am running a deck that was supposedly off an X320 on my 2002 GX345 which originally came with a 48c. I would say that it's highly likely that it will fit.
denverguy is online now
post #5 of 22 Old 08-10-2019, 02:01 PM
Joe Naab's Avatar
Send a message via AIM to Joe Naab Send a message via MSN to Joe Naab Send a message via Yahoo to Joe Naab
Check for bent spindles, that's serious. The vibrations will certainly bring your deck to a slow death. Cracking and worn parts! Try it with no blades and running while watching the shafts turning as slow as possible.
Ariens GT20 with lots of attachments to play with
New Holland L325 Skid Loader (money pit) with new Kohler K582 mini block, standard q. attach and likes to flip forward
Joe Naab is offline
post #6 of 22 Old 08-10-2019, 06:44 PM
Remove the blades and then hit the PTO switch.
rayjay is offline
post #7 of 22 Old 08-10-2019, 06:52 PM Thread Starter
I called the dealership and asked the service department if the old deck could go on the newer mower. I was told it wouldn't. This is also the same guy that told me I'd need 4 self tapping screws to mount a spindle assembly in my deck when I was just able to use the old nuts from the one I replaced, so take that for what it's worth.
I first changed the blades to new ones and greased up the spindles. No change. Pulled the deck again to take the belt off to see how the spindles were doing. One was rough to turn and made a growl. Got it off and replaced the whole assembly with a new one. Greased it up, put the deck back on, engaged the blades... same vibration, although maybe just a tad better, and oddly enough, the new assembly turned just as rough and made the same sound as the old one I thought was bad. Pulled and mounted the deck again to try two new idler pulleys for giggles. Possibly a bit improved, but maybe I'm just getting used to it. It's still there for sure.
I've pulled and mounted this deck three times now in a week. I'm getting tired of it, although I'm getting faster at the whole deal with practice. Still, I don't want to pull and mount two decks if I find out I can't swap them... I don't have tons of free time.
Both belts are good, or at least seem as though they are. The previous owner replaced them last summer, but not sure how much use they have on them in that time. Strangely enough though, now that it's been mentioned, I just noticed black marks on the deck that I'm pretty sure must be coming from the blade belt as it travels around the middle spindle, and coincidentally, that's the spindle I thought was bad and replaced. I wonder if there is something wrong with the shell of the deck itself that would have made the new assembly sound and turn bad like the other one? It's worth investigating at least. I'll have my wife sit on it and engage the blades so I can take a look as best I can at what's going on with the belt. I sort of feel dumb I didn't do that first.
The vibration is definitely not there until the blades are engaged. I didn't know it would be safe to power up the deck belt without the blades mounted. I'll try that as part of the troubleshooting.
As far as the suggestion made above to "Release the tension on the deck drive belt to see if it is in the PTO while it is running." I'm not sure what that means exactly. Should I literally take the drive belt off and then pull up the knob that engages the blades?
post #8 of 22 Old 08-10-2019, 10:17 PM
JD-285's Avatar
Have you spun the pulley on pto while off and without deck belt on. Of course engine off. How does it feel and sound?
Also engage the PTO with engine running. Without belt on.
X500 "Wife's"
285 "The Ames" backup 1
165 "The 165" (Upgrade to FC420V from 170) backup 2
JD-285 is online now
post #9 of 22 Old 08-11-2019, 08:17 AM
Joe Naab's Avatar
Lightbulb Re: Can I run an older deck on a newer mower
I'll bet your idler pulley is not pivoting freely. Take it apart, clean it and grease it. That's why your belt is so loose. That's likely the vibration. I used to see that a lot.
Joe Naab is offline
post #10 of 22 Old 08-11-2019, 11:02 AM Thread Starter
I changed both idler pulleys with new ones yesterday and still no change. The mower is new to me, and the marks on the deck from the belt could have been there before I got it. I know the previous owner replaced both belts last year; maybe they were too loose for him and that's how the marks got there.
Maybe I need to look into adjusting the idler tension. It might be a little slack.
The suggestions about investigating the PTO seem to be a good next step, but could someone describe the process with a little more detail; maybe with some step by step directions?
post #11 of 22 Old 08-11-2019, 11:37 AM
If you have dropped the deck you removed the belt from the PTO. Release the tension on the belt as you did when dropping the deck and get it off the PTO. Get under there and spin it by hand. There you go. You can also start it up, throw the switch and give it a listen. When I replaced spindles I did both to be sure.
deskrider is offline
post #12 of 22 Old 08-11-2019, 11:46 AM
I believe the post to check the idler was with regard to the pivot, not the pulley itself. I think it good advice to check the pivot as the bushings do wear and need replacing periodically. And if it's binding, could be your issue.
post #13 of 22 Old 08-11-2019, 06:53 PM Thread Starter
I took the deck off and tried to rotate the pulley that moves the deck drive belt, the one on the tractor itself that is underneath the motor, but it wouldn't budge. I pulled up the switch to engage the deck with no belt on it while the deck was off and there was no noise at all. I had to have my wife sit on it and engage it so I could be underneath it to see it start to turn, that's how quiet it was. I guess the good news there is the problem is in the deck itself.
I popped off the entire assembly that holds the idler and the double stack of two pulleys (one for the blade belt and one for the drive belt) and checked all that out. As best I can tell, and I'm no mechanic, those things are rolling smoothly. The spring that pulls against the idler arm seemed to have been bent out of shape at some point in the past, so maybe there just isn't enough tension on the idler because the spring isn't at 100 percent.
I pulled the blades off of the deck, remounted the deck and engaged the PTO. The noise from the vibration wasn't as loud, but the vibration was still clearly there, so the problem has got to be somewhere in the deck. With my wife sitting on it, with no blades on the deck and the belt engaged, I couldn't see the belts flapping about and hitting anything but I could see the idler moving up and down in time with the noise of the vibration, so that has to be the source, but for the life of me, I can't figure out why it would be doing it. The only thing I can think now is the tension on the idler is wrong, but I've already thrown 200 dollars in parts at this thing and spent all of my free time this week trying to fix it. I've pulled and remounted this deck five times this week; two times today and I'm just knackered with it. I'm taking it in to the Deere shop and they'll be able to diagnose it faster and more accurately than I can. Probably should have just done that to begin with; I'm tired of throwing parts at the problem...
post #14 of 22 Old 08-11-2019, 07:38 PM
It sounds like you have a stretched belt and a weak idler spring. Even though you did not see it hitting anything the belt is flapping and the idler is showing you how much it is. I hope you dealer is a nice guy and only charges you for a new belt and spring.
post #15 of 22 Old 08-11-2019, 10:38 PM Thread Starter
I'm tired of messing with it, but the sting of defeat is worse than the work of trying something else as simple as replacing a spring and a belt. The idea of a loose belt has been bothering me all night... From looking at it and taking it off so many times it just doesn't seem that the belt is loose, but I keep wondering if it could be and that's all it is.
A spring and a belt shouldn't be more than 40-50 bucks. I'm sure that means I'll have to pay nearly 100 dollars at the Deere place..........
inspectorudy
