45 Loader before and after pics - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 34 Old 08-08-2019, 09:02 PM Thread Starter
gt275's Avatar
I spent some time restoring the bucket on my 45 loader. Sanded the rust and some loose paint and used several rattle cans to paint the bucket. Also sprayed some clear and added new decals. One 6 inch to the back of the bucket and a 3" on either side of the arms.
I was going to have it powder coated, but the $300 price tag made me rethink it and decided to paint it myself. I think it turned out pretty good. My wife said, "Now what are you going to do when you need to use it?"
ID:	2390155   Click image for larger version
ID:	2390157   Click image for larger version
2004 X485 (4/15) 25hp Kawasaki, 62" deck, 45 Loader, Front-mount de-thatcher.
2005 GX345 (11/09 124hrs) 20hp V-twin liquid cooled Kawasaki, 54" deck, Differential lock, Femco Cab Weather Enclosure, 42" snowblower, Electric Spout Rotation Kit.
1998 345 (08/19 627hrs) 18hp V-twin liquid cooled Kawasaki, 54" deck.
-SOLD-
2001 345 20hp V-twin liquid cooled Kawasaki, 54" deck
1998 GT275 17hp Kawasaki, 48" deck, Cab Enclosure, 38" Snowthrower, Manual Spout Kit
1997 LX188 17hp Kawasaki, 48" deck
gt275 is online now
post #2 of 34 Old 08-08-2019, 09:11 PM Thread Starter
gt275's Avatar
Re: 45 Loader before and after pics
One more
-SOLD-
gt275 is online now
post #3 of 34 Old 08-08-2019, 09:16 PM Thread Starter
gt275's Avatar
A couple more of the gx345 to get you thinking about winter.
Added 6" decal to the back of the cab.
ID:	2390163   Click image for larger version
ID:	2390165   Click image for larger version
-SOLD-
gt275 is online now
post #4 of 34 Old 08-08-2019, 11:44 PM
cadman56's Avatar
Loader turned out real nice!
Grandpa Cadman56
1972 JD 140 H3 14hp/41" deck/
1981 4211 11 hp / 36" deck
2003 Prestige 23 hp / 54" deck
2008 JD X728 27 hp / 62" deck / 45 FEL
JD JS60 Walkbehind
Echo SRM-2100
Echo ES-210 Shred-'N'-Vac
cadman56 is online now
post #5 of 34 Old 08-09-2019, 02:26 AM
Just great. Now we're going to get snow in August. Thank you very much.
dave_r is online now
post #6 of 34 Old 08-09-2019, 04:58 AM
20,000 Posts & Climbing
Looks good!
You don't powder coat something that is going to bang into rocks. Paint scratches and can get worn off requiring a simple sand and repaint to fix, but powder coat chips and moisture gets under the edges of the chip so that the ensuing rust can lift large patches of powder coat. The result is u-g-l-y, and the repair is to grind off all of the powder coat and rust patches and start from scratch.
TUDOR is online now
post #7 of 34 Old 08-09-2019, 09:55 AM
Wfburton159's Avatar
Paint looks good. I agree on the powder coat being a bad option for this.
2003 John Deere X485
647 tiller
54c deck w/ mulch kit and power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
post #8 of 34 Old 08-09-2019, 12:25 PM
oaks1450's Avatar
Looks great! I would have gone with paint also.
1964 110
1964 110 w/Johnson 10 loader
1987 318
1991 420 w/ 44 Loader
2007 X300 w/bagger
oaks1450 is offline
post #9 of 34 Old 08-09-2019, 12:30 PM
AKA Moses Lawnagan
KHodges's Avatar
I agree with Tudor 100% on powder coating. If you use a loader, it's going to lose its paint on the bucket. I don't really worry about the bare steel, if you use it often enough it stays polished. If you put it up for a while, then I'd use a spray bomb to coat the bare spots and keep the rust away.
I love those ripper teeth, did you buy them or make them? If you made them, what from?
'09 JD 2520, CX200 loader and 62D deck
LP RTR0550 rototiller
?? 60" box blade
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
'08 X748SE, gone but not forgotten
KHodges is offline
post #10 of 34 Old 08-09-2019, 02:18 PM Thread Starter
gt275's Avatar
I originally was going to powder coat it since it is powder coated from the factory. I agree, it's going to scratch off eventually, so spray cans were the way to go, plus it was a lot cheaper.
The bucket had missing paint when I bought it. Since then I have moved 40 tons of traffic bond for a retaining wall and patio and also the retaining wall block and pavers, so it has had some use. Not to mention removing the huge 300-400 lb boulders from where I built the wall and tons of dirt from planting a tree line.
BTW, the Tooth Bar is from Titan Attachments.
-SOLD-
gt275 is online now
post #11 of 34 Old 08-09-2019, 07:13 PM
Looks sweet. How much time did you spend?
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Ford 1910 4WD Loader Backhoe
Jacobsen GT14
cnymowinplowinsailin is online now
post #12 of 34 Old 08-09-2019, 08:39 PM Thread Starter
gt275's Avatar
I power wire brushed and sanded for 2 hours then pressure washed and let dry.
By the afternoon I was spraying green paint in light coats letting it dry between coats.
Probably 8 hours total at that point.
Then I let it dry for several days and re-sprayed green again.
Then let it dry for several days and clear coated and is what you see today.
Wasn't too bad, just a lot of patience which I normally don't have.
-SOLD-
gt275 is online now
post #13 of 34 Old 08-10-2019, 02:22 AM
A labour of love doesn't require patience. It's the main ingredient of the love package.
TUDOR is online now
post #14 of 34 Old 08-10-2019, 08:02 AM
4Get GTO's Avatar
I first thought was why bother. But it made the world if difference. I'm OCD about that stuff myself.. 👍
4Get GTO is offline
post #15 of 34 Old 08-10-2019, 09:48 AM
Still lovin' the 322!
PA318Guy's Avatar
Now everyone thinks you never worked it!
Looks good, never hurts to maintain equipment.
Current Machine JD 322
PA318Guy is online now
