335 surging when warm - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 08-04-2019, 09:25 PM Thread Starter
My mower has developed a surge when warm. If the mower deck is applied the surge goes away and it runs strong. Turn the pto off and it surges at high speed and will kill at low speed.
Sometimes the Rpms won’t even come down when the throttle is lowered, just stays at full.
To me it seems like 2 different problems. Maybe a fuel issue for the surging and a linkeage for the rpms not wanting to lower. 😐
papacamper is offline
post #2 of 11 Old 08-04-2019, 09:32 PM
Re: 335 surging when warm
My 345 had a similar issue that turned out to be old gas lines allowing it to suck air at the filter.
meyerjrj is offline
post #3 of 11 Old 08-04-2019, 09:55 PM
Jimbochap's Avatar
Time to replace the carburetor
https://www.ebay.com/itm/New-CARBURE...8AAOSwndZaZ3k0
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is online now
Old 08-04-2019, 10:03 PM
Jimbochap
This message has been deleted by Jimbochap.
post #4 of 11 Old 08-04-2019, 10:47 PM Thread Starter
I wish a replacement carb was only $25, gotta 10x that!
post #5 of 11 Old 08-05-2019, 07:38 AM
Jimbochap's Avatar
It is $26, try one and see what happens.
John Deere X495
54" Mower Deck
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
post #6 of 11 Old 08-05-2019, 08:11 AM Thread Starter
My current carb is 4 bolt and has 2 flaps, not 1
Looks like this, it’s not officially for my motor but looks like it may still fit.
https://www.amazon.com/Karbay-Carbur...26146304&psc=1
post #7 of 11 Old 08-05-2019, 10:25 AM
Father Deerest
Run a heavy dose of seafoam through the fuel system for a few tanks and see if that clears anything. It's not the cure all but I've had it work in several machines, worst case take the carb off and run a strand of thin wire in the ports and soak it in carb cleaner.
Father Deerest is offline
post #8 of 11 Old 08-05-2019, 11:12 AM
Sea foam is a great product, I mix up some in each five gallon can when purchasing fuel, then it's got a fighting chance. All of my other small engines run on E-94.
Clipperskipper is offline
post #9 of 11 Old 08-05-2019, 12:08 PM
inspectorudy's Avatar
I recently bought a nice X520 that had been sitting for a year and it surged at idle but ran ok at WOT. I poured the required amount of Seafoam into the the tank and ran it for about thirty minutes and it cleared up. Not guaranteed but it is a cheap and easy first step. After that, all of my experience with Kawas is the carb. I believe the Japanese culture is more refined than ours when it comes to taking care of machinery. They tend to be more focused on things like cleanliness and care of fuel and maintenance. That is why the Mikuni carbs are so much trouble for us. They were built for people who pay attention to their fuel and what they put into their machines. I do know that the Mikuni carbs have smallest orifices in a carb that I have seen and it takes only a mite that is almost not visible to change the operation of the engine. Good luck with your issue.
inspectorudy is offline
post #10 of 11 Old 08-05-2019, 12:30 PM
Originally Posted by inspectorudy View Post
. I believe the Japanese culture is more refined than ours when it comes to taking care of machinery. .
I would bet that the vast majority of made in japan Kawasaki OPE engines are exported out of japan.
I think the problem with the motors using 2 bbl carbs is that the carbs are too big for the requirements and this reduced airflow through the carb makes the jetting more critical. I know on the GT245 I had the carb had a built in limiter that kept the butterflies from opening more than about 1/4 to 1/3. That means that 2/3 to 3/4 of the potential airflow is not being used, i.e. the carb is too big. Most likely they had to do this due to poor mixture distribution between the cylinders. This is also why the carbs on these motors have different jetting on cyl 1 than cyl 2. I can also imagine that it is common for the jets to be put in the wrong side when the carb is rebuilt by a shadetree mech.
rayjay is offline
post #11 of 11 Old 08-07-2019, 12:25 PM
Trying2mow's Avatar
Originally Posted by jimbochap View Post
amen
Trying2mow is offline
