John Deere Power Flow Leaves strip of clippings. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 07-26-2019, 03:51 PM Thread Starter
Ive seen a couple of postings on this subject but nothing about the solution.
Bagger picks up everything except a narrow strip of clippings about 4 inches wide and 10 inches from left side of more.
Mower has baffles in place. Also, it did not always do this.
Any suggestions?
Clanita is offline
post #2 of 21 Old 07-26-2019, 03:55 PM
Re: John Deere Power Flow Leaves strip of clippings.
You looked underneath the deck, that it's clean and that the all the belts for the deck and powerflow have good tension, and that the blades are all in good condition (not just sharp, but that the "wings" on blades haven't worn away)?
dave_r is offline
post #3 of 21 Old 07-26-2019, 05:23 PM Thread Starter
Thanks Dave.
I had cleaned and checked everything.
As you suggested maybe the wings have worn. I could try swapping with one of the other blades or get a new one to try.
BTlW, its on the right side and not left as I indicated earlier.
Clanita is offline
post #4 of 21 Old 07-27-2019, 02:40 AM
maybe also take the deck belt off and see how the blades spin on their own. it's possible the one spindle (or rather, the bearings in the spindle) are failing and preventing the blade from spinning at full speed. The pulley and belt would also be getting pretty hot after mowing for awhile if this were happening.
dave_r is offline
post #5 of 21 Old 09-08-2019, 06:59 PM Thread Starter
I have checked everything I can think of; levelled the deck, put on new blades and still having the problem with the strip of clippings not being picked up. Im now thinking that the power flow fan may be worn and not working as well as it should. My next step may be to replace the fan (unless someone knows of a better fix).
Clanita is offline
post #6 of 21 Old 09-09-2019, 02:41 AM
Is the fan in the powerflow unit still bolted to it's spindle? I've had that bolt shear off on my powered bagger fan, and the fan would still rotate a bit, but not nearly enough.
I've also found that higher lift blades also help with getting grass into the bagger.
dave_r is offline
post #7 of 21 Old 09-09-2019, 07:41 AM
demonspeed's Avatar
Has it always been like this, or only recently started?
2004 John Deere GX345
48 Edge Mower & Blowout Kit, Predtor2s|42 Thrower|48" Blade & Angle Kit
Front Bumper|Halogen Kit|Carlisle HDFT & Xtrac
FOR SALE: 3481M 48" Blade/Angle Kit and BM20827 Mulch Kit for 54C/54D/54X
Past:1988 Bolens ST120 Hydro Eliminator
36 Mower & PowerPacker|42 Blade & Lift Kit|Head Light Kit
demonspeed is offline
post #8 of 21 Old 09-09-2019, 12:38 PM Thread Starter
Think problem started a couple of years ago and has been getting progressively worse making me think its caused by wear.
The fan is secured and working. The puzzling part is that the mower picks up all the clipping from the far left side of the mower and leaves the clippings about a foot from the intake to the power flow.
Clanita is offline
post #9 of 21 Old 09-09-2019, 02:17 PM
Not toooo puzzling: The left blade makes clippings and blows them to the center blade. The center blade makes clippings and blows them, PLUS the clippings from the left blade, to the far right blade. The far right blade also is making clippings and passing those PLUS the clippings from the center blade AND the left blade!!! LOTS of clippings heading towards the discharge.
I'd look inside the chute/tube from the power head to the collection bag. You may (???) have clippings stuck to the inside of that slowing down the clippings. If the power head can't get clippings through the tube, it'll just leave them. If connection chute/tube is clean/clear, replace fan. Bob
rwmeyer is offline
post #10 of 21 Old 09-09-2019, 02:45 PM
inspectorudy's Avatar
The powerFlo fan blades do wear and lose a lot of suction. I have one now on a GX345 that is pretty worn along the outer edges and tips. I think also that as crud clings to the tube, that can help slow down the transfer of grass into the bags. If there is any loss of suction or flow rate the extra grass has to end up on the ground just outside of the powerflo head.
inspectorudy is offline
post #11 of 21 Old 09-09-2019, 02:58 PM Thread Starter
Thanks to everyone for your words of wisdom. As I consider your advice and my own suspicions, Im looking at replacing the fan (which does have a lot of hours and looks to have wear). Ill be sure to let you know how it goes.
Clanita is offline
post #12 of 21 Old 09-09-2019, 02:59 PM
AKA Moses Lawnagan
KHodges's Avatar
1-How old is the system (for wear)?
2-How dry is the grass?
3-How much are you cutting off the grass?
4-How high do you have the deck set?
5-Does this issue start with an empty collection system or only when it's close to being full?
6-Do you have the antiscalp wheels set lower on the right side of the deck?
I've found that these are the biggest issues with using my Power Flow system. I routinely use gator blades and have no problems generally with the lift they create, unless the grass is wet; by wet I mean "juicy" and rapidly growing, not just dewy or rained on.
As the turbine wears, it gradually loses vacuum, and even Gator blades start losing lift as the 'ears' on the blades wear.
If you have the deck set to a fairly high level (3" or more), you begin to lose the effectiveness of the anti-blowout plates and the deck also allows more air to be pulled in from around the edges, decreasing overall vacuum. The more you cut off the grass, the heavier the mass that the vacuum is trying to move, and the more that will get left behind. The left side of the deck starts to lose vacuum first. The partial solution to cutting more, cutting higher, and cutting 'wetter' grass is to slow down, sometimes a lot slower than you want to go.
Once the collection bag or cart starts getting close to full, the less air can pass through the system, which starts causing it to back up. First you start getting what you're describing, a trail of clippings left behind, then the chute begins to clog.
The last thing, with the antiscalp wheels, is that they help keep the deck level, due to the weight of the turbine head. If the deck is even slightly off level, you lose vacuum out the left side, not to mention a more uneven cut, which may go unnoticed.
Maybe your issue is something else, but these are the things I've discovered from using a PowerFlow, with the MC519 collection system, on a 54C deck, for the last ten years.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #13 of 21 Old 09-10-2019, 06:08 AM
TJR345's Avatar
What deck do you have. I had a similar problem with my 62c deck and found out I was missing a baffle on the right side. I got the PF used so I didn't know till I looked at the parts break down.
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow bagger
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
Frontier SS1036B Spreader
TJR345 is offline
post #14 of 21 Old 09-10-2019, 08:09 AM
Jimbochap's Avatar
I have a 54c deck and as far as I know I don't have any special bafle under my deck...........Do you have a picture as to what this baffle looks like.
Also I'm not leaving any strip of grass either..............My power flow and bagger did not come with the tractor. It was a bagger and power flow I pieced together which works fine. Only additional part I had to buy was the click n go bracket whichI use for both the bagger and weight bracket.
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline
post #15 of 21 Old 09-10-2019, 03:42 PM
demonspeed's Avatar
There are definitely baffles that are supposed to be bolted to the underside of the lips around the perimeter of the deck. Go to partscatalog.deere.com and search your tractor model and find the parts list for the bagging system.
