Jd 160 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 44 Old 07-17-2019, 02:20 AM Thread Starter
Onward till it's done
Jd 160
Well, it was a long day. Tried to get my JD 160 going. The last time I used it was about six months ago and I thought there was a problem with either the starter or the solenoid. I bought a new battery and installed that. And things kind of went south from there. The reason I thought the issue was the starter or the solenoid is because when I used the mower six months ago, I wiggled some of the wires under the starter and the solenoid and after I did that, I was able to start the mower. Well, yesterday, the wiggling trick failed. I thought I would take the wires off and do some cleaning and make sure the contacts on the starter and solenoid were good. After I did that and put everything back together, it still didn't start. My brother in law who has big farm JD's walked over and thought maybe the solenoid wasn't working. He suggested I take the solenoid off and take it to NAPA to have it tested. I did that and the rep there tested it and said it was working. I wasn't sure what my next step was going to be. When I got back to the mower, I put it back together like I though it was supposed to go. I think I may have put some of the wires back onto the solenoid in the wrong sequence because after I put the wires back on the starter and solenoid, when I went to reconnect the battery, I encountered sparking. So I think I put something back wrong. Hope I didn't ruin my new battery. Also, when I removed the wires and started putting them back, I dropped or misplace the 13mm nut that holds the wires to the solenoid. I will get another one tomorrow. Meanwhile, if someone would be so kind as to coach me to put the wires back in the proper order, I'd be grateful. Next time I will take things apart on a cement floor instead of in the dirt or in the grass. Also, I don't know what else to try. I am wondering if I need to replace the battery cables. Or maybe the problem is with the key switch. If I hadn't got sparks when I tried to reconnect the battery, I was going to try to jump start the mower. Maybe it's a good thing I didn't get to that point. I might have ruined the battery or ruined some of the other electrical components or both. Thank you.
stevem17 is offline
post #2 of 44 Old 07-17-2019, 02:21 AM Thread Starter
Re: Jd 160
And if I posted in the wrong place, please let me know. Thank you.
stevem17 is offline
post #3 of 44 Old 07-17-2019, 02:32 AM
MTF--A Step Above!
Brad's Avatar
Re: Jd 160
Good morning Stevem17.
You posted in the correct forum, no problem there. Not being familiar with the JD160 not sure of any special requirements on putting the wiring back together, but some folks on here should be able to help. Pretty straight forward.
What was it doing before you took the solenoid off?
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #4 of 44 Old 07-17-2019, 07:21 AM Thread Starter
Re: Jd 160
Thank you de KA9WRZ. The JD wasn't doing anything. Just couldn't get it started. I did use my multimeter (still learning how to use that). Got a 12.4v reading when I checked the connection at the solenoid. I'm not certain I did that correctly. Thanks again. Have a blessed day!
stevem17 is offline
post #5 of 44 Old 07-17-2019, 09:55 AM
The Admin from... Nowhere
littletractorguy's Avatar
Re: Jd 160
Hi Stevem17,
Since I've got a 160 out in the garage, are there any questions I can answer for you, pix I could take for you about how mine's set up? So, you turn the key and nothing at all happens? In a case like that, my first guess (and easy to check) would be the seat safety switch connector is loose/flakey... If you still have the seat safety switch. You can check on it by just lifting up the seat, you should see it bolted onto the bottom of the seat, and the wiring harness with connector will be sticking out.
littletractorguy is offline
post #6 of 44 Old 07-17-2019, 12:39 PM
Re: Jd 160
Steve, When you checked the solenoid, did you check at the battery wire terminal or the smaller wire terminal? At the battery terminal you'll always get 12+ (battery voltage). When you check the smaller terminal, you should only get 12v when the key is in the "Start" position.
There is no sequence to attaching the wires to the solenoid. If your getting sparks, it sounds like you've got a short someplace (??). If wiggling the wires got it going once or twice, I'd say the short is in one of those wires. Remove whatever wires you wiggled and check the insulation. The only other possibility I can think of is a bad key switch, but check wire insulation first. Bob
rwmeyer is offline
post #7 of 44 Old 07-17-2019, 01:18 PM
JD-285's Avatar
Might try this.
https://www.mytractorforum.com/12-jo...1330135?page=2
X500 "Wife's"
285 "The Ames" backup 1
165 "The 165" (Upgrade to FC420V from 170) backup 2
JD-285 is offline
post #8 of 44 Old 07-17-2019, 01:44 PM
Re: Jd 160
Sparks are not uncommon when reconnecting a battery. Typically, you want to make sure the key is set to off, connect the positive, then connect the negative last. (Reverse is true for disconnecting, always remove the negative first). This cuts down the chances of inadvertently shorting your positive to the ground when wrenching on the positive terminal.
First check park brake is set, PTO off, in neutral, and seat safety switch. If all those are working, you should hear a clicking noise. Sometimes you have to press the brake further than where park is set, sometimes need to wiggle shifter and clanck to left to make sure neutral switch is tripped, PTO left on is very common (especially after running out of gas while mowing), Seat switch is easy enough to short out with a jumper wire.
There are a few tests you can try with a voltmeter. One sounds like you have done, and that is to see if one of the big wire to the ground has 12 ish volts, the other will have zero. With weight on the seat, turn-key and see if the zero side goes positive. If does go positive, it's likely a starter problem. Disconnect everything and figure a way to spin the starter manually with a long screwdriver or something. Sometimes, brushes get bad spots and simply rotating the position will engage the magnets.
If the starter side of the solenoid didn't go to 12 in the previous step, move your positive probe to the smaller wire going to the solenoid. If it goes nowhere when flicking the key to start, then start jumping safety switches.
Does your tractor have a supplemental "Starter Relay" installed? Google AM107421 Sometimes the solenoid doesn't get enough juice from the ignition switch to engage. Wiggling the wires probably used to be enough to get past the hump.
This Minor fix is very common. See more here:
https://www.mytractorforum.com/234-a...y-install.html
I bought a generic version of AM107421 for about $10 or $15 on amazon or ebay.
Here is a $30 version from JD of Ebay:
https://www.ebay.com/itm/Starter-Rel...ss!46037!US!-1
Before you shell out for this, another quick test would be to make a jump start lead connected to the positive and touch the other end to the small wire going into solenoid (as in the little wire that is not grounded). Or jam a screwdriver across the two big wires on the solenoid, that will throw a few sparks, but the started should spin.
Hope one of these works for you.
Kurts Roberts Auziņš is offline
post #9 of 44 Old 07-17-2019, 01:55 PM
MTF--A Step Above!
Brad's Avatar
Re: Jd 160
Take a look at my signature with the link to a Youtube video. Explanation in there how this happens.
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #10 of 44 Old 07-17-2019, 02:20 PM Thread Starter
Re: Jd 160
Thanks Kurts Roberts. I don't understand your suggestion where you suggest, "Disconnect everything and figure a way to spin the starter manually with a long screwdriver or something. Sometimes, brushes get bad spots and simply rotating the position will engage the magnets." Are you saying I should stick a screw driver into the starter? Thanks for all your suggestions. Plan to try give them a try later today. Thanks again.
stevem17 is offline
post #11 of 44 Old 07-17-2019, 02:26 PM
Re: Jd 160
Just going to say that the battery, especially if new and fully charged, should read +13 Volts DC. The 12 Volt designation is what the battery provides under load.
With the multimeter turned to the Volts DC setting, touch the black test probe to the negative terminal and the red test probe to the positive terminal. You should get 13 point something volts. If you still are reading 12 point something volts, return the battery, if new.
Flaken is offline
post #12 of 44 Old 07-17-2019, 02:55 PM Thread Starter
Re: Jd 160
Thanks Little Tractor Guy. I will take a look under the seat. I don't recall if the seat safety switch was functioning previously or not. If you have time, please post a pick of the safety switch on your JD 160. And also, please post a close up of the wiring hook ups for the starter/solenoid. Thank you.
stevem17 is offline
post #13 of 44 Old 07-17-2019, 05:34 PM Thread Starter
Re: Jd 160
Ok, this is really strange. I hooked up the wires to the starter/solenoid again and....when I went to hook up the battery (positive side first) no problem. But when I attempted to connect the ground side, more sparking and it sounded as if the starter was spinning. There are two post on the solenoid and I tried attaching the black wire that comes from the voltage regulator to the smaller (back post of the solenoid) and I hooked the red wire from the voltage regulator along with the red cable that comes from the battery, do the larger post on the solenoid. Also, someone suggested I check the safety switch for the seat. That switch is disconnected. Do I need to reconnect it? Thanks y'all!
stevem17 is offline
post #14 of 44 Old 07-17-2019, 05:50 PM
Re: Jd 160
After a quick search on Duck Duck Go, I found this schematic for the L100 series. Take a look and verify your wiring goes to the correct places.
https://diagramchartwiki.com/john-de...iring-diagram/
Flaken is offline
post #15 of 44 Old 07-17-2019, 10:50 PM
JD-285's Avatar
There is a free manual online. I think he is working on a “160” and not LT160.
X500 "Wife's"
JD-285 is offline
