heck yeah id paint it or dude, it is what it is? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 07-15-2019, 09:19 PM Thread Starter
This is the 6' deck on my F1145 which it is time to sell now that I'm convinced the X595 is the right machine for my new home. It is straight, cuts very well (arguably far better than the 62C) and is solid. However, surface rust is pervasive, there are a few pin holes starting and there are some holes in the exit you can see in the second pic. My question for you is would you paint it and if so what method. Or, is it at the point where it is what it is and nothing I'm going to do with it is going to change what I get for the machine anyway? Machine is mid 90s with just over 1500 hours on it.
ID:	2386727   Click image for larger version
ID:	2386729   Click image for larger version
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Ford 1910 4WD Loader Backhoe
Jacobsen GT14
post #2 of 18 Old 07-15-2019, 10:32 PM
Cat385B's Avatar
Re: heck yeah id paint it or dude, it is what it is?
Does the deck look much worse than the rest of the machine? If yes, then pretty it up. If the whole unit looks shabby, sell as-is.
Cat385B is offline
post #3 of 18 Old 07-15-2019, 10:46 PM
inspectorudy's Avatar
If you are not going to do a good job of preparing the deck before you paint then don't waste your time. I have done a lot of old decks and it is a lot of hard work to get them ready to paint. I think you are looking at about 5 hours of hard work to get that deck in decent shape to sell. If the tractor looks as bad as the deck just forget about it and sell it as is.
inspectorudy is online now
post #4 of 18 Old 07-16-2019, 03:32 AM
I would say if it's rusted through in parts, the next owner is unlikely to be impressed with your paint job once he/she finds out what's underneath it (be it either pre or post-purchase).
dave_r is offline
post #5 of 18 Old 07-16-2019, 09:15 AM
RBRONKEMA GHTFD's Avatar
As others have stated, does the rest of the machine look the same, worse or better? Next question you have to ask yourself is, is this going to make or break a sale? 3rd question is, if I spend say 500 properly sandblasting, and repainting this deck will it make a difference in the selling price? You could potentially spend the money on it and it not make a difference in the overall selling price, and you could potentially be out that 500 dollars for nothing.
07 John Deere X748
54c Deck
Cat. 1 Limited 3pt. hitch
540 Rear PTO
03 John Deere X585
54c Deck w/14 bushel bagger
45 Loader
47 Snowblower
51 Rotary Broom
54 Push Box
Curtis Cab
John Deere 10p Cart
Land Pride CAO556 Aerator
Sold
John Deere x475
48c deck
47 quick hitch blower
02 John Deere x585 rescue project.
RBRONKEMA GHTFD is offline
post #6 of 18 Old 07-16-2019, 11:24 PM Thread Starter
Thanks all for the input. I tried to keep the rest of the machine out of the discussion out of respect for the lawn and garden tractor forum. The rest of the machine is in far better condition and will likely polish out nicely and then a little touch up paint in a rub spot. I'm going to pull the heated cab off and sell both it and the blower separately then try to create a solid 6' diesel 4WD mower that someone who has a decent sized property and doesnt need a perfect machine would buy. Other than the deck the only other real issue with it is the seat. There is no point in going after restoration grade here just respectable take it home and knock some lawn/field down with it at a decent price point. I think a lot of potential buyers me now included would not even look at it as is but also dont need a perfect powder coat finish for a machine destined to maintain a rural property.
Any thoughts or pointers to threads on what process best achieves my goal for the deck?
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Jacobsen GT14
post #7 of 18 Old 07-17-2019, 02:21 AM
I wouldnt sand blast the deck. And if it costs $500 to have it done, youre paying waaaay too much.
Bead blasting is much much less harmful to the metal and you can buy an entire home sand/media blaster set up for $500. Not a cabnet that will hold a 6' deck but a roll around blaster and compressor that will give you enough air to do it in spurts. And thats brand new. Second hand sales would be cheaper.
NicoR is offline
post #8 of 18 Old 07-17-2019, 09:20 AM
Check with a local powder coater, or even heavy equipment refurb shop. See if they'll just take it down to bare metal and prime it. Tell them you'll paint and take care of the rest. That is what I have done in the past and it has worked out well for me. I have been told that the guys running the sand/ media blasters don't care what the parts are (what the parts are for etc.) They just know they need to be cleaned up and do great work. Same with the painters/ powder coaters. They know they need primer and paint and quality of work has to be the same across the board.
07 John Deere X748
54c Deck
540 Rear PTO
03 John Deere X585
45 Loader
47 Snowblower
51 Rotary Broom
54 Push Box
Curtis Cab
John Deere 10p Cart
Sold
John Deere x475
48c deck
post #9 of 18 Old 07-17-2019, 02:01 PM
Putting lipstick on pigs works.
Remove what you can part wise, metal brush cup on an angle grinder to knock back whatever rust you can.
Tape off the lables and non-yellow pieces. Rattle can a few coats of big box store JD yellow.
This could be done in a couple of hours and make a huge cosmetic difference.
It's not much different than washing and waxing a car or cleaning the engine bay.
Looks go a long way for getting online shoppers to your door.
Kurts Roberts Auziņš is offline
post #10 of 18 Old 07-17-2019, 02:38 PM
I agree that putting lipstick on a pig works. You do not have to knock yourself out but get the surface rust off and then use a cheap primer and a cheap yellow paint and you will be surprised what a difference it makes. Buyers are looking for the best when they come to see your stuff. If you make an effort to clean and paint it, it will make a difference. I have looked at tractors where there is so much dust and grass on it that I cannot read the labels on the deck. The engine bay looked like a dirt dobber's nest with so much red clay. I would never sell a tractor without cleaning it up first.
post #11 of 18 Old 07-30-2019, 08:38 PM Thread Starter
Have you guys had any experience with the rust converter products? I know either way you take the flaky stuff off but is there any benefit to them over the metal brush cup until its bare and then primer route?
How many cans for a big deck like this and am I doing top and bottom?
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Jacobsen GT14
post #12 of 18 Old 07-31-2019, 10:52 AM
I have used Duro "Extend" (made by Permatex/Loctite) and Rustoleum "Rust Reformer" and several other similar rust converters,they do work pretty good,I used them on rusty floors and body parts on vehicles I had..
They need some rust to work,so don't wire brush or sand it to bare metal--get all the loose crusty stuff off,blow off or vacuum the dust off,wipe it down with some laquer thinner,then apply the rust converter..it will look like milk going on,then dries to a clear coating after the rust gets turned black..it does resist further rusting quite well..
POR-15 is a coating that converts rust and dries to a very tough coating,that will lat a long time provided its not exposed to UV rays--they do have versions that are more UV resistant..however its very expensive,like $30 a quart,and your better off using it all up at once,its tough to store unused portions without it "welding" the can lid or glass jar top on permanently..
Auto body supply stores also sell chemical rust converters like Morton's "Rust-Mort" and some paint brands like R-M had a coating/converter that uses phosphoric acid to convert the rust to a black primer and prevent further rusting..
I would be honest and tell a potential buyer ,yes,I painted the deck--but it did have a few pinholes that'll need attention down the road"...
|I don't like people coming back angry when I sell something,I tell them every known "issue" it may have--if they don't buy it,its better than having them come back wanting to kick your butt if you failed to disclose any potential issues..
I'd be a lousy used car salesman..
Tractor-Holic is offline
post #13 of 18 Old 07-31-2019, 03:41 PM
KATT's Avatar
What he said If you can see daylight through it, I don't think you want to see what sand blasting will show you
Current 09 " X520 with 48" Deck, #44 Snow Blower, Weather Enclosure, Wheel Weights, Chains, drift cutter, Brush Guard, #36 Tow Behind Spreader, Single bucket holder, #7 #80 and #50 Trailers,
"11" X540 54" Deck
Some LX 188's and a few 100 series
Previous JD's
"86' 318 #44 Front End Loader, #49 Snow Blower. TY15380 Hard Cab, Wheel weights Chains Weight box ( 6 suitcases ) "99"LX279 Liquid Cooled ."87"SX95 / Rear Bagger, 165 Hydro, STX38, LX188. Toy a 175 Hydro #38 snow blower #38 mower deck.
Sold Rusty
KATT is offline
post #14 of 18 Old 07-31-2019, 08:39 PM Thread Starter
Yep me too. Thanks for sharing the rust converter experience. I'd like whatever I do here to last as long as possible given a reasonable amount of effort and cost.
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Jacobsen GT14
post #15 of 18 Old 08-01-2019, 02:16 PM
May I suggest you polish up the tractor as good as you can. Price it up a little, and "throw in" the "as is" mower deck to anyone willing to consider your asking price.
X 500 48" Deck 48" blade
Cyclone Rake
Stihl BR 600
Sears Suburban Super 12 1968
Alien5044 is online now
