Basic Questions on My JD 318 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Michael Page. Visited Today 10:45 AM Subscriptions
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
post #1 of 13 Old 07-15-2019, 03:00 PM Thread Starter
[email protected]
Frank@Mound's Avatar
Can anyone answer these basic questions. Attached are images each question refers to:
  • Is the mule drive belt supposed to touch this little elbow mounted on the deck top?
  • How much play should there be in the steering (see video link)
  • Attempted to level the deck -three good corners, but the front right insists on being lower than the front left. To get it as close to "level" as can be I have to raise the front right wheel and it still sits lower than the front left. Any ideas?
ID:	2386693   Click image for larger version
ID:	2386695   Click image for larger version
ID:	2386697   Click image for larger version
post #2 of 13 Old 07-15-2019, 04:20 PM
RussKish
Kish JD 318/420/430
RussKish's Avatar
Re: Basic Questions on My JD 318
You can find this information by going to the John Deere Parts web site and doing a model lookup, putting in the 318 model number. Looking under the various sections involved.
For steering:
You need to get a repair kit for the steering. The nuts and bolts there are 24M
These are plates and bolt into place : AM101198 > M88755 $11.14 each; plus bolts/nuts Metric (4) Nuts 14M7273 1.05 each; Bolts 19M7163 $0.54 each
Also check the axle pivot bolt/bushings/spacers, also check axle to see if the hole is wallowed out, if it is then axle needs to be replaced or repaired (drilled out/sleeved).
Bushings P1076H (2) $6.06; Spacers M80030 (2) $5.34; Bolt M85458 (1) $22.17
Front Wheel Spindle Bushings are serial number dependent:
S/N 222001-372595 - M83541 (4) $5.45 each
S/N 372596-999000 - M70808 (4) $6.59 each
S/N 010001-______ - M70808 (4) $6.59 each
Deck wheels:
Front wheels should be set in the same holes, There should be be a sticker showing the height spacing according to the holes, Do you have that sticker? Back wheels are the same way, but should be offset by it being higher by 1/4"
Deck Belt: Check Guide, looks like it have been beaten down on top, belt is to be under it, so that is correct, but that angle looks off to me. No pics in the deck manual showing it with belt under it.
The deck level hanger (left to right height adjustment) (the one that has the threaded bolt needs to be on the right side to allow for adjust the side with the power flow blower weight/balance)
The front to back level is adjusted by the nuts on the arms attached to the mule drive)
Russ
Proud Owner of: 318/420/430
RussKish is online now Report Post
post #3 of 13 Old 07-15-2019, 05:02 PM
JDDottie
Ya gotta bear in mind - a JD 318 L&G tractor - there is an operator's manual - for the tractor.
And then each & every attachment that can be used with it - front blade, mower deck(s), tillers, etc., will have a separate operator's manual. JD is pretty persnickety about posting that stuff on line anymore.
JDDottie is offline Report Post
post #4 of 13 Old 07-15-2019, 07:56 PM Thread Starter
[email protected]
Thank you for this information. I have the technical manual, but it doesn't appear to tackle things like the plate and bolt found at the deere site. It does tackle the pivot bolt.
For steering:
So the idea isn't that the bolts are not turned to their proper location (snug, I presume, up against the plate), but that the plate itself is worn (which is visible) and if it is replaced, the bolt head would be in the proper place.
S/N 372596-999000 - M70808 (4) $6.59 each -this would be mine.
Deck wheels:
Front wheels should be set in the same holes, There should be be a sticker showing the height spacing according to the holes, Do you have that sticker? Back wheels are the same way, but should be offset by it being higher by 1/4" -I have the sticker and attempted to level, with difference between front and back, but the right hand front wheel I could not get to level with the front left. It continued to stay on the ground unless I changed the position of the height adjustment (as in the photos). After messing around for quite some time, it appeared something was wrong I couldn't see. I'll go back to it and mes with the mule drive arms -and if I read you right, place the threaded hanger on the right side to help out with the powerflo (which I do use during leaf season).
I need to pick up a deck technical manual from ebay...but maybe the level issue is what is causing the belt to touch the 90 degree bracket.
The front to back level is adjusted by the nuts on the arms attached to the mule drive)[/QUOTE]
post #5 of 13 Old 07-15-2019, 07:58 PM Thread Starter
[email protected]
The previous owner gave me the technical manual and the onan component tech manual -but that is all. I need to pick up a deck tech manual.
post #6 of 13 Old 07-15-2019, 08:32 PM
RussKish
Kish JD 318/420/430
RussKish's Avatar
You need the Operator's manual for what you have:
316, 318 and 420 Lawn and Garden Tractor > OM-M72236 Operator's Manual
46" MMRM Deck > OM-M89612 Operator's Manual
PowerFlow for 38",46" and 50" Mowers > OMM121515 Operator's Manual
Make sure the belt guide is straight vertical from the plane of the deck and the top part is more towards 90 degree but still slightly down that is how mine looks
Russ
post #7 of 13 Old 07-15-2019, 08:50 PM
RussKish
Kish JD 318/420/430
RussKish's Avatar
Deere could of originally had them on the machine, but even back then the bean counters were involved. So now you drop the axle and clean up the wear on the old frame and bolt on a new wear plate. With how it is now you will not get the proper vertical travel needed for slops, hills, turns. You also need to check wear on the bolt head too. Then adjust as directed in the TM
Deck wheels:
Even mine touches the top when not powered, but drops down when under power.
[/QUOTE]
IF there is a lot of wear in the mule drive, things will bind and it will be very hard to get level front to back or left to right.
Russ
post #8 of 13 Old 07-15-2019, 09:50 PM Thread Starter
[email protected]
[/QUOTE]
Well I did buy a 35 year old machine! So things could be replaced, as needed. But I will begin with the axle stuff since it feels sloppy. Time to get comfortable working on garden tractors.
post #9 of 13 Old 07-15-2019, 11:02 PM
RussKish
Kish JD 318/420/430
RussKish's Avatar
Yes they are old but very hardy and tough. I have a 318, 420 and a 430 all of which are slowly being rehabed because of wear and age. Still use them a lot 50 to 100 hours a year each. But I will give them to my sons when I die.
Russ
post #10 of 13 Old 07-16-2019, 10:48 AM
inspectorudy
inspectorudy's Avatar
It isn't uncommon for one of the supports for the gauge wheels to have been knocked up or down a little. If it is then you can bend it back with a long steel pipe or just leave it alone and adjust the wheel off of the level ground. Remember, they are only occasional wheels and do not actually roll on the ground so if one is off a little it doesn't really matter. I'll be honest that I have never heard a good explanation for the two bolts on the axle for intentional slop or play. I usually keep them just off of snug but there must be some reason why people want them to be sloppy. I also grease the gap. The belt guide is definitely bent forward. Hit it with a big hammer towards the rear and it will be fine. The 318 and its attachments are very robust and simple. Don't be afraid to do to them what it looks like you should do. Everything is reversible.
inspectorudy is offline Report Post
post #11 of 13 Old 07-16-2019, 03:20 PM
mopar65pa
Parts collector
mopar65pa's Avatar
My front axle on my 332 egg shaped and did what your does only worse. Yep replaced it with a used one off a 330. Tightened up the gap in the bolts and she steers wonderful now.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline Report Post
post #12 of 13 Old 07-16-2019, 11:58 PM Thread Starter
[email protected]
Thanks -I'm depending on this machine nearly every season now and can't afford too much down time!
post #13 of 13 Old 07-17-2019, 08:56 AM
antiqueetc
More on deck leveling: The deck should be leveled by measuring from the blades to a hard surface. Orient the blades fore and aft to get that measurement. Rotate 90deg to measure side to side. Set the decks wheels to clear the same surface by 1/4-1/2". They do not really level the deck, they only contact the ground to prevent scalping. All this is covered in the deck manual, but who reads those things, right? Yeah, me neither only as a last resort.
In order to get the axle adjustment to work as intended, the surface the bolt head touches needs to be flat. Otherwise the adjustment won't be correct except in the one place where it was set. As the axle moves up/down it will become tighter or looser. I have welded and reground those to make it better. Of course welding and grinding freehand won't be perfect but it can be better that the worn surface you have.
antiqueetc is offline Report Post
Remove Text Formatting
Bold
Italic
Underline
Insert Image
Wrap [QUOTE] tags around selected text
Decrease Size
Increase Size
Switch Editor Mode
Drag and Drop File Upload
Drag files here to attach!
Upload Progress:
0
Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd tiff txt wmv xls xlsx zip
Currently Active Users Viewing This Thread: 1 (1 members and 0 guests)
Michael Page
Forum Jump
You may post new threads
You may post replies
You may post attachments
You may edit your posts
