John Deere F525 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 07-15-2019, 08:39 AM Thread Starter
John Deere F525
My tractor will not start and I am pretty sure it is the solenoid/starter. I am having trouble accessing that part. What is the easiest way to remove the left fender?
rrbuff1960 is offline
post #2 of 7 Old 07-15-2019, 09:56 AM
Re: John Deere F525
You might get a lot more response in the section devoted to John Deere, located a bit higher up in the main page.
tom
simplificate & add lightness
tomw0 is offline
post #3 of 7 Old 07-15-2019, 10:43 AM Thread Starter
Re: John Deere F525
Thank your for the advice, Tom.
Jack
post #4 of 7 Old 07-15-2019, 10:47 AM Thread Starter
Re: John Deere F525
I tried that. When I got to John Deere and try to post a new thread, it tells me to log in. When I login, it tells me invalid username or password. I am already logged in though and for some reason cannot start a new thread.
post #5 of 7 Old 07-15-2019, 03:22 PM
MTF--A Step Above!
Brad's Avatar
Re: John Deere F525
What does it do when you try to start the engine?
Drop me a PM!
Brad
de KA9WRZ
Brad is online now
post #6 of 7 Old 07-19-2019, 02:32 PM Thread Starter
Re: John Deere F525
When I bought it from my brother in law, he said the ignition switch was going bad. When turning the key, it would not always "make contact" and turn over. It had begun to take more tries to get it to turn over and start, so I planned to replace it this spring. It got to the point where I needed to charge my battery before each start. I replaced the ignition switch to no avail. It made no difference other than it won't even start with a full charge. My attention shifted to the starter/solenoid. However, I cannot access this part without taking off the left fender. I removed every bolt I can see and feel but still cannot get the fender off. I can find now exploded view anywhere that might help me see what I am missing.
post #7 of 7 Old 07-20-2019, 10:34 AM
Still lovin' the 322!
PA318Guy's Avatar
Re: John Deere F525
Sounds like your battery is old or is being drained by something when not in use. I would try a known good battery and see if it fires each time. Might just be loose battery cables too or a bad ground or even a bad battery cable.
Current Machine JD 322
PA318Guy is offline
