Questions for the john deere experts - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 07-13-2019, 05:27 PM Thread Starter
stratocast56's Avatar
I am looking at purchasing a John Deere 425 with the product identification number M00425B01154 not complete but is only readable part. I believe that would make it a 1993. I will post some pictures showing the tractor, the hour meter reads 800 hours. The gentlemen who owns it says he bought it 7 years ago from a dealer who took it on trade not running and replaced the bad plastic timing gear with the new steel one. He says that has been a great tractor but he doesn't need it any longer as his son now does all of the yard work with his new equipment. It has the 54 inch deck, rear PTO and three point lift installed. The rear PTO is one of my concerns, it is the female design that would require a male end on the drive shaft to the attached piece of equipment or a male to male adapter shaft. I thought all of the 425,445 and 455 tractors had the male PTO installed? Please respond with your comments and advice once you read this and view the pictures. The seller is asking $2,600.00 for the unit but has hinted could be bought for $2,400.00 cash!!
Name:	John Deere 425-1.jpg
ID:	2386409   Click image for larger version
Name:	John Deere 425-2.jpg
ID:	2386411   Click image for larger version
Name:	John Deere 425-4.jpg
ID:	2386415   Click image for larger version
Name:	John Deere 425-5.JPG
Name:	John Deere 425-6.JPG
stratocast56 is offline
post #2 of 12 Old 07-13-2019, 06:47 PM
Re: Questions for the john deere experts
Here's some data on the JD 425.
TractorData.com John Deere 425 tractor information
800 hours for a '93 seems real good, look over the rest of the machine close.
Plastic sides and hood are fragile.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #3 of 12 Old 07-13-2019, 07:44 PM
4x5 rear pto utilize male to male adapter.
BM17757 John Deere 540 RPM Rear PTO Stub Shaft Kit. Converts 540 rpm rear PTO gear box female output to industry standard male output. Required for powering most 540 rpm equipment. Not required with 450 Tiller.
https://www.shopgreendealer.com/John...t-BM17757.html
John Deere PTO Stub Shaft - M112354
https://www.greenpartstore.com/John-...t-M112354.html
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is offline
post #4 of 12 Old 07-14-2019, 10:52 AM Thread Starter
Help Re: Questions for the john deere experts
Can anyone comment on pricing for this tractor due to age and hours?? If you review pictures is in good shape, has a new upper hood section installed and it has been kept clean. Should I be looking at something newer in that price range?? Comments please!!
post #5 of 12 Old 07-14-2019, 08:28 PM
Merc1973's Avatar
From what i have seen, that is a good price. Comes with the 3 point hitch and rear PTO?
1981 400- Vanguard 23 HP, 54C deck, 56 blade, 50 snow blower
SOLD-2003 G100- 54", Kohler Command 25, Gator G5 blades
JD 46" snow Blade
Stihl 031AV (WIMA cap, base gasket delete) 20"
Echo CS-590 (MM) 20"
Husqvarna 128LD Trimmer
Giant Vac w/ 6.5HP Predator Engine
Unknown 1980's Japanese backpack Blower with Kawasaki engine
1968 M35A2
Merc1973 is offline
post #6 of 12 Old 07-14-2019, 09:01 PM
I don't think the price is out of range, plastic cam replaced, pto and 3ph.
It's age is the only drawback but it's one issue has been resolved, plastic cam gear.
It is carborated, 445 has EFI, 455 is diesel.
If you have a use for PTO and 3PH, I'd say it is a good deal.
You could do a lot worse.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #7 of 12 Old 07-14-2019, 09:14 PM Thread Starter
Exclamation Re: Questions for the john deere experts
Thank You for your comments will be making the eight hour trip each way road trip to pick it up!! The 3 point hitch and PTO are the real reasons I want it, have a good 48 inch tiller that will save me tons of work in the large garden I put out every year. I will follow up with a new post including new pictures once I have have it home and completely check out!!
post #8 of 12 Old 07-14-2019, 09:19 PM
Hope it works out well for you.
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #9 of 12 Old 07-14-2019, 09:53 PM
Country1966?'s Avatar
That's a liquid-cooled V-Twin it's only half used up. If it was maintained well it's not even half used up. they're not making them like that anymore my friend; I think that's a good buy.
and as I like to say even if you have to spend a little money on it, that's no throw away mower
Massey GC2400
Gravely ZT HD 60" 24hp Kaw.
Old Troy Build Horse Tiller
Husky Snow Blower 24" 6hp
Not Enough Barn
Country1966? is online now
post #10 of 12 Old 07-14-2019, 10:13 PM
Here a real nice one for comparison.
https://indianapolis.craigslist.org/...928919361.html
If I didn't have an x530 I might jump on this one.
Wlmitty is offline
post #11 of 12 Old 07-15-2019, 01:54 PM
Deck shell is worth $500.00 to ?
CCMoe
CCMoe
2000 John Deere 455
1991 Ingersoll 4018
1988 Cub Cadet 1720
Cub Cadet 1320
Murray 13.5 HP
Gilson Rear Engine
CCMoe is offline
post #12 of 12 Old 07-15-2019, 05:46 PM Thread Starter
I saw that tractor but it doesn't have the rear PTO or 3 point hitch, going to leave Wednesday morning early to go pickup tractor. I will probably start a new thread one I get it home and checked out completely!!
