jd "316" low oil cut off now no start - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 07-11-2019, 04:43 PM Thread Starter
jd "316" low oil cut off now no start,,, it is a MOO316X426127 WAS CUTTING GRASS AND IT DIED the oil lite came on, I add 1/2 gt,, but now no start, thank you Thomas Brown have gas, 12v on coil
Leroy Brown is offline
post #2 of 12 Old 07-11-2019, 06:26 PM
Re: jd "316" low oil cut off now no start
Sounds like you should have checked the oil prior to using it. That said, if it abruptly shut down you may have seized it and only after cooling down would turn over again but the damage is done....
kbit is offline
post #3 of 12 Old 07-11-2019, 06:45 PM
Does the engine crank? Oil lite will come on when the engine isn't running, simply because the pump isn't running. Which happened first? The lite, or the engine quitting?
HeyYou is online now
post #4 of 12 Old 07-11-2019, 07:06 PM
Senior Moment
Greybeard09's Avatar
Many of these engines use the same type of oil pressure switch, it's not an oil amount or "low oil" sensor... They measure pressure.
These simple switches won't cause the light to turn on until there is zero oil pressure. Zero oil pressure is a death sentence for an internal combustion engine.
Late 50's Bready... aka, "The WoodRat"
1969 John Deere 110 w/front blade
1998-99 MTD/AYP "Black Thing" 18hp Briggs MUTT-Mower
2002 Cub Cadet 2166 (in process)
2006 Cub Cadet GT2544
2011 Cub Cadet Z-Force S 48
Greybeard09 is offline
post #5 of 12 Old 07-11-2019, 09:37 PM
Alot of oil pressure switches also cut power to the coil.
Safety feature. No pressure, no fire.
I would remove the switch and clean it with carb cleaner into the switches inlet port.
Reinstall and try again.
Wlmitty is offline
post #6 of 12 Old 07-11-2019, 09:55 PM
Did you check the oil level before or after adding any? How much is in it now?
Seems like a normal process, engine dies, then trouble lights are suppose to come on. Just like when you go to start the engine. Turn the key, warning lights come on, then crank it over, they go out when it starts.
I donít think this is related to the oil level.
xcrsp440 is offline
post #7 of 12 Old 07-12-2019, 07:34 AM
Trouble with that theory is, at startup, the engine shouldn't fire until oil pressure comes up. Which isn't the case.....
I think he has some other issue in there.
post #8 of 12 Old 07-12-2019, 10:59 AM
Kish JD 318/420/430
RussKish's Avatar
Which engine in this 316? A Kohler or Onan?
Russ
Proud Owner of: 318/420/430
RussKish is offline
post #9 of 12 Old 07-12-2019, 02:31 PM
I'm guessing onan, as I don't think the kohler had a pressurized oil system.
post #10 of 12 Old 07-12-2019, 07:06 PM
Kish JD 318/420/430
RussKish's Avatar
Well a tear down would tell about any damage. It could be that the oil pan is full of sludge and may be a fuzz ball on the oil pickup screen. Both of which can starve an engine of oil. Or the oil pump (which is two gears wore out or broke away from the timing gear on the crank.
Russ
RussKish is offline
post #11 of 12 Old 07-12-2019, 09:26 PM
Senior Moment
Let's not have him tearing the engine down just yet... He hasn't been back to answer the "does it turn over and not fire, or not turn at all?" question.
post #12 of 12 Old 07-12-2019, 10:35 PM
Kish JD 318/420/430
RussKish's Avatar
True, so let's now wait to see if the OP comes back with any more info.
Russ
RussKish is offline
