Is a John Deere X380 enough for my yard - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 40 Old 07-10-2019, 10:57 PM Thread Starter
Hello Everyone. I am looking for advice on purchasing my first riding lawn mower.
I have about 0.7 acres with some small hills and one larger hill that is about 100' long with slopes ranging from ~10-20 degrees (see attached photos of the larger hill). I currently use a Honda self-propelled mower and am looking to upgrade. I went to the local John Deere dealer and they recommended a X380 for my lawn based on my description without seeing any pictures. They thought that for my situation the k58 transmission on the X380 was a good compromise between the k46 on the other X300 machines and the k72 on the X570.
I live in Madison, AL so I do not really need any snow removal attachments where something like hydraulic lift would come in handy, but I would like to be able to occasionally bag my clippings and perhaps pull a cart with dirt/mulch around the yard. I am looking for a mower that will last a long time (15+ yrs) if well-maintained. Will a X380 last that long if well maintained, or would I need to step up to something like a X570?
Any and all input would be much appreciated.
Thanks,
Tim
Name:	Side View - Wide.jpg
ID:	2386073   Click image for larger version
Name:	Bottom View - With Angle Labels.jpg
tkokan is offline
post #2 of 40 Old 07-10-2019, 11:11 PM
inspectorudy's Avatar
Re: Is a John Deere X380 enough for my yard
I have a similar yard and I use an X390 which is almost the same tractor as the X380. It does the hills with no trouble or hesitation and the one inch axles are sturdy enough to handle the work. The K58 is a big improvement over the old K46 and most of the issues it had are gone and it is serviceable with a filter. People on this forum have a tradition of telling people to buy bigger than they need in case they want to add a freeway to their home in the future!
inspectorudy is offline
post #3 of 40 Old 07-10-2019, 11:15 PM
Alberta Al's Avatar
If you're going to be mowing straight up and down the hill, then you might want to upgrade to the better transmission. If you are only mowing side-to-side as shown in your photos, then the X380 is more than sufficient.
  • 2013 John Deere X540 with 54X Edge Xtra Deck
  • 47 in. Snow Blower, 42 in. Hydraulic Tiller, Integral Power Sleeve Hitch
  • Brinly Box Scraper, Brinly 40 in. Plug Aerator
  • 3 bag power flow bagger, 10P Utility Cart
  • LP36741 weather enclosure
  • 4 - Quik-Tatch Weights (42 lbs)
  • Tire chains
  • 928E Walk-behind JD Snowblower
Alberta Al is offline
post #4 of 40 Old 07-10-2019, 11:28 PM Thread Starter
It was my understanding that when using a riding lawn mower on a hill of 10+ degrees, mowing up and down is the way to go and when using a push mower, side-to-side is best (which is what I do).
tkokan is offline
post #5 of 40 Old 07-10-2019, 11:46 PM
Alberta Al's Avatar
If you're concerned about tipping, then maybe mow on a diagonal??? If not, then personally I'd go up to an X5__ series.
  • Tire chains
post #6 of 40 Old 07-11-2019, 12:33 AM
You're right about mowing up and down on a hill. You'll probably still be mowing that area over by the retaining wall with the push mower, but I think you can do the rest as it looks like you have a level area at the top to turn around on.
Something to consider with the x570 is it has a locking differential. Do you need it? Maybe not, but it'd be nice to have. Otherwise yeah the x380 is a good choice.
MinnesotaSteve is offline
post #7 of 40 Old 07-11-2019, 01:06 AM
Well said! x10
denverguy is offline
post #8 of 40 Old 07-11-2019, 05:33 AM
UpstateTony's Avatar
X380 will handle that yard no problem, itís a very sturdy LT, probably going to have be careful around the retaining wall where slope is steepest. Properly maintained The X380 will give you 20-30 years in that yard
2012 John Deere X310
2009 John Deere LA-135 SE
UpstateTony is offline
post #9 of 40 Old 07-11-2019, 07:09 PM
I agree with the folks recommending the x380 for your yard. For piece of mind, I would hit the transaxle case with an IR thermometer immediately after mowing the hills on a hot day while still within the JD Promise period. If the case measures above 180 F ish, I'd reconsider.
I'm sure there are other opinions on the max temp but TT suggests 195 F as a max temp.
post #10 of 40 Old 07-11-2019, 07:24 PM
Proud JD Owner
Mach-1's Avatar
You'll get varying opinions. I'd get an X570 minimum w/HDAPS and diff lock for that hill. Amortize the extra cost over the life of the machine and it's not that much more. Better to upsize than to find out you under bought later. Diff-lock is an indispensable thing to have. After having a machine with it, I would not go without.
___________________________________
2008 X720 Ultimate
54" Blade
47" Snowblower
Powerflo Bagger
Mulch Kit
#18 Dump Cart
Mach-1 is offline
post #11 of 40 Old 07-12-2019, 04:04 PM
Banker / hobby farmer
Stryker7200's Avatar
I'd probably recommend an x5 series tractor over the x380. x380 may get the job done, but I think you will have a much better chance making a 5 series last 15+ years. Especially if you start towing a loaded cart over the hills to any degree.
__________________
JD 2003 X485, JD 54" hydraulic 4-way blade, JD 647 rotary tiller, 2x 50 lb wheel weights, 62" Edge deck.
Stryker7200 is offline
post #12 of 40 Old 07-12-2019, 05:12 PM
I knew it! Get ready to build that freeway to your back door!
post #13 of 40 Old 07-12-2019, 06:30 PM
Steve Urquell's Avatar
Lol. I read a thread on another forum where the OP said he had asked this question over here and got the "Tim the tool man Taylor" response of buying a cannon to swat a gnat with.
I agree that the JD dealer gave good advice on the X380. I ran a K61 on my 3 acres of very rough hills mowing my fields and it didn't overheat until ~2.5 acres were mowed. <1 acre will be fine with a K58.
Steve Urquell is offline
post #14 of 40 Old 07-12-2019, 07:14 PM
wally2q's Avatar
the transmission is fine... but lack of diff-lock will make it a fun ride.
Living in AL, you probably get the occasional rain?....
There is no better amusement-park-ride than going down a 20deg hill on wet grass, with the rear wheels spinning in opposite directions (diff. action), while you are applying 1 million pounds of force on the brake pedal, yet still accelerating... LOL!
Now try the same going up-hill, and lose traction.... even more fun!!!
You want diff lock.
wally2q is offline
post #15 of 40 Old 07-12-2019, 07:21 PM
You want diff lock.
I'll politely disagree here with the stipulation that if you have that much traction need then buy some ATV tires. I have no diff lock on my Cub XT3 and have no problems with my ATV tires mounted. They also do not tear up the grass as they do not spin.
Oh, I also have a 3240 with diff lock. The XT3 w/o diff lock does as well as the 3240 with diff lock in slippery situations. ATV tires are better than diff lock and much cheaper.
ID:	2386253   Click image for larger version
