X585 bucket down pressure can't lift tires off ground - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 44 Old 07-10-2019, 10:21 PM Thread Starter
Shacker
papashelby's Avatar
I went with my neighbor yesterday to look at an X585 that he did purchase even after finding this issue. The tractor has 700 hours on it and appeared to be well taken care of, all original paint other than a few touched up areas. When testing the bucket out, it seemed to work as it should (comparing it to mine), but it struggled to lift the front tires off the ground, maybe be an inch at most even at full throttle. Checked the fluid level, and it was full. I drove the tractor around his property with some steep inclines, and the tractor never missed a beat, just like driving my X728. When I asked the owner when was the last time he changed the fluid and filter, he hesitated somewhat and said "maybe four years ago ... probably about 200 hours ago", which makes me think it's probably more like 6-7 years and 400 hours ago. He definitely didn't know when he did. Also, when lifting the bucket to full height, (which it does with no problem), there is a very loud high pitch squeal coming from the right side ram and the tranny area when at full height, quiet on the way up. So the question is, could the issue be a somewhat plugged filter and/or bad hydraulic fluid, or more likely something wrong with the hydraulic pump? Any and all thoughts appreciated. Thanks, Rick
2012 X728
48C deck
MC519 collection system
3 point hitch
47" blower and suitcase weights
54" blade
Curtis ROPS soft side cab
Front bumper and fenders
Front mounted thatcher
45 Loader
1997 345
48" deck
snow thrower
2 bag bagger
1984 420 with 50" deck - sold
1968 112 all original, from my dad, with:
deck, snow thrower, white patio blade, cab, 1966 #80 cart with vac system, all shop manuals
papashelby is offline
post #2 of 44 Old 07-10-2019, 10:37 PM
Kish JD 318/420/430
RussKish's Avatar
Re: X585 bucket down pressure can't lift tires off ground
1st thing to do is a hydro fluid and filter change. Then redo all those test. It is the most simplest of things to try and it may fix the issue.
Russ
Proud Owner of: 318/420/430
RussKish is online now
post #3 of 44 Old 07-10-2019, 11:13 PM
inspectorudy's Avatar
Actually the first thing to do is to curl the bucket to the dump position and then try it again. Many FEL's with the bucket in the flat on the ground position do not have any range left to lift the tractor. Usually an inch or two at most. But with the cutting edge of the bucket pointed straight down it will lift the front off about 6 to 10 inches.
inspectorudy is offline
post #4 of 44 Old 07-10-2019, 11:45 PM Thread Starter
Shacker
papashelby's Avatar
Yes, he is going to do that, probably did it today. Didn't get home until 4:00 A.M. Thanks Russ.
Rudy, we tried that too, but still, at best, maybe an inch. And it struggles to get that high, very slow.
One thing I forgot to mention, as we repeat the up/down procedure, it will get the tires off the ground faster, but no higher.
2012 X728
48C deck
3 point hitch
54" blade
45 Loader
1997 345
48" deck
snow thrower
2 bag bagger
post #5 of 44 Old 07-10-2019, 11:52 PM
mrbeef's Avatar
Any idea what the loader was used for? Maybe it hasn't been shimmed and the relief valve installed? Along with a fluid change, test the pressure.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #6 of 44 Old 07-11-2019, 01:24 AM
Red Cap Club
nick4030's Avatar
This, along with the fluid change.
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is online now
post #7 of 44 Old 07-11-2019, 03:25 AM
Possible relief valve issue. Debris from a dirty hydraulic system could have gotten caught, possibly holding the valve slightly open. Did you try any tests in the other direction? Lift anything?
eKretz is offline
post #8 of 44 Old 07-11-2019, 06:34 AM
Nouveau Redneck's Avatar
Possibly leaking seals internal to one of the lift arm cylinders. When they start leaking they can leak worse in one direction than the other and as time goes on they eventually leak bad in both directions.
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #9 of 44 Old 07-11-2019, 08:08 AM Thread Starter
Shacker
papashelby's Avatar
According to the PO,just for hauling mulch. The bucket itself, was in excellent condition, not beat up. We will be pulling the fender pan to shim and will double check this relief valve and do a pressure check.
No, didnít think until after we left to have the PO try and lift us (not too far off the ground ).
Is there any way to check/know this is whatís happening? Maybe thatís why the right side cylinder has a high pitched squeal when itís maxed out in the up position.
Another thing I forgot to mention, is the tractor is a 2002, but unsure of the loader age.
Thanks guys for your insight and suggestions.
2012 X728
48C deck
3 point hitch
54" blade
45 Loader
1997 345
48" deck
snow thrower
2 bag bagger
post #10 of 44 Old 07-11-2019, 08:31 AM
20,000 Posts & Climbing
Test the pressure with an appropriate gauge first.
Relief valves squeal when they are dumping fluid at pressure.
TUDOR is online now
post #11 of 44 Old 07-12-2019, 06:25 PM Thread Starter
Shacker
papashelby's Avatar
Just an update of what we found today. Changed the hydraulic fluid and filter, but the bucket still operates the same ... won't lift the tires of the ground using the lift control, but ... , using the tilt it will lift with no problem, even at idle. The issue now seems to be with the lift cylinder/cylinders??? I put my pressure gauge on the gray connection (upper right, one of the lift connections) and we had 800 plus PSI (a little on the low side?). Should I have done all four? We also have a leak on that particular quick connect fitting which we think is the male side of the connection (my gauge did not leak), or the o'ring on the female side. Still getting the squeal from the right side tilt cylinder. We have not tried to lift anything at this point, need to fix the leak first.
2012 X728
48C deck
3 point hitch
54" blade
45 Loader
1997 345
48" deck
snow thrower
2 bag bagger
post #12 of 44 Old 07-12-2019, 07:13 PM
Check all four for sure. Problem could be a restriction in the line as well. Also could be a QC fitting that isn't working correctly. Lots of possibilities.
eKretz is offline
post #13 of 44 Old 07-12-2019, 07:18 PM
Three things to investigate.
1. Leverage of the cylinders acting against the ground. (Bucket cylinders have the advantage.)
2. Geometry - The angle that the cylinders apply force. (Bucket cylinders have the advantage.)
3. Hydraulics - Force = pressure X Area. (The bucket cylinders are pushing with the maximum piston area exposed to pressure, the arm cylinders are pulling with the lesser piston area exposed to pressure. Bucket cylinders have the advantage.)
Added to this is the sizes of the cylinders involved. The older aftermarket loaders had 2" bore cylinders. The newer loaders have 1.5" bore cylinders that have only a bit better than half the force at a given pressure for pushing, and slightly less than that for pulling.
Bottom line, the bucket curl cylinders can apply more pressure to the ground than the lifting arm cylinders before the relief pops.
TUDOR is online now
post #14 of 44 Old 07-12-2019, 08:26 PM
mrbeef's Avatar
At 800 psi there is no chance that machine would ever lift the front end. If the relief valve is not install, install and shim to at least 1,250.
Is the squeal from simple lack of use and grease?
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #15 of 44 Old 07-12-2019, 09:18 PM
My 595 was able to lift the front end at 900 psi stock. Pretty sure it's heavier than a 585. Anyway, the 45 loader uses 1.75" bore cylinders and a 1.13" rod diameter. By my back of the napkin calculation that's about 1.40 in≤ on the retracting piston surface, so at 800 psi that's over 1,100 pounds of force on each cylinder. Should be able to lift it even though it's around a 2:1 reduction at the bucket.
And there's no need to install a relief valve?! They come that way from the factory. You must be thinking about the THRV - but that has nothing at all to do with implement relief, only the hydro (transaxle) relief.
eKretz is offline
