X540 Jerks to a stop in Reverse - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 07-10-2019, 02:59 PM Thread Starter
TundraBoy's Avatar
I have an X540 that 'jerks' to a abrupt stop when you release the direction peddle at even a relatively slow speed. You can slowly release the foot peddle and it stops gently. I am not experiencing a similar action in forward direction although it too might be more abrupt than normal. The machine is 2010 with about 570 hours on it. Nothing seems amiss with the linkages. I notice a shock absorber connected to the linkages. Might this be an issue?
Interested in your thoughts.
Cheers, Ken
Cheers
TundraBoy is offline
post #2 of 8 Old 07-10-2019, 06:47 PM
Re: X540 Jerks to a stop in Reverse
Most likely the shock. Its purpose is to slow the return of the pedals to the neutral position to prevent the transxle from thrashing and jerking to a stop.
I would suggest looking for the JD part number and doing a quick search on this site to see if someone has posted the OEM or an aftermarket part. The shocks are "shockingly" expensive from deere.
denverguy is offline
post #3 of 8 Old 07-10-2019, 08:18 PM
Father Deerest
Denver guy is correct, without the shock it would be the equivalent to slamming your car in park every time you wanted to stop.
Father Deerest is online now
post #4 of 8 Old 07-10-2019, 09:34 PM
oldgibsonguy's Avatar
+100 on the above. Buy a new shock and throw the old one away.
John Deere X738 4wd
48" mower deck
oldgibsonguy is offline
post #5 of 8 Old 07-11-2019, 09:02 AM
This one worked perfectly and fixed the exact problem your having in my x540
https://www.ebay.com/itm/192904430311
greenbean4606 is offline
post #6 of 8 Old 07-11-2019, 10:22 AM Thread Starter
TundraBoy's Avatar
Thanks guys. Guess my suspicion of the damper is looking to be correct. I appreciate the tips on the eBay option. Unfortunately he does not ship to Canada so off John Deere for the expensive option at ~$200 CDN!!!
Cheers, Ken
Cheers
post #7 of 8 Old 07-11-2019, 05:54 PM
Cheers, Ken
Might be worth checking with Tufftorq, not sure what their parts network looks like in Canada but prices seem to be about 25% cheaper buying direct in the US then from Deere.
post #8 of 8 Old 07-11-2019, 07:25 PM
Collector of many tractors
Kbeitz's Avatar
You need a new dash pot....
Kbeitz is offline
