2wd 400 with snowblower on incline - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 07-10-2019, 02:51 PM Thread Starter
I have a 2wd 400 and I acquired a snow blower for it. I have wheel weights, suitcase weights, and tire chains. my drive way has a slope to it. The drive way is not steep, but there is a pitch to it. How can I realistically expect the tractor to perform?
randynh1979 is offline
post #2 of 9 Old 07-10-2019, 03:21 PM
Still lovin' the 322!
PA318Guy's Avatar
Re: 2wd 400 with snowblower on incline
With sufficient weight and chains on turf tires you shouldn't have too much of an issue. If you do, blow a downhill path then come back up the path and do all the clearing when going downhill. Sometime technique is really all that you need, especially if you don't have 4/awd or a differential lock.
Current Machine JD 322
PA318Guy is offline
post #3 of 9 Old 07-10-2019, 04:29 PM
Parts collector
mopar65pa's Avatar
X2 on that! I go down hill, than take a 1/4 to 1/2 cut on the way back up.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #4 of 9 Old 07-10-2019, 04:36 PM
A small slope should not be an issue with weights and chains. My neighbor has a blower on a 345 and only has chains on the turfs (no extra weights at all) and has used it that way for 10 years. Granted his driveway is pretty flat, but the added weights should compensate for that.
One trick I have found on mine, with just a 54" 4 way blade, is to lower the blade or blower down on float and it sometimes gives you better traction. This is because with the blower raised up you are adding weight to the front undriven wheels and unloading the back drive wheels. This winter when plowing my neighbors drive with a mild slope and with a coating of ice under the snow, when trying to get moving uphill with the blade up it would sit there and spin but as soon as I dropped the blade down on the ground it would regain traction and start moving.
6.2Blazer is offline
post #5 of 9 Old 07-10-2019, 07:22 PM Thread Starter
Good great to hear!
post #6 of 9 Old 07-10-2019, 07:28 PM
badgerland01's Avatar
The 400 is a tank. You shouldn't have too much trouble pushing a snow blower. I think you have split brakes on that machine. When one wheel starts to spin, slightly apply the brake on the spinning wheel which will force the other wheel to turn, hopefully resulting in forward progress.
X749 "H-3 EDITION"
GX345
badgerland01 is offline
post #7 of 9 Old 07-10-2019, 07:58 PM
Red Plaid is Timeless
grandpajay's Avatar
The only issue you may have is backing uphill with the thrower raised. The solution is more weight or, like 6.2Blazer suggests, float the thrower to keep the rear end down. The snow thrower doesn't really like to go around corners, so that is an occasion to differential brake to help steering.
1981 JD 400 K582. 60 deck, SSQA 50 snowblower, suspension seat, left side brakes, 2 pedal foot control, H5 with separate deck lift and 3PH. Home made 3PH, mini SSQA loader, landplane, 10 weight capacity hitch, stacking starter weights, fender extensions, LED lighting.
grandpajay is offline
post #8 of 9 Old 07-10-2019, 08:32 PM Thread Starter
grandpajay- Your setup looks very similar to mine! I even have the cozy cab!
post #9 of 9 Old 07-10-2019, 09:30 PM
oldgibsonguy's Avatar
Randy,
I live down the street from NH just outside of Boston. My drive is very long, very wide, and very up hill. Sometimes in both directions, or so it seems. I don't have a blower and use my 580 with a 48" blade. The rear sports HDAPs and Terra Grips. I can't picture you having any problems with your machine and a blower, up or down, as long as you use chains and have plenty of weight on the rear.
ID:	2386057   Click image for larger version
ID:	2386059   Click image for larger version
ID:	2386061   Click image for larger version
John Deere X738 4wd
48" mower deck
oldgibsonguy is offline
