JD 47 snowblower models - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 07-09-2019, 05:30 PM Thread Starter
Kabetogapapa's Avatar
Hi, does anyone know the difference between these 2 older models of JD 47 snow blowers and their compatibility?
MO2752x (mine has a quick hitch that terminates in a pulley for an electric PTO and is on my 318)
MO2753x (I can't find any information on this model but it came off of a 420 and terminates with a coupler for front PTO)
Thanks.
1987 JD 318
47" snowblower
50" mower
heated Cozy cab
"Buford Bucket" loader
Custom weight box
Kabetogapapa is offline
post #2 of 5 Old 07-09-2019, 07:39 PM
Re: JD 47 snowblower models
The only 47s for a 318 that I have seen have a pulley that is driven with a belt from the electric clutch on the onan engine. Would it be possible that someone removed that driven sheave and added another electric clutch and then put a standard pulley on the engine?
Junky is offline
post #3 of 5 Old 07-09-2019, 08:30 PM
Kish JD 318/420/430
RussKish's Avatar
You are also talking completely different mounts due to the front frame widths between the 3XX, and the 420/430 series. Plus the 47 went on to be mounted on some SCUTs (4000 series) also, again using different mounting frame and PTO adaptions.
Russ
Proud Owner of: 318/420/430
RussKish is offline
post #4 of 5 Old 07-09-2019, 10:01 PM
MO2752x (mine has a quick hitch that terminates in a pulley for an electric PTO on my 318)
MO2753x (I can't find any information on this model but it came off of a 420 and terminates with a coupler for front PTO) Thanks.
First generation Fridge style
47" blowers with VIN M02752x fit the 318, 322 and 332 pre-Quick-Tatch pulley drive
47" blowers with VIN M02753x fit the 420 and 430 garden tractors pre-Quick-Tatch shaft drive
47" blowers with VIN M01470X, M01471X or M047SBX fit the 318,322,332,420,430,425,445,455 Tractors And F900 Series Front Mowers With Quick-Tatch.
-- Those with M01471X also fit the 4100 CUT With Quick-Tatch
-- Those with M047SBX also fit the 2210, 4010, 4100, 4110, 4115, 2305, 2320, 2520, 1023E, 1026R, 1025R, 2025R, 2032R, 2720 Compact Utility Tractors With Quick-Tatch
47" blowers with VIN M01080X or M01081X fit the F910, F911, F912, F915, F930, F932, F935 And F1145 Front Mowers.
47" blowers with VIN M02790X fit the 655, 755 and 855 CUTs.
File Type: pdf 300.series.snowblowers.compatibility.pdf (11.4 KB, 18 views)
File Type: pdf 400-X595_John_Deere.Snowblower.Interchangeability.pdf (11.3 KB, 18 views)
File Type: pdf 47-2-Stage.Snow.Blower.Model.Serial.Number.pdf (233.1 KB, 22 views)
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is offline
post #5 of 5 Old 07-10-2019, 09:57 AM Thread Starter
Thanks everyone for the replies and the great information! I don't think either of the blowers or quick-hitch units were modified.
1987 JD 318
47" snowblower
50" mower
heated Cozy cab
Custom weight box
