Refurb of 54" Blade - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 06-28-2019, 10:39 PM Thread Starter
MISparty's Avatar
Refurb of 54" Blade
So I got a great deal on a quick hitch and 54" blade, however, the blade appears to be in rough shape.
It looks like it'll need the cutting edge replaced, along with the side skids and possible some pins.
Has anyone documented a refurb on this before? (sorry - I couldn't find one).
Also - does anyone have a parts list? I'd like to get this ready for winter.
Thanks!
JD 445 ~2001 w/ 47 blower and 60" deck. Ruegg Cat1 3pt Hitch
1200hrs
JD 455 ~1998 w/ Rear PTO and 60" deck. JD 3pt Hitch
1600hrs
MISparty is online now
post #2 of 8 Old 06-29-2019, 01:50 AM
Re: Refurb of 54" Blade
Here is a link to a site Ive used for years.
For the blade: https://www.green-parts-direct.com/j...-174708-128580
You can navigate from this page for other parts.
They are all genuine Deere and less than a dealer charges.
I would also suggest ebay.
There is a seller in Ohio who specializes in replicating alot of blade parts.
I met him at the tri-state tractor show last summer.
Look him up.
Wlmitty is offline
post #3 of 8 Old 06-29-2019, 09:19 AM
I use this for the cutting edge: https://heavyhitch.com/product/heavy...54-inch-blade/
kbit is offline
post #4 of 8 Old 06-29-2019, 09:48 AM Thread Starter
MISparty's Avatar
Originally Posted by kbit View Post
Thank you both!
WLMITTY - thanks for the diagram. Is there any other info out there on the pins and frame behind the blade?
1200hrs
1600hrs
post #5 of 8 Old 06-29-2019, 10:20 PM Thread Starter
MISparty's Avatar
OK - so a little more info and a fun mess in front of me it looks like
As a back story, I bought this blade only for the quick-hitch. The price I paid was cheaper than a hitch from other sellers.
The only purpose I had for the blade was for dirt and debris. I wasn't planning on using it on snow, so it really didn't matter what shape it was in.
So..I've used it a couple of times, and was happy with what I was using it for. I am now selling my 445 and see the opportunity for more customers by including a blade in on the deal as I live in Michigan.
With that being said, I finally looked the blade over closer this afternoon.
This looks like fun....
Is it just me, of did the previous owner weld the cutting edge to the blade? :
They also obviously used it in a manner where they shaved the nuts down on the bottom side. If I was going to even mess with this, I'd have to torch or crack the nuts off.
Or should I just be happy with the fact that I pretty much for a free dirt blade out of the deal?
ID:	2384011   Click image for larger version
1200hrs
1600hrs
post #6 of 8 Old 06-29-2019, 10:26 PM
I just flipped the blade on my Cub over, the nuts were worn, so I replaced the carriage bolts and the nuts.
Gary R C is offline
post #7 of 8 Old 06-29-2019, 10:41 PM Thread Starter
MISparty's Avatar
It's my first dealing with this type of equipment.
I would be replacing the cutting edge and the hardware. I'm just not sure if he welded it or not.
I'll be working on it for the next couple of days
1200hrs
1600hrs
post #8 of 8 Old 06-29-2019, 11:10 PM
Kish JD 318/420/430
RussKish's Avatar
A inspection after removing the edge and bolts will tell you a lot more. But if a new piece needs to be added hopefully you have a wire welder/gas to do the work or a friend that way the cost down rather that take it to a weld shop but that will be your call. I have found the my local metal supplier can do an excellent job on some of my projects.
Russ
Proud Owner of: 318/420/430
RussKish is online now
