LA 165 PTO wiring connectors - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 06-27-2019, 05:40 PM Thread Starter
We had a mishap recently and the tractor caught fire. After putting it out, the tractor starts but using PTO shorts battery. Found that wires burned and I now need the connectors to the PTO and could use the connector to the rear wiring harness. Does anybody have some ideas where I can find these parts reasonably? JD dealer wants to sell me a new harness at $128. Not cost effective for an 11 year old tractor.
pjrobbins49 is offline
post #2 of 10 Old 06-28-2019, 09:27 AM
Cannon51's Avatar
Re: LA 165 PTO wiring connectors
I'm not sure what your connector looks like but would this work?
https://www.rotarycorp.com/product/12923
Cannon
Cannon51 is online now
post #3 of 10 Old 06-28-2019, 09:52 AM
greenmachine's Avatar
Is this the harness you need? If so, your dealer is really trying to stick it to you on price.
https://www.greenpartstore.com/John-...s-GY21127.html
Not knowing what the fire damaged in terms of wiring, replacing this complete harness might be the best way to do the job once and then forget about it.
2017 John Deere X394
2007 John Deere LA140 / 48" Bagger
2007 John Deere 10P Utility Cart
greenmachine is online now
post #4 of 10 Old 06-28-2019, 12:20 PM
JoeZeppy's Avatar
Hi pj - glad you're (almost) back in working order. Sounds like you and I have the same set up. I'm at about 430 hours right now. If you don't mind me asking, what happened? Was it a freak incident or is there something I should be careful of to prevent something like this from happening?
2008 John Deere LA165: 24hp, 48" deck, 44" snowblower
1994 MTD 8hp/26" snowblower
Rubbermaid/Craftsman poly dump cart
K-mart 22" push mower
2010 GMC Sierra 2500HD
2014 Subaru Legacy Sport
JoeZeppy is offline
post #5 of 10 Old 06-28-2019, 02:14 PM
If you just need the wiring connector housing (plastic part) for the PTO, tractor side of the harness, it's P/N T28586
You did not say what rear connector you needed.
Zebra5 is online now
post #6 of 10 Old 06-28-2019, 02:49 PM
Insulated connectors are available at box stores (Home Depot, Lowe's) and automotive supply stores (Advance, O'Reilly's). I will also suggest/RECOMMEND a wire with heat resistant insulation for use where the wire passes near/by the engine. Most appliance repair stores carry this as "stove wiring"...silicon insulation. Bob
rwmeyer is offline
post #7 of 10 Old 07-15-2019, 04:25 PM
I would like to find the connectors that go into empty plastic housing connector T28586. Its a female connector housing. I have the male end on new pto asm. Easy to get the female T28586 but its empty. I may be able to get housing and small spade connectors than wire them in.
raisin1 is offline
post #8 of 10 Old 07-15-2019, 11:51 PM
T28586 is a Dephi 56 series connector. So you need MALE 56 series terminals. They will be sized by the cross sectional area of the wire that they will accept.
Delphi is now Aptiv.
Try searching for Aptiv P/N 02962958
post #9 of 10 Old 07-16-2019, 06:34 PM
Very good info, thanks. Found contacts on industrial websites nothing on amazon or e-bay. I had already ordered T28586 and a six position connector and will use the male spades from it.
raisin1 is offline
post #10 of 10 Old 07-16-2019, 06:54 PM
I buy connecters and parts from www.mouser.com
