455 Transaxle Temperature - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 18 Old 06-09-2019, 08:45 AM Thread Starter
BradMiller's Avatar
Good morning fellow John Deere fans!
I have had my 455 for a few weeks now, after a lot of cleaning and fluid changes I got to get some seat time yesterday.
My task yesterday was pulling a large lawn roller, the roller weighed about 1200 pounds and rolled pretty easy. I did not feel like the tractor had any trouble with it.
After pulling it for an hour or so I noticed the transaxle had a little more of whining noise, nothing obnoxious or noticeable by anyone else. I got off the tractor and felt the transaxle, geez it was hot. It would not burn your hand but you would not leave your finger on it long at all a few seconds at best.
Is that normal?
How hot does your transaxle get when you are working your 4xx....
I looked at the hydro plumbing schematic and wondered if anyone had ever plumbed in an additional hydro cooler?
Thank you for any insight you can provide.
Brad
Brad Miller
Oneida, NY
BradMiller is offline
post #2 of 18 Old 06-09-2019, 11:04 AM
Re: 455 Transaxle Temperature
My advice is get a laser temp gun and find out how hot is really is. I'll bet it's ok since it is cooled by the radiator fluid. Hyd fluid doesn't like to be over 180-90deg which is about the lower temp in the radiator but that feels hot to a human!
antiqueetc is offline
post #3 of 18 Old 06-09-2019, 11:08 AM Thread Starter
BradMiller's Avatar
Good point! I have a temp gun and have no idea why I didn’t shoot it.
I will get out and ride around a while to see what I get. Thanks!
Brad Miller
Oneida, NY
post #4 of 18 Old 06-09-2019, 02:08 PM Thread Starter
BradMiller's Avatar
Hi guys, so I pulled the roller around for about an hour again, the rear cover was 189 - 196 degrees.......
Given this is right around the radiator water temperature the temp is ok? What do you think?
Has anyone else ever checked your transaxle temps after working the tractor?
Brad Miller
Oneida, NY
post #5 of 18 Old 06-10-2019, 05:18 AM
20,000 Posts & Climbing
You're at the limit for max operating temperature. For hydros, and hydraulic systems in general, normal recommended max operating temp is 180°. Max temp is 192-195°. Above this temp, the fluid begins to lose its ability to transmit power due to reduced viscosity. At 225°, the fluid begins to carbonize (burn) and the carbon particles cause accelerated wear. This is where the killer for the much maligned K46 resides.
Periodic 'rest' times are indicated to keep the temperature under control for that particular task. A 'rest' of a few minutes at high idle with the drive in neutral should lower the temp to a safer level if it gets any higher.
Ensure that your radiator fins are clear and the fan is in good condition for maximum cooling. There may be debris build-up in the fins or the rad prescreen inhibiting air flow. My understanding from previous threads is that the normal fluid temperature is about 177° +/- for the liquid cooled tractors with an oil cooler in the rad. Work that is harder will, of course, raise the temperature of the coolant with a corresponding rise of the hydro fluid temperature. If the hydro is at 196°, you can be assured that the engine temperature is even higher.
Keep in mind that only the fluid from the 4.6 gpm auxiliary pump goes through the cooler. The hydro pump recirculates up to 3 times as much fluid and that is where most of the heat is made. High hydro pressure is what develops heat in quantity.
WOT will help keep the temperature in check with sustained heavy load work. That delivers max flow from the auxiliary pump to the oil cooler, and max engine coolant and air flow to the rad.
TUDOR is offline
post #6 of 18 Old 06-10-2019, 09:30 AM
mrbeef's Avatar
I agree with Bob, that seems a little warm. I'll try and grab some data tonight off my 455. Couple questions:
What fluid did you use?
What was the ambient temp?
Where did you measure the temps?
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #7 of 18 Old 06-10-2019, 09:54 AM Thread Starter
BradMiller's Avatar
I am starting to question my cheap thermal gun, the engine runs nice and cool and the radiator is whistle clean.
I am going to bring home a better Fluke thermal gun from work to take these readings again.
I used JD Hy- Gard and JD #AM116156 Filter
Ambient temp was 78 and the engine temp was on the cool side.
I marked a picture to show you where I shot the temps.
If the weather holds out I will do this test again soon and post new numbers.
Do you have any recommendation on where to check the temps?
Thanks Guys!
Brad Miller
Oneida, NY
post #8 of 18 Old 06-10-2019, 10:17 AM
Enginerd - DieselDork
moondawg's Avatar
There are a few other things you should check:
1. Coolant temperature and level. Since (as someone else pointed out) the transaxle is cooled by the radiator, transaxle temps are going to get pretty close to coolant temps. Make sure you aren't also overheating your engine due to low fluid levels and/or defective radiator cap or thermostat.
2. Double-check this measurement with your coolant temp gauge. These gauges are notorious for getting "sticky" in the older clusters. If your coolant temperature gauge doesn't return to "low" when you key off, this may be a sign that the gauge is sticky.
3. Hydro fluid level. Make sure you've got plenty of "mass" in the system... a full transaxle reservoir will take longer to heat up than an "empty" one.
4. Hydro fluid filter. If it's not flowing well, fluid can't get through the system as quickly and your cooling will be affected.
Ryan
1996 455 AWS - 54" Deck - 54" Blade - Quick Hitch
moondawg is online now
post #9 of 18 Old 06-10-2019, 12:49 PM
I'd check the temp at the radiator top tank, bottom tank and fluid return line to the transaxle. That will tell you the engine operating temp(top tank), radiator temp drop(bottom tank) and the temp of the fluid being returned to the transaxle. compare those readings to the rear cover temps you take. Also check the filter temp, as that is the temp of the fluid being returned to the reservoir.
post #10 of 18 Old 06-10-2019, 10:34 PM
On a hydro, the filter is on the supply side. The filter temperature reading will be the temperature of the fluid entering the hydro.
That is the one that counts. Ideally, it should be lower than 180°.
TUDOR is offline
post #11 of 18 Old 06-11-2019, 01:19 AM
mrbeef's Avatar
Here is a little info from my 455.... took the liberty of borrowing a FLIR Camera from work (with permission of course). Ambient temp was about 65. Keep in mind the scale is not constant across the images.
Before mowing....
After about 3 minutes of run time.
After about 7 mins of mowing the front ditch.
Peak temp after mowing for ~25 minutes. I took the temp gun and got a few readings in the 175 range but most all were in the low to mid 160's.
I'll try to get some better pictures this weekend. I was running out of light (the camera also takes a light image with the thermal image) and the camera emissivity settings were not 100% correct for aluminum.
EDIT*** Forgot this image. Radiator was about 150F after mowing.
For those of you that wonder about spindle temps... these are freshly rebuilt spindles with less than 10 hours on them.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #12 of 18 Old 06-11-2019, 01:28 AM
mrbeef's Avatar
Thanks Guys!
Low Vis Hygard is the preferred fluid from Deere.... Granted lots of folks run other oils in the K series transaxles just fine... But I am wondering if the Hygard is a little too thick compared to LV Hygard and other recommended oils.... I would have to dig around for the ISO rating of other oils.
The machine looks nice and clean but is the top of the hydro clean as well? Build up of oil and grime can cause heat retention.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
post #13 of 18 Old 06-11-2019, 08:24 AM Thread Starter
BradMiller's Avatar
MrBeef
Very nice thermal pictures, I had to laugh at the fact you beat me to the punch. I have a Flir camera sitting on my desk and didn’t take it home yesterday because of the rain. I will take it today so I can compare our pictures and temps.
I will try to keep my pictures in the same time frames so we have an accurate comparison.
I will get as many shots from various angles as I can.
This forum community is so amazing, no have cocked answers here. People are lazy and rarely put any effort into helping someone, this group is a breath of fresh air! I am glad I picked up this 455 a few weeks ago, I would of never found this site!
Thanks again!
Brad
Brad Miller
Oneida, NY
post #14 of 18 Old 06-12-2019, 11:52 AM
e
You're right of course. I intended to type 'from the reseroir'.
post #15 of 18 Old 06-12-2019, 07:13 PM Thread Starter
BradMiller's Avatar
Well I think I can throw away my cheap temp gun, I started a thread for no reason.....
I pulled the same very heavy roller again today that I thought got my transaxle too hot. I pulled it for 30 minutes fast and without stopping. I was about 3/4 throttle right in the sweet smooth spot. This thing is clearly not even being worked hard, I am very happy with how strong and willing it is.
These pictures were taken immediately after I stopped. The temps seem to be perfect!
Thank you for all the help with my question.
ID:	2381529   Click image for larger version
ID:	2381531   Click image for larger version
ID:	2381533   Click image for larger version
ID:	2381537   Click image for larger version
Brad Miller
Oneida, NY
Maynard
