JD 210 quit wont restart - Page 5 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #61 of 95 Old 06-13-2019, 03:47 PM Thread Starter
Re: JD 210 quit wont restart
Yes, the wires at the back of the dash that connect to the ignition plug go into a plastic shroud. there are 5 blade connectors inside. I just ordered a new ignition key for the tractor so that will rule that out - or should.
mackendw is offline
post #62 of 95 Old 06-19-2019, 11:32 AM Thread Starter
parts on order (coil, points, & condensor + ignition key).
mackendw is offline
post #63 of 95 Old 06-19-2019, 11:59 AM
OLD TIRED CDN. MECHANIC
Larry LGT 165's Avatar
Keep in mind those inaccessable connections inside that harness plug on the key switch can cause more trouble than the switch itself. Did any of the sellers offer a new multiplug with the switch that you could splice into your existing harness?
Larry ( in Southern Ontario )
Larry LGT 165 is online now
post #64 of 95 Old 06-19-2019, 02:41 PM
You shouldn't see more the 3 or 4 ohms resistance across the + and - terminals on the coil. (no wiring connected please.) Secondary resistance is within spec.
HeyYou is offline
post #65 of 95 Old 06-19-2019, 02:48 PM
garden tractor junkie
Nathan Bottjer's Avatar
I would check the key switch i had a guy a while back said he had spark but it seemed week and he thought he had a coil issue. his would run then just die and not fire. So i told his to jiggle the key switch and see what happens. he got it to fire again and he jiggled the key switch and she coughed and sputtered. he ended up giving me back the coil i told he probably didnt need and bought a new key switch. problem was solved!
garden tractor hoarder!
Nathan Bottjer is offline
post #66 of 95 Old 06-21-2019, 09:19 AM Thread Starter
I'll replace that first then for a test to rule out whether it's that, the coil or the points.
mackendw is offline
post #67 of 95 Old 06-21-2019, 09:23 AM Thread Starter
you mean replacing the other half of the plug that has the 5 flat blades? Nope, nobody offered it up. I think the switch may be what is going on as it would not turn over for a bit after it quit mowing the lawn. I had to play with it for around 10 minutes to get it to turn over again. I was moving the shift lever around for a bit thinking it was the neutral switch.
mackendw is offline
post #68 of 95 Old 07-08-2019, 02:11 PM Thread Starter
Hi:
I installed the new ignition switch, coil + condensor, new plug wire and points. Points set at 20 thousands. Still no fire. Guy I'm working on this with said try running a wire from the + battery terminal to the + post on the coil and turn it over. Started first click. So, does that mean I have a bad regulator? or.....what?
Suggestions??
mackendw is offline
post #69 of 95 Old 07-08-2019, 02:34 PM
Trying2mow's Avatar
Is it possible that you have installed a poor coil?
Trying2mow is offline
post #70 of 95 Old 07-08-2019, 02:35 PM Thread Starter
New parts from isavetractors.com. who knows...
mackendw is offline
post #71 of 95 Old 07-08-2019, 02:54 PM
Hi:
Suggestions??
It means you don't have power to the coil + thru normal routing.
Use a test light... check for power into the ign switch, power out of the ign switch, and follow it all the way to the coil. Maybe a safety neutral switch, or pto / blades engaged.
post #72 of 95 Old 07-08-2019, 03:18 PM Thread Starter
do you have to open up the wire (ie: break the surrounding shield) to probe each wire in the bundle that connects to the 5 flat blade connectors?
mackendw is offline
post #73 of 95 Old 07-08-2019, 03:35 PM
Turn key "On" and check got voltage at + terminal at coil.
rwmeyer is offline
post #74 of 95 Old 07-08-2019, 04:38 PM
No, preferrably don't puncture the wires, stick the probe into the multi plug on the key switch, where the wires come out, until you touch the metal terminal. Do the same at each connection/terminal, verifying power at each point, until you get to the coil.
Although it has happened, wires rarely fail in the middle. It's always the connections at the ends.
post #75 of 95 Old 07-08-2019, 04:49 PM
Do you still have power while cranking?
HeyYou is offline
