2007 X724 54” Deck PowerFlow Compatibility to 2017 X730 62” Deck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 05-23-2019, 03:48 PM Thread Starter
RT3360's Avatar
Ran across a deal on a 2007 John Deere X724 with an MC519 and PowerFlow on the 54” deck. I was thinking of using the PowerFlow and MC519 on my son’s 2017 X730 62” deck, but the local dealer (salesman) said it wouldn’t fit the newer 62” deck. Anybody know that it will Fitzroy how much would take to use it?
Thanks in advance.
Craftsman DLT2000, 48”
Ariens ST824 snowblower
RT3360 is online now
post #2 of 4 Old 05-23-2019, 10:37 PM
TJR345's Avatar
Re: 2007 X724 54” Deck PowerFlow Compatibility to 2017 X730 62” Deck
54 and 62 are 2 different.
Tom
2002 X595 with 62" deck and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
98 345 with 54" deck and powerflow
30" tiller,JD 18 cart, Front thatcher
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer,175lb tow spreader
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
TJR345 is offline
post #3 of 4 Old 05-24-2019, 05:25 PM
burned300's Avatar
Wasn’t 2012 last year of 62” deck on x series? The 2013 and newer x’s biggest deck is 60”
Sent from my iPhone using Tapatalk Pro
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #4 of 4 Old 05-24-2019, 06:18 PM Thread Starter
RT3360's Avatar
burned300 - You are correct. It is a 60” instead of a 62”. I’m assuming the dealer is probably correct and I can’t use the same PowerFlow on both. Kind of messes up my plan though. I don’t need the MC519 or PowerFlow, but thought if it would fit my son’s tractor, then the X724 might make a good tractor option for use elsewhere.
