GX345 Traction belt replaced do I need the pulley and fan too? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 05-20-2019, 10:49 PM Thread Starter
Thank You MTF
There is a little wobble in these, think I need to replace them?
https://photos.app.goo.gl/BVNhDZLEPupb5Sdu6
GX345ISMYTRACTOR is online now
post #2 of 9 Old 05-20-2019, 11:03 PM Thread Starter
Thank You MTF
Re: GX345 Traction belt replaced do I need the pulley and fan too?
Here is a youtube video if that helps.
post #3 of 9 Old 05-20-2019, 11:23 PM
Yes, you need new ones.
rayjay is offline
post #4 of 9 Old 05-20-2019, 11:26 PM Thread Starter
Thank You MTF
Ok thanks. I was thinking I could tighten the nit and they would be fine.
post #5 of 9 Old 05-20-2019, 11:27 PM
There should be basically zero play between the pulley and the shaft. If you look at the splines in the pulley they are probably very sharp due to wear. The nut was probably loose.
rayjay is offline
post #6 of 9 Old 05-20-2019, 11:38 PM Thread Starter
Thank You MTF
You are correct they are sharp and it was loose. I'll buy a new one and install a new lock nut while at it. Does blue loctite help at all? Probably loose from the vibrations caused by the belt going bad.
Thanks for the reply.
post #7 of 9 Old 05-21-2019, 07:38 AM
You don't need Loctite.
rayjay is offline
post #8 of 9 Old 05-21-2019, 07:51 AM Thread Starter
Thank You MTF
Ok - Thanks!
Sent from my Pixel 2 using Tapatalk
post #9 of 9 Old 05-23-2019, 10:54 PM Thread Starter
Thank You MTF
Got the drive belt replaced thanks to all that provided advice. She seems to be awesome again!
Overheating beefarmer Ford/New Holland Tractors 41 04-25-2019 01:22 PM
B7100 fan belt change Murrelet Kubota 2 02-16-2019 09:24 PM
JD 155c, K46be transaxle upgrade to K66Y Supra98nc John Deere Forum 25 02-02-2019 11:48 PM
Craftsman Rider 917-258910 Motion Drive Belt jl66redcpe Craftsman/Sears Forum 17 11-19-2018 02:39 PM
9n replaced fan belt wilcoy02 Ford N's 9N/2N/8N 11 11-08-2015 09:50 AM
