Hydrostatic control lever - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 05-20-2019, 01:56 PM Thread Starter
Hello Guys,
I looked on the forum for this but no luck.
My HYDROSTATIC CONTROL LEVER will only go 3/4 the way to full. I don't have the speed like other 332's. Is there a linkage or adjustment I have to adjust? Are there any instructions on this?
thank you
Orv1988332 is offline
post #2 of 5 Old 05-20-2019, 07:41 PM
Re: Hydrostatic control lever
Sent PM
D MACHINE WILL NOT REACH FULL SPEED
Inspect transmission control linkage for wear or damage. See Section 50.
Inspect transmission and differential mounting cap screws for loose condition.
Check engine fast idle speed: See Section 220.
Inspect check valves for damaged seat, seals or stuck check ball. See Section 50.
Inspect internal rotating group for scoring and wear (slippers, pistons and cylinder block, valve plate and
cylinder block). If internal damage is found check for missing welch plug: GO TO
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is offline
post #3 of 5 Old 05-20-2019, 10:35 PM
inspectorudy's Avatar
Good luck with the manual procedures. I had the exact same problem on a 430 and was told to go through the exact same steps. No help. Then I noticed another hole in the control arm that rotates the shaft going into the tranny. I put the long rod from the hydro lever into the lower hole and not only got all the speed, but I also got even more than I had originally. I did have to readjust the turnbuckle on the rod to balance out reverse and forward but it wasn't that much trouble. I had the factory service manual for the 430 which is the same tranny as the 318/322/332 and it was a long horrible procedure that required taking the whole thing apart and inspecting for wear and slop. It would actually be easier to buy a used tranny than comply with their steps.
inspectorudy is online now
post #4 of 5 Old 05-21-2019, 07:00 PM Thread Starter
Now I do remember I did adjust for Creep about a year and a half ago, Maybe I adjusted the wrong thing.....
post #5 of 5 Old 05-21-2019, 07:01 PM Thread Starter
BTW - Thank you all
1978 Power King Adventure HavinFun Power King & Economy Tractors 27 04-26-2019 01:13 PM
PTO Control Arm Lever Jack/modelA1 Gravely 1 01-09-2019 11:07 AM
Hydraulic Control Lever deckerjs57 Ford N's 9N/2N/8N 4 01-02-2019 11:58 PM
Lack of Forward Speed ssmewing Case_Ingersoll_Colt Forum 3 08-28-2018 11:21 AM
hydrostatic control lever system garybflo Simplicity/Allis Chalmers Forum 2 01-14-2013 11:20 AM
