X590 users - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 05-19-2019, 03:14 PM Thread Starter
TJR345's Avatar
X590 users
Looking at a 2018 or 19 X590 and was wondering how you like it and if anyone has the 30" tiller for it. I'm looking to replace my 345.
Tom
2002 X595 with 62" deck front thatcher and Ruegg 3pt hitch
45 John Deere loader
Cat 1 3 pt plow and Heavy Hitch
62"powerflow
2019 X590 with 54" deck,power mulch kit and powerflow
30" tiller,JD 18 cart
JD 40" spike aerator
12 suitcase weights
JD T105 trimmer
15 gal. tow sprayer,175lb tow spreader
(2) JD JS63C walk-behind mowers
Turftime 60" roller
Turftime 54" 3pt core aerator
TJR345 is offline
post #2 of 14 Old 05-19-2019, 04:12 PM
hillwood's Avatar
Have you considered a 7 series? It would be better suited for a tiller. Just suggesting, I don't know your situation.
hillwood is offline
post #3 of 14 Old 05-19-2019, 05:01 PM
Alberta Al's Avatar
Re: X590 users
I'm going to pipe in since the X540 is similar to the X590 in many ways. I have the 42" hydraulic tiller. Not sure why you'd want to go with a mechanically driven tiller, which is quite a bit smaller, when your tractor is designed to use a larger 42" hydraulic tiller. The 42" width makes sure there's no tracks left behind by the tractor's tires. Here's the tiller in action with my X540. This is from last Spring. It looks a bit messy since I had a ton of leaves I wanted to till into the soil.
Btw, I'm purposefully going slowly to till the soil more finely. It can go much faster, as I've seen others do in their videos, but I don't recommend it.
  • 2013 John Deere X540 with 54X Edge Xtra Deck
  • 47 in. Snow Blower, 42 in. Hydraulic Tiller, Integral Power Sleeve Hitch
  • Brinly Box Scraper, Brinly 40 in. Plug Aerator
  • 3 bag power flow bagger, 10P Utility Cart
  • LP36741 weather enclosure
  • 4 - Quik-Tatch Weights (42 lbs)
  • Tire chains
  • 928E Walk-behind JD Snowblower
Alberta Al is offline
post #4 of 14 Old 05-19-2019, 07:37 PM
UpstateTony's Avatar
Re: X590 users
TJR345 already has a beautiful X595 for his heavy duty Garden tractor. His 345 is getting a bit "long in the tooth" And he is looking to replace its with a X590 to complete the rare X590/595 clean sweep As for 30 inch tiller looks like TJR already owns one he used with 345
As for X590-- going into my 4th year and its been flawless- starts with flick of the key-- the 2 stage 47 inch snowblower is a beast, and like the tractor itself, not a hint of trouble with snowblower -- easily throwing snow 30 feet or more. Honestly I couldn't be happier with my combination of tractor and blower
2012 John Deere X310
2009 John Deere LA-135 SE
UpstateTony is offline
post #5 of 14 Old 05-19-2019, 08:37 PM Thread Starter
TJR345's Avatar
Re: X590 users
https://www.youtube.com/watch?v=uDooIE4Cmyw
Al, the 42" tiller is wider than I need. I use the 30" in between the rows to keep the weeds down.It's light and easy to handle. Having a x595 I could go with the 42 or 647 but my garden not that big either.
Tom
62"powerflow
12 suitcase weights
JD T105 trimmer
Turftime 60" roller
TJR345 is offline
post #6 of 14 Old 05-19-2019, 08:50 PM Thread Starter
TJR345's Avatar
Re: X590 users
The Accel deep deck is really nice and gives a great cut.Now with the power mulch control you can mulch or side discharge.Saves the landscape from getting messed up.
Tom
62"powerflow
12 suitcase weights
JD T105 trimmer
Turftime 60" roller
TJR345 is offline
post #7 of 14 Old 05-19-2019, 09:30 PM
Alberta Al's Avatar
Re: X590 users
If you're just trying to go between the rows, pulling a 30" tiller behind a 42" wide tractor still means that the tractor wheels will drive over the plants ... or am I missing something??? Unless the rows are 42" wide???
Name:	30 inch tiller.jpg
  • Tire chains
post #8 of 14 Old 05-20-2019, 06:37 AM
oldgibsonguy's Avatar
Re: X590 users
I did 1/2 acre with the 30 tiller last fall in about 2 hours. It works better than advertised, is built like a tank, and I can't find any reason to say the hydro tiller is better than the mechanical 30.
Here's mine on the back of my X580 along with the results;
ID:	2377365   Click image for larger version
ID:	2377367   Click image for larger version
John Deere X580, 48" deck, rear lighting and electrical distribution
JD Power integral sleeve hitch, 48" JD blade, 30" JD tiller
oldgibsonguy is offline
post #9 of 14 Old 05-20-2019, 09:08 AM
Tech Exchange Moderator
Sergeant's Avatar
Re: X590 users
Al's Point was the row width.
But It's Nice to be able to Maneuver 145 Lbs over 265Lbs when Mounting the tiller which is another nice reason to go with the 30inch mechanical over the 42inch Hydraulic.
I have used a 30inch Mechanical tiller In the Past and I Just Loved it. If I can find One In driving distance I'll get One for My GX335. I have a 42inch Hydraulic driven and a 48inch 647 Tiller for My X748 I want a Narrow tiller for Cultivation I prefer the Mechanical over the Hydraulic Because it doesn't over till Like the Hydraulic can if Your Not Careful. But I am Probably going to go with a Bercomac 30" Rotary Tiller for Lawn and Garden Tractors - Bercomac Just so I can switch it Between My GX335 & Cub Cadet XT3 GSX Unless I find a 30inch Mechanical Deere tiller for My GX335 I use to Have a 30inch Hydraulic tiller for My Previous Cub Cadet 2206. It was great for Cultivating Because it allowed Me to Tear Up the dirt without getting to close to the Corn for which I use a walk Behind tiller for cultivating close to the corn stalks anyways
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
MSGT 11 & 18 Series Retired
Sergeant is offline
post #10 of 14 Old 05-20-2019, 10:12 AM
Alberta Al's Avatar
Re: X590 users
I can see that. There are two times that weight becomes a factor. 1) when I move the tiller from its winter storage location to the spot where I'll mount it to the tractor. Approx 6 feet. Although it's still relatively easy to maneuver since the 'arms' become the lever point to pivot the weight to the wheels and roll the tiller into position, and 2) when you have to lift a portion of the tiller weight to mount the back brackets to the pins at the rear of the tractor (at the 3:30 mark in the video). Other than that, weight isn't an issue.
Storing a smaller tiller is also an advantage over finding storage space for the larger tiller.
  • Tire chains
post #11 of 14 Old 05-20-2019, 07:43 PM
Sergeant's Avatar
Re: X590 users
https://www.youtube.com/watch?v=8RFpd0yJOgM
In My case Having a 647 & a 42inch Hydraulic is a PIA to store Just because of the 3 point Mounts You have to Have Plenty of clearance to go underneath shelves or Racks especially when there on a dolly
White Model: GT2055
Sergeant is offline
post #12 of 14 Old 05-20-2019, 10:02 PM Thread Starter
TJR345's Avatar
Re: X590 users
The 42 is just too heavy moving it in and out of a shed. If I went with a 42 or 647 they would be 3pt for the X595. The 30" is easy moving and storing.
If you were closer I'd sell you the tiller,just rebuilt it 3 years ago.All new shaft, tines and bearings.
Tom
62"powerflow
12 suitcase weights
JD T105 trimmer
Turftime 60" roller
TJR345 is offline
post #13 of 14 Old 05-21-2019, 07:42 AM
Sergeant's Avatar
Re: X590 users
Yeah I wish WNY was close than 9Hr's away for me 4Hrs In one direction is as far as I want to go to get something Just Bought a New Old stock JD Brinly Made 3 point Cultivator for the X748 from Green Farm Parts
White Model: GT2055
Sergeant is offline
post #14 of 14 Old 05-21-2019, 10:18 PM
Jimbochap's Avatar
Re: X590 users
Wrap it on a pallet and take it to Fastenal.
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is online now
Upgrading to the x584 or x590 - Please help! Magnificent Muttley John Deere Forum 79 04-13-2019 12:10 PM
Attention : rudedawg 42inch deck On X590 Sergeant John Deere Forum 18 03-30-2019 08:48 AM
I'm back! With an X590. mike01 John Deere Forum 2 06-12-2018 10:15 PM
Size comparison - x590 versus x758 PaulB324 John Deere Forum 21 05-19-2018 07:37 PM
Thoughts and questions from x590 owner Jay26 John Deere Forum 17 04-29-2018 01:23 AM
