info needed about a 332..... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 05-18-2019, 08:01 PM Thread Starter
Parts collector
mopar65pa's Avatar
so just bought a beat 332. untill winter I just need it to mow.
I fired it up and it sounds great. BUT the electric PTO clutch does not kick in, and the bearing is frozen.
My question is will a PTO clutch from a 300 16HP Kohler work on the Yammar?
Thanks for the help.
Tony
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #2 of 13 Old 05-18-2019, 08:07 PM
MARK (LI)'s Avatar
Re: info needed about a 332.....
Same diameter shaft?
MARK (LI) is offline
post #3 of 13 Old 05-19-2019, 08:16 AM Thread Starter
Parts collector
mopar65pa's Avatar
I'm not sure yet. I didn't get it off. I will find out today. I just figured some here would know before I dig into it. Thanks
1970 140 H1
1977 300 H2
198? 332 50" deck
post #4 of 13 Old 05-19-2019, 08:58 AM
Who there buckaroo...... take a small break. I had the same problem with my 332, a little oil and gently turning by had and it came free. Try that first before ripping apart.
JD 332
Former Toys
JD 2210, 210 FEL, MMM 62C,
54" Blade, IMatch & Ballast Box
Artillian Forks, Artillian Blade Adaptor
JD 300, restored with
Mower & 54" Blade
JD 316, restored with
Mower & 54" Blade
JD 318, restored & gave
to brother in-law
with Johnny Bucket
RayinPa is offline
post #5 of 13 Old 05-19-2019, 09:08 AM Thread Starter
Parts collector
mopar65pa's Avatar
Well I have to get the trac bar on my wife's truck today then I'll get on the 332.
1970 140 H1
1977 300 H2
198? 332 50" deck
post #6 of 13 Old 05-19-2019, 11:44 AM
Tony, You may have 2 different problems.
1. You're saying the bearing is frozen. With engine not running and pto switch "off", you should NOT be able to rotate pulley...it has a "brake". With engine running and pto switch "off", pulley should NOT rotate..."brake" prevents rotation. Bottom line, if pulley does not rotate with engine running, bearing is OK.
2. As far as pto not engaging: could be bad pto switch, bad/shorted wiring, bad pto coil, or a bad safety switch, or even a bad TDCM. First things first: Disconnect wire from pto. Start engine, turn pto switch "on" and check for 12v +/- at pto wire. If voltage, check ohms through pto coil...should be 4 ohms. If ohms...3.6 (??) to 4.0... good, check ground...from pto housing to frame. Also, check pto gap, .018.
Start there and get back. Bob
rwmeyer is offline
post #7 of 13 Old 05-19-2019, 10:29 PM Thread Starter
Parts collector
mopar65pa's Avatar
Thanks for the info. No it does not turn with the engine running and the PTO switch engaged. I can not turn the pulley with the engine off. Funny I have never seen this but the tractor has 2 PTO switches, front and rear.
I have had too much to do on the trucks at the house so i have just sparaticly looked and fiddled with the 332.
1970 140 H1
1977 300 H2
198? 332 50" deck
post #8 of 13 Old 05-19-2019, 10:52 PM Thread Starter
Parts collector
mopar65pa's Avatar
1970 140 H1
1977 300 H2
198? 332 50" deck
post #9 of 13 Old 05-20-2019, 08:23 AM
wirlybird's Avatar
Send a message via AIM to wirlybird Send a message via MSN to wirlybird Send a message via Yahoo to wirlybird
On the PTO not engaging. Here is what mine did.
Wouldn't engage by flipping the switch. Go to the front and push on it with a long screw driver and it would engage.
Thought I had a bad winding or something.
Turned out to be the "gap" was to big.
Try adjusting the gap with a feeler gauge and see if it helps.
wirlybird is offline
post #10 of 13 Old 05-20-2019, 04:54 PM Thread Starter
Parts collector
mopar65pa's Avatar
Thanks. When I have time I'll check for power from the switch to the clutch. If there is power I will try your trick.
1970 140 H1
1977 300 H2
198? 332 50" deck
post #11 of 13 Old 05-21-2019, 06:58 AM
wirlybird's Avatar
I also have a new PTO I'd be willing to sell. Got it a few years back when I thought mine had bad windings.
Since my 332 get little use now I will probably never need it.
post #12 of 13 Old 05-21-2019, 11:15 AM
inspectorudy's Avatar
You can also take the blue wire going to the PTO and connect it to the positive terminal on the battery and if the magnet pulls the disc in the PTO is working and just need adjustment. If it doesn't move at all or you cannot feel any magnetic pull with a screwdriver while tapping the pulley, then you have a bad coil.
inspectorudy is offline
post #13 of 13 Old 05-21-2019, 04:51 PM Thread Starter
Parts collector
mopar65pa's Avatar
I may take you up on that. We are taking our second honeymoon this weekend so now work getting doen to the 332 and I have to rebuild the front end of our Durango by the end of the week.
yep I have tried that trick before.
1970 140 H1
1977 300 H2
198? 332 50" deck
hoosierpete
Info about an Electric Toro Whirlwind needed LawnToro Walk Behind Mowers 18 03-12-2019 08:25 PM
Old Craftsman lawn cart info needed and what to do with it. Quick Cal Lawn and Garden Tractor Accessories 5 06-12-2018 02:44 PM
Sears FF20 Coil Wiring info needed rwolf15241 Craftsman/Sears Forum 6 02-07-2013 07:02 AM
MTD "columbia" info needed jodi n chris MTD 13 12-25-2012 06:02 AM
wheelhorse info needed frank253 Toro/Wheelhorse Forum 7 12-12-2012 08:50 PM
