54" deck choices for 455 tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 05-14-2019, 08:37 PM Thread Starter
wally2q's Avatar
Ok folks - continuing saga of rebuilding the 455 AWS tractor.
The tractor is done... onto the deck.
let me start with the question: has anyone ever tried modifying a 54C deck, to fit under a 445/455?
Background:
I stripped down the original 54" deck that came with the tractor - other than the 2 idler pulleys that have bad bearings, all mechanical parts are perfect.... except for the sheet-metal.
Rust thinned the metal down, and in a few locations (like around the front attachment points) it's perforated right through.
Called a local dealer here in Canada - he quoted me $2100 for a new deck pan. I told him that this sounds like the price for a whole new deck... not just the sheet metal.... but he told me that is just the sheet metal.
I have a choice... do some welding, or try to fit a 54C deck under that tractor. I can get a 54C in almost new-condition, for $650
That's not a ton of $$ if all i need to do is spend a couple of days modifying it to hang it, and hook up the PTO.... compared to welding, grinding, and painting the heck out of the old deck. But I'll do that if I have no choice.
so.... anyone tried that before?... try to fit a 54C under a 445/455?
wally2q is offline
post #2 of 8 Old 05-14-2019, 09:54 PM
Re: 54" deck choices for 455 tractor
I have not done this specific model but I have made many different decks fit different machines in the past. I will give my process / tips.
First, I do my very best to find the closest matching deck that I can, same cut size and all. To start, you want the spindle drive pulleys almost in the exact same places as the old deck. If you go bigger or smaller deck size you have to remember that you could find yourself really messed up belt / pulley wise.... I have come to find that welding on deck hangers from an old deck onto the "new" one to be the easiest task when building a frankenmachine. This task is almost impossible when you don't have an old deck to cut the hangers off of and pulleys to transfer. When I find the deck I want to use, I will try and transfer everything good from the old original deck to the new one. Most of the time I use a large piece of cardboard to transfer bolt holes and the mount locations from one to the other, that way everything stays square and it is a fairly quick test to see if it will workout. Take pictures of both decks before removing anything so you can reference them if needed during the process. If your mounts end up being in a higher or lower section of the new deck, don't forget to modify their height accordingly, otherwise there might not be enough or any adjustment to fix the difference. I will use two pieces of angle iron welded together to make a pulley mount if needed. A hole can be drilled in the middle of it to mount the pulley and the bottom sides of the angle can be modified to the contour of the deck before welding in place. If there is a large plate that all the pulleys mount too I will try to cut it off an move the entire plate to the new deck. Make small tack welds to mock everything up first then after you are confident that you got it all right and everything goes up and down right, move on to finding a belt that works. Start with trying the stock one and going larger or smaller if necessary. Try not to rely on the tensioner to take up slack, if it is too tight it will eat belts, if too loose the belt will jump off under load of cutting heavy grass...
I hope this gives you and idea of what all is involved and maybe helps some.... Just sharing the simplest version of my experience.
thatmowerguy is offline
post #3 of 8 Old 05-15-2019, 07:20 AM Thread Starter
wally2q's Avatar
yea - thanks for all that.
makes perfect sense.
for me - I will have the 2 decks side by side, so should make it really easy to visualize, and modify.
in my particular case, I am not moving any spindles, pulleys or belts. The belt routing and drive box (shaft drive) is identical on both decks. The drive shaft couples onto the same transmission on both tractors. The only difference I see, is the deck shape itself (pan dimensions) and deck mount locations. What I am still wondering about, is whether the shape of the deck is such that it will interfere with the wheels, or if it's too-high, interfere with the rest of the tractor when lifted. That is something can really can't be "modified" without significant work - making it not worth-while.
cheers!
wally2q is offline
post #4 of 8 Old 05-15-2019, 07:59 AM
Set the deck under the tractor, and see what things look like.
Either that, or start doing body work on the original deck. Sometimes you can find them for reasonable money on the used market as well.
HeyYou is online now
post #5 of 8 Old 05-15-2019, 08:41 AM
Enginerd - DieselDork
moondawg's Avatar
I looked into this a few years ago when I was in the same boat as you... same deck, same tractor. I had a couple of people measuring 54C decks in a few critical dimensions. There was some apocryphal lore that you'd need to update the deck lift arms in order to make this swap work.
In the end, It looked like the 54C might be limited in how high it would raise, especially due to interference with the wheels (front and rear) when you're turning an AWS tractor.
I shopped and shopped and shopped for a used replacement deck. They were all in nearly as bad of shape as my original deck. when my right front gage wheel mount fell off the front of the deck, I finally bit the bullet and bought a new deck shell. (about $1700 from GreenFarmParts.com) It was easy enough to swap over most of the hardware, just replacing some gage wheels that were completely shot.
A couple months later I found a great replacement deck for $950. sigh.
Anyway, if you decide to go the retrofit route... don't forget to take the steering movement of the wheels into account when deciding if the deck "fits" especially if you've got anything other than the 23" tires on the back, or if you want to ever run ags on the back.
Ryan
1996 455 AWS - 54" Deck - 54" Blade - Quick Hitch
moondawg is offline
post #6 of 8 Old 05-15-2019, 08:45 AM
Wfburton159's Avatar
Get a 60"!
2003 John Deere X485
647 tiller
54c deck w/ mulch kit and power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
post #7 of 8 Old 05-15-2019, 08:47 AM
https://www.mytractorforum.com/12-jo...parison-3.html
https://www.mytractorforum.com/12-jo...new-455-a.html
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is offline
post #8 of 8 Old 05-15-2019, 11:48 PM Thread Starter
wally2q's Avatar
interesting.
thanks for all the excellent info!!
modifying the GX345 deck with hangers from the 455 deck etc worked.
But I didn't see anyone try the longer lift-arms and a 54C, which someone theorized may work...
I start the weld-job on the old deck, tomorrow 1st thing. But will continue researching re 54C anyway.....
I have a 62C from my 2305 which I will slide under the 455 - since the mounting points on the 54C and 62C are identical (made for same tractor).... once I have the 62C under there, I can evaluate all the interferences, and the lift-arm length topic. Could also check the 2305 lift arms since they look identical (not sure if they are longer or shorter though) etc
cheers!!!
wally2q is offline
John Deere 48" Edge Mowing Deck Stand (100 Series) TechnicalLee John Deere Forum 2 12-31-2018 11:10 AM
Prestige 54" deck help Dpregs Simplicity/Allis Chalmers Forum 1 09-26-2018 10:47 AM
Simplicity Sunstar 20 Garden Tractor w/Plow, Cutting Deck, Rear PTO, Vacuum System CT Grayp For Sale & Wanted to Buy (Your Location) 2 02-01-2018 03:40 PM
I bought the wrong tractor?! JakeNY John Deere Forum 50 12-20-2017 11:25 AM
Mulch Plate Cover for 54" deck - cant find? mroman59 Craftsman/Sears Forum 12 12-17-2012 12:17 PM
