Yanmar diesel qustion (x595) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 05-14-2019, 03:42 PM Thread Starter
So bought this unit used about 20 months ago. Just did a bunch of maintenance I should have done when I bought it: drained coolant, flushed and refilled; greased it all, checked/cleaned air filters, changed oil and filter etc. I did change oil and filter when I bought it so this is the second time I changed oil. Checked oil level after I filled it and it was clear as expected. Then started it up, dove it out of the garage. Rolled the deck under it and then fired the unit up a couple times to check/fix leveling and height. Then drove it back in the garage and checked oil again. Oil was already black! Is that normal after about 4 starts and maybe 4 to 5 mins of running? My Duramax doesn't get dirty nearly that quick.
VDO
bvdo1948 is offline
post #2 of 6 Old 05-14-2019, 03:55 PM
Re: Yanmar diesel qustion (x595)
Yes, it is normal......no worries
Orv1988332 is offline
post #3 of 6 Old 05-14-2019, 03:57 PM
AOW162435's Avatar
Normal.
Andreas
2003 John Deere x595
54c deck / 54 Quick Hitch blade / CTC loader / Warn XT30 winch / joystick conversion / QHDL / rear hydraulics
AOW162435 is offline
post #4 of 6 Old 05-14-2019, 04:07 PM
AKA Moses Lawnagan
KHodges's Avatar
VDO
Your D-Max holds about 4 times as much oil, too.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #5 of 6 Old 05-14-2019, 07:54 PM
Yes, it holds more oil and so it looks fresher longer. As soon as you start the x the fresh oil circulates and starts to wash all the leftover old oil out of the nooks and crannies, mixing it in with the fresh. Doesn't take long for particulates to make the new oil darker.
eKretz is online now
post #6 of 6 Old 05-15-2019, 12:40 AM Thread Starter
OK. Thanks for the replies and advice! I'll not worry about it again.
VDO
bvdo1948 is offline
Illinois auction YANMAR GT14 Diesel Tractor 14 hp 48 in mower deck locodave64 Ebay/Craig's List 1 07-23-2018 06:11 PM
Trouble with Yanmar diesel sputtering wannabefarmer John Deere Forum 5 05-06-2018 02:53 PM
JD 455 Yanmar Diesel Engine Crankshaft Seal Replacement Photos & Notes itsagaas John Deere Forum 2 04-03-2018 05:35 AM
Yanmar diesel engine RSJSES Construction Equipment 0 03-21-2018 06:42 PM
Yanmar diesel engines for sale inspectorudy John Deere Forum 1 02-17-2018 10:06 AM
