1990 JD 318 with Front PTO / Clutch Grinding?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 05-14-2019, 01:54 PM Thread Starter
Question 1990 JD 318 with Front PTO / Clutch Grinding??
On my 2nd 318...... but now troubleshooting a grinding metallic issue with the clutch 'plate' and ???? Dad and I just took it all off due to a very loud - bearing with sand in it grinding sound coming from the front PTO/CL area.......
Was a Rock found inside, but even still, with the belt on and Gapped correctly, I still have the grinding sound. constant screeching. Its steady, not like a warped sound
The bearing was fine, the mag plate held a bolt/socket easily when engaged.........??? Dad's like it seems the plate that covers stuff needs to be further away vs being pulled closer. The surfaces seemed flat
When its gapped further out and doesn't engage right,, it is quiet and sounds great. Like my former 1987 318
Compression was 126 / 122 roughly, so I can only hope this is a good unit that replaced my LX 178, sadly i sold my 1987 318 due to dealer advice.
When the tractor is off and we take the belt off and turn PTO by hand, you can hear it grind/scratch against the Rotor.....Dad felt it should turn freely without issue, but can't when gapped to .018
ANYONE in Minnesota ????????
What are we missing ?? this doesn't sound like my 1987 and just can't be good for the back of the rotor , or normal to us...
spent plenty on this one with 800+ hours, and a ..... for a paint resto..... but ...... hummmmm
Dad loves his x739 and wanted me to go newer, but I like Old School.....and wanted my former 318. Just hope I didn't get hosed.
Wolf44 is offline
post #2 of 11 Old 05-14-2019, 02:24 PM
Smalljob's Avatar
Re: 1990 JD 318 with Front PTO / Clutch Grinding??
When gapped at .018 you can turn it but not easily.
1988 332 with 49 blower , 54 blade and 3 pt hitch
X500 w/48 deck and 44 blower
1023E H120 loader, B260 BH, 54D deck
Moved on to new home
1962 IH Cub Cadet Original
1963 110 Round Fender... Restored
1963 IH Cub Cadet 100, plow, deck, weigh box, 3 point hitch
1965 110 Round Fender with Model 38 deck..Restored
1966 110H Round Fender with Model 42 Blade..Restored
1967 112 Round Fender with Model 36 blower
1967 112 Round Fender with Johnson Model 10 Loader
1971 120 with 48 deck and 49 blower and OTC cab
1973 140H3 with 41 deck
1987 318 with 46 deck, 54 blade, 49 blower, 3pt hitch
1987 332 with 46 deck
Smalljob is offline
post #3 of 11 Old 05-14-2019, 02:44 PM Thread Starter
Correct, you can "hear'' metal on metal. Its not overly easy to rotate the pulley/assembly, which when running w/o pto engaged it sounds like constant metal on metal....
Everything bearing wise et al looked ok, magnet strength held bolt et al......??? Dad kept saying and i agree its like we're missing a spacer or the key is just too long.
at proper gap. backing it out to .040 or more and its quiet or quieter.
On a secondary Note at PROPER GAP: at bottom idle, PTO will engage and engine happy. anything between low idle and 1/2 throttle it will stumble and kill.
hummm
Wolf44 is offline
post #4 of 11 Old 05-14-2019, 03:51 PM Thread Starter
Some persons have commented that certain years or engines had a 'bushing' installed at the block on the CShaft....... prior to the assembly ???
Unsure that would solve anything but? anyone have any idea on that part.
Also - could the key be too long ? I need to find a schematic or ? on the proper length for that thing, we checked the channel et al for debris, cleaned all of it and reinstalled.
Wolf44 is offline
post #5 of 11 Old 05-14-2019, 06:45 PM
Kish JD 318/420/430
RussKish's Avatar
Here is the info on the key:
9.52mm X 9.52mm X 25mm, (CUT FROM 10' H64376) (SUB FOR M87505)
side - side - length
Russ
Proud Owner of: 318/420/430
RussKish is offline
post #6 of 11 Old 05-14-2019, 06:50 PM Thread Starter
Sweet. thanks, just pounded food and was literally stretching fingers for Google FU on the Key....
Wolf44 is offline
post #7 of 11 Old 05-14-2019, 06:58 PM
Kish JD 318/420/430
RussKish's Avatar
Check to see if the hub (it is the part with the bearing and spring fingers has a notch in it, that sets the over all spacing. It is the rotor that moves back and forth. Backward toward the coil (electromagnet) to engaged PTO. Forward to stop PTO and apply brake.
Russ
RussKish is offline
post #8 of 11 Old 05-15-2019, 06:10 AM Thread Starter
Will take a good look at that notch too, in the rotor, maybe i don't have enough magnet strength ??? to keep it away from the constantly 'braking' ??
Wolf44 is offline
post #9 of 11 Old 05-15-2019, 02:15 PM
Kish JD 318/420/430
RussKish's Avatar
I would check the resistance of the coil, it should be around 4 ohms, also inspect the coil for damage (discolored, burnt, exposed wiring). To test for strength (with the coil out) hook the coil to another battery and see if it can pick up a very large bolt, or heavy tool (channel locks).
Russ
RussKish is offline
post #10 of 11 Old 05-15-2019, 09:19 PM Thread Starter
Wilco RussKish. Going to be crap this weekend here in MN..........Storms/rain. Thus, I hope to tear it out and try again.
Wolf44 is offline
post #11 of 11 Old 05-20-2019, 08:23 PM Thread Starter
Gent sold me a nicely used full assembly for fair price and it worked perfectly from the start. Go figure. but even he said my orig. one looked pretty good.
Something just enough off to cause issues or didn't seat just far enough or ???
Thanks All.
Wolf44 is offline
Unable to adjust front PTO clutch on 322 Teen with 318 John Deere Forum 25 03-27-2019 06:58 AM
Bushing for John Deere L120 PTO Clutch. Anyone have a hack? mwnitz John Deere Forum 1 07-30-2018 03:34 PM
RT5000 PTO Clutch assy. WilsonDV Honda 7 07-10-2018 06:54 AM
318 Front PTO Belt Crooked peksav44 John Deere Forum 37 05-10-2018 11:20 PM
Rider PTO Clutch Disassembly yamato72 Gravely FAQ and Stickies Section 12 10-07-2012 09:06 AM
