How much to make a beat 47" blower right? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-13-2019, 07:24 PM Thread Starter
I cant stomach the asking prices on blowers in good shape and starting to look at ones run hard and put away wet. Not damaged just needing a paint job and have to assume every wear item needs to be replaced. Assuming the quick hitch is good, if I had to replace every single normal wear item on an early 2000s 47" blower, how much should I budget? And assuming I'm starting from scratch with the pto, what am I looking at to hook it up to the X595 if it was on a X585? Is thinking this is a 2 or 3 solid but not killing myself weekend project reasonable?
This is for me and I dont care about resale so just looking for reasonable operating condition as opposed to anything resembling restoration. Thanks in advance for your insight.
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Ford 1910 4WD Loader Backhoe
Jacobsen GT14
post #2 of 10 Old 05-13-2019, 07:31 PM
Red Cap Club
nick4030's Avatar
Re: How much to make a beat 47" blower right?
It would be far less expensive to buy a nice blower to begin with than piecing one together. By a long shot.
If you happened to find a fully functional but cosmetically lacking blower you might save a few bucks.
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is offline
post #3 of 10 Old 05-13-2019, 07:39 PM Thread Starter
That's my starting point and I am trying to figure out worst case if all the normal wear items need to be replaced before it is reasonably ready for service. I have seen some pretty cheap functional but ugly units go by. If worst case was say $500 in parts for normal wear items it brings me down to what I want to be into other than a few weekends of work.
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Jacobsen GT14
post #4 of 10 Old 05-14-2019, 03:49 PM
Banned!
I have to agree with Nick, there is almost unlimited possible issues that without a thorough inspection and run with someone very familiar with the unit, you can get buried really quick. The gearboxes on these things alone will blow your $500 budget. Although mine is a x5XX series version, I replaced the Augers and Shaft and that was well over $600.
The reality is, the worse case scenario is you can easily go past $1,000 if the unit was abused and not maintained and it has a few issues to resolve to ensure some degree of reliability.
I say this with all due respect, but if you sense the need to ask this kind of question, and don't think you have the ability to thoroughly judge the total condition, you should probably lean away from those that are questionable. Gambling like this can only consistently work in your favor when you know these things inside and out.
I'd start by looking up the model on JD Parts, and just print out the schematic and price sheet for the major components. That will be an eye opener for sure.
My .02 fwiw.
mrmagloo is offline
post #5 of 10 Old 05-14-2019, 04:35 PM
oldgibsonguy's Avatar
Some attachments should be repaired and maintained as needed by the owner. This keeps the cost of ownership down and the resale value up. Blowers are an attachment that needs constant attention and blowers are one of the more expensive attachments to maintain. Unless you find a blower in really good shape for about 1/2 to 2/3 the cost of a new one I would say buy new, get all the right parts and a warranty.
John Deere X580, 48" deck, rear lighting and electrical distribution
JD Power integral sleeve hitch, 48" JD blade, 30" JD tiller
oldgibsonguy is online now
post #6 of 10 Old 05-14-2019, 07:34 PM
Well, I picked up a 42 inch 2 stage blower for my JD L130 for $100 plus a 5 hour round trip. Seller was up front and stated that one auger didn't rotate. Long story short, I found that Agri-Fab built it for JD. Ordered the gearbox/input/auger shafts, all the wearables, pulley, impeller and extra shear pins for around $400 direct from Agri-Fab. Had I ordered every thing from JD, I could have bought a new Berco. (the gearbox assembly{not serviceable} from JD was $560 and I paid $250. The impeller from JD was $156 and I paid $46.)
wooserco is offline
post #7 of 10 Old 05-14-2019, 08:14 PM
Still lovin' the 322!
PA318Guy's Avatar
If hydraulic cylinders and gearbox are OK you should be able to fix one up for the price range that you are looking at. I've been know to rescue one or two snowblowers in that type of condition (not the same model) and bring them back. If nothing else you have the pride of knowing you saved a piece of machinery from an early grave.
Current Machine JD 322
PA318Guy is offline
post #8 of 10 Old 05-14-2019, 08:51 PM Thread Starter
Thanks all for the input and love your story @wooserco...thats the plan I am trying to get on but limiting my search to fully functional just not pretty.
I have owned a 59 as well as the older style 47 for many years but havent had to put anything into them other than grease. So, I wasnt sure how this adventure might pencil out.
Soon to be former:
JD x300 42"
Former:
JD F910 60" deck
Jacobsen GT14
post #9 of 10 Old 05-16-2019, 02:30 AM
Red Cap Club
nick4030's Avatar
The gearbox is your biggest ticket item. Without frequent oil changes they have been known to fail (relatively small amount of oil in them, contaminants get into bearings). They can be rebuilt, similar to mower deck gearboxes, but you have to research them well because they are considered non serviceable. You can get bearings though. If you find one to look at, pay very close attention to the gearbox. Listen to it turn over very carefully, check the oil and pay attention to any "sparkles" in the oil.
U-joint crosses are or were available a few years ago, probably still are if you can track down the pn. I used to know it at one time but have since forgotten.
1991 John Deere 332
1973 John Deere 110
1974 Case 646
nick4030 is offline
post #10 of 10 Old 05-16-2019, 07:33 AM
mrbeef's Avatar
As a general rule of thumb unless there is clear evidence of maintenance a cosmetically lacking blower will also be mechanically lacking. I think I have looked at one cosmetically chaleneged blower that passed my mechanical test, not surprisingly it sold for $1,500 at auction.
Just and example, I've purchased blowers for my 1445 front mount. Cosmetically I would rate both 7/10... Put $650 into one and $550 into the other (hoping the $550 did the trick, if not it will be an additional $770). Both blowers were used and maintained...
Yes, you can find cheap 47 blowers in good mechanical condition... The $500 one I found was in great shape mechanically and 8/10 cosmetically but the seller didn't have a clue what to do with it... They just happened to end up with the blower when they bought the mower.... Haha.
However, generally you are going to be money and time ahead by spending the $2000 to buy a nice used one. This is just a general rule of thumb.... As an example, you can buy nice 455's for $3000-3500... I paid $1500 for one is poor cosmetic condition... Shockingly the parts bill is sitting right at $1600...
Take some time and look through the parts breakdown of the 47 blower and QH. Look at all the prices for the parts and the parts you think might wear (Sprockets, shafts, chains, bearings, skid plates). Use that information when you inspect a used unit, offer accordingly.
Tractors:
Former Machines:
Kohler Light Plant
mrbeef is offline
Adapting Ariens blower to medium frame elvenhome21 Bolens Forum 15 03-05-2019 04:37 PM
what's the easiest snow blower to install? MichEE Lawn and Garden Tractor Accessories 26 04-24-2013 02:39 AM
445 with 47" blower works AWESOME-- VIDEO cobra445 John Deere Forum 9 02-12-2013 08:37 PM
Wish I had a 54" blower instead of 47" 77cruiser John Deere Forum 25 02-05-2013 02:51 PM
