How can I make seat more shock absobent - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 35 Old 05-11-2019, 09:19 PM Thread Starter
How can I make my seat setup more shock absorbent on a 314? Has anyone replaced their seat with something else that doesn't cost much, that I can find as an aftermarket part? Or welded in springs, under there seat, or added more padding.
I'm starting to get a sore back when mowing the lawn. It can't be because I'm getting old, and don't move around very much anymore. It must be the tractor is old or the lawn is bumpy. lol
314 John Deere
blower
mower
mike Liz is offline
post #2 of 35 Old 05-11-2019, 11:09 PM
rudedawg's Avatar
Re: How can I make seat more shock absobent
A couple of things that helped mine: a cut to fit piece of foam cushion laid on the seat then a seat cover over both, lowered air psi in tires.
rudedawg is offline
post #3 of 35 Old 05-11-2019, 11:56 PM
20,000 Posts & Climbing
I use a piece of plush carpeting in the winter when the seat is frozen. It will work in the summer for bumpy lawns as well.
TUDOR is online now
post #4 of 35 Old 05-12-2019, 12:26 AM
demonspeed's Avatar
Maybe one of the JD seat covers? The basic one (LP22704) has some padding ($30). There is a Deluxe (LP40090) which has thick padding (it's $50, though).
2004 John Deere GX345
48” Edge Mower & Blowout Kit, Predtor2’s|42” Thrower|48" Blade & Angle Kit
Front Bumper|Halogen Kit|Carlisle HDFT & Xtrac
FOR SALE: BM20827 Mulch Kit for 54C/54D/54X
Past:1988 Bolens ST120 Hydro Eliminator
36” Mower & PowerPacker|42” Blade & Lift Kit|Head Light Kit
demonspeed is offline
post #5 of 35 Old 05-12-2019, 12:37 AM
dwendt44
Does your tractor have springs under the seat now?
The newer units have springs that can be adjusted to a small
degree. Moving them toward the rear will soften the ride slightly.
My 2¢
dwendt44 is offline
post #6 of 35 Old 05-12-2019, 10:27 AM
My 2¢
You have that backwards I believe unless your spring set up works backwards from mine.
rayjay is offline
post #7 of 35 Old 05-12-2019, 10:34 AM
On the 314 it would be easy to move the seat back on the springs. Add a section of strap iron on top of the springs that extends back enough to add a hole for the rear holes in the seat. Then move the front seat fasteners to the existing rear hole and the rear fasteners in the seat mount to the new holes in the new strap iron. Might end up too soft at which time you could add some helper springs.
rayjay is offline
post #8 of 35 Old 05-12-2019, 10:42 AM
All kinds of possibilities!
Take a look here:
https://seat-warehouse.com/
Flaken is offline
post #9 of 35 Old 05-12-2019, 12:43 PM
dwendt44
Yikes Re: How can I make seat more shock absobent
I stand corrected. I originally wrote 'forward' but changed it for some reason.
Brain fart.
My 2¢
dwendt44 is offline
post #10 of 35 Old 05-12-2019, 05:48 PM
inspectorudy's Avatar
You can buy a piece of the fattest pipe insulation and cut a piece the width of the seat springs and put it beneath the existing springs. That will give you some extra softening of the existing springs. I did it on an old Cub I had and it worked pretty well.
inspectorudy is offline
post #11 of 35 Old 05-12-2019, 06:46 PM
greenguy2's Avatar
I park the John Deere for the summer and mow w/ the Ferris IS2100Z, my back thanks me for it!
2011 X720SE
'98 Troy Bilt GTX20(sold to nieghbor)
Ariens GT20(gone)
Ariens 10 HP gear drive(16 yrs hard use)(gone)
80 John Deere cart
2016 Ferris IS2100Z
greenguy2 is offline
post #12 of 35 Old 05-12-2019, 08:54 PM
AKA Moses Lawnagan
KHodges's Avatar
Michigan Seat Company makes the suspension seat for the X7's (the one that comes on the SE models). It works great, but may be larger than you'd like on the 314.
A better fit, but probably harder to find, would be the optional seat that came on the 318. It would bolt right up, be a better fit, and it works well, too. There is an adjustment bolt that changes the stiffness to suit your weight.
ID:	2376351   Click image for larger version
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #13 of 35 Old 05-13-2019, 06:29 AM
Old school motorcycle seat springs are a possibility . These are springs that are about 3 " tall and maybe 1 " - 1 1/4 " in diameter . Wedge them in between the OEM seat springs you just need to figure out a way to secure them . Shouldn't be that difficult .
rfuerst317 is offline
post #14 of 35 Old 05-13-2019, 10:21 AM
I have used these trailer door bumpers to soften the ride on my 300 series with tilt seats. It offers a less jarring ride than the tiny original rubber bumpers on the seat springs, and also tilts the seat forward a bit, which works for me.
ID:	2376415   Click image for larger version
NYKen is offline
post #15 of 35 Old 05-13-2019, 10:48 AM
Merc1973's Avatar
Suspension seat bases from a (425, 445, 455) series are about $100-125 on ebay. You may have to drill holes, but that's easy. Those are cheaper than 430 seat bases which are probably plug and play for more than $200 on ebay.
1981 400- Vanguard 23 HP, 54C deck, 56 blade, 50 snow blower
SOLD-2003 G100- 54", Kohler Command 25, Gator G5 blades
JD 46" snow Blade
Stihl 031AV (WIMA cap, base gasket delete) 20"
Echo CS-590 (MM) 20"
Husqvarna 128LD Trimmer
Giant Vac w/ 6.5HP Predator Engine
Unknown 1980's Japanese backpack Blower with Kawasaki engine
1968 M35A2
Merc1973 is offline
XT3 Seat Switch faulty? ChuckT Cub Cadet Forum 54 05-01-2019 08:36 PM
Slippery seat, one solution. JP Savage Backyard Round Table - L & G Tractor Related Topics 8 06-07-2018 03:49 PM
ATTN: John Deere 318 Owner's, a Few Tip's on how to Keep that 318 Alive & Well Hammerdown John Deere Forum 34 06-01-2016 11:21 AM
X-Series seat cracking in the cold forum009 John Deere Forum 9 02-15-2013 08:11 AM
"RUBBER" Tire Chains....how to make Whirly Lawn and Garden Tractor Accessories 21 12-29-2012 01:27 AM
