Kawasaki FD620D Plastic Cam Gear - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 33 Old 05-10-2019, 06:26 PM Thread Starter
mowergene's Avatar
I've read enough about the plastic cam gear in the 445 to get me just a little bit shook. I purchased my 445 late last summer. The serial number of the tractor is mostly obliterated, BUT, the engine air cleaner sticker says that it was manufactured in June of 1998. I've searched too many hours with this information and cannot get a definitive answer. I'm eight hours short of 1500 hours and the machine is running well. I know the water pump can be removed to check on the gear if necessary but I hate to go to that trouble if not necessary. Is it possible that the plastic gear could have this many hours on it AND twenty years???
In the past:
In use:
mowergene is offline
post #2 of 33 Old 05-10-2019, 07:09 PM
mikgran's Avatar
Re: Kawasaki FD620D Plastic Cam Gear
I believe February 1998 was the cut off for the plastic cam gear. Steel after that.
2004 X485- 54 deck, 47 blower
1977 210
1970 110H
1991 Ariens YT12H w/bagger
1986 Kubota B7200HST
mikgran is online now
post #3 of 33 Old 05-10-2019, 07:33 PM
Everything I've ever read about the plastic gears says they go between 800 and 1200 hours. If so, you either have a plastic gear that's way past its due date or you've already got the steel gear and you're home free. I'd bet on the latter.
Cheapsnake is offline
post #4 of 33 Old 05-10-2019, 07:37 PM Thread Starter
mowergene's Avatar
mikgran
These two responses are encouraging!
In the past:
In use:
post #5 of 33 Old 05-10-2019, 08:41 PM
Able to still see/read the engine serial no.?
JDDottie is offline
post #6 of 33 Old 05-11-2019, 01:30 AM
inspectorudy's Avatar
The front engine number is rarely still on many of the engines. That date on the air cleaner is not the engine build date. They are not built at the same time so it is only a pull as need part. It really is not that big of a job to pull the radiator housing off and then remove the front cover on the engine. That will expose all your questions and if you have a new gasket handy if the gear is steel then you just put it app back together. If you are a pessimist then you can buy the new gears and gasket kit and have them ready to go if needed.
Watch this short video on how to replace the cam gear on a 445.
inspectorudy is offline
post #7 of 33 Old 05-11-2019, 02:11 AM
post #8 of 33 Old 05-11-2019, 05:55 PM Thread Starter
mowergene's Avatar
I'm still wondering if there were any noticeable differences in the 445's or the engines therein to differentiate the plastic vrs the steel other than serial numbers.
In the past:
In use:
post #9 of 33 Old 05-12-2019, 12:01 AM
If inspector is right about a "pull as need part" and the air cleaner has a build date of June 1998 then the tractor would have to have been built after the the air cleaner was built and well within the "age of the steel cam gear". Now you need to know if when they put the tractor together is the engine a "pull as need part" too or are they being built at the same time as the tractor is assembled.
Tractor Beam is online now
post #10 of 33 Old 05-12-2019, 06:52 AM
mikgran's Avatar
My opinion- drive it and donít worry about it. Not likely that someone would have replaced the air cleaner. And Iím pretty sure Iíd read where February of that year was then end of plastic.
1977 210
1970 110H
post #11 of 33 Old 05-12-2019, 10:19 AM Thread Starter
mowergene's Avatar
I, too, believe that the June of '98 on the air cleaner is the best evidence apart from looking inside! I've got to learn to throw my concerns out the back door.
In the past:
In use:
post #12 of 33 Old 05-12-2019, 09:42 PM
In JDparts Label 3A has been replaced by Label 3B.
MAYBE 3A was plastic cam engine and 3B is steel cam engine????
Zebra5 is offline
post #13 of 33 Old 05-12-2019, 09:44 PM
Could a small bore camera be inserted through the oil drain to "look" at the cam gear?
Zebra5 is offline
post #14 of 33 Old 05-13-2019, 12:50 AM
Here is the Kawa with the water pump removed and the gear showing. This is the easiest way to determine for sure if your has the plastic gear. Three bolts and a hose to remove.
post #15 of 33 Old 05-13-2019, 09:39 AM Thread Starter
mowergene's Avatar
Another good sign! I've got the 3B.
In the past:
In use:
What was the last year for the Kawasaki plastic cam gear? ggsteve John Deere Forum 5 12-18-2018 10:32 AM
John Deere 445 Plasric Cam Gear tjcski John Deere Forum 22 10-30-2018 09:12 AM
345 Plastic Cam Gear & Transmission Oil Change Pjs1inc John Deere Forum 2 04-22-2018 07:30 PM
345 steel cam gear upgrade rags John Deere Forum 15 11-05-2017 09:59 AM
RECALL - Kawasaki engines & Honda generators BRAKER Safety Forum 0 11-16-2012 09:26 PM
