Kawasaki FD620D Plastic Cam Gear - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #31 of 33 Old 05-16-2019, 04:10 PM
inspectorudy's Avatar
Re: Kawasaki FD620D Plastic Cam Gear
Here is a picture of how the pushrods work. They never get near a piston. If you notice on the bent rods one was badly bent and the others were each a little less. The valves may have been involved but not the pushrods with the pistons. I think it may have been a few teeth at first and then the timing got really out of whack and that's when it bent the rods.
inspectorudy is offline
post #32 of 33 Old 05-16-2019, 04:17 PM
pushrods are typically very thin tubs. depending on how everything is aligned, if the piston does wind up hitting a valve, it may just damage the valve, but if the pushrod happens to be weaker or just slightly not perfectly straight, it may bend instead of or as well as the valve.
dave_r is offline
post #33 of 33 Old 05-16-2019, 04:27 PM
Correct. If pistons meet pushrods, that's gonna be replacement of the engine, not repair.
Pushrods get bent (in an interference engine) when pistons meet VALVES. When a steel valve meets an aluminum piston, it leaves evidence. I am not seeing any evidence. There is a *possible* mark on the first piston he shows, but, the other side has zero evidence of anything hitting it. (or, it hitting anything... as the case may be.)
I am also not finding many folks talking about having to replace pushrods with the failed cam gear either...... I find folks with bent pushrods that the cam gear is still good though.
Wonder if the guy in the video just had bad luck.....
HeyYou is offline
What was the last year for the Kawasaki plastic cam gear? ggsteve John Deere Forum 5 12-18-2018 10:32 AM
John Deere 445 Plasric Cam Gear tjcski John Deere Forum 22 10-30-2018 09:12 AM
345 Plastic Cam Gear & Transmission Oil Change Pjs1inc John Deere Forum 2 04-22-2018 07:30 PM
345 steel cam gear upgrade rags John Deere Forum 15 11-05-2017 09:59 AM
RECALL - Kawasaki engines & Honda generators BRAKER Safety Forum 0 11-16-2012 09:26 PM
