Kawasaki FD620D Plastic Cam Gear - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #16 of 33 Old 05-13-2019, 01:11 PM
Re: Kawasaki FD620D Plastic Cam Gear
Originally Posted by zebra5 View Post
could a small bore camera be inserted through the oil drain to "look" at the cam gear?
+1
denverguy is online now
post #17 of 33 Old 05-13-2019, 02:00 PM Thread Starter
mowergene's Avatar
Originally Posted by Zebra5 View Post
Could a small bore camera be inserted through the oil drain to "look" at the cam gear?
I only wished I had that kind of high-tech equipment!
In the past:
In use:
mowergene is online now
post #18 of 33 Old 05-13-2019, 03:36 PM
I have no experience with this product or brand, but for $20 you can get an inspection camera that connects to a smartphone or laptop. I'm sure it's very low quality but I would expect it to get the job done.
https://www.amazon.com/DEPSTECH-Semi...%2C178&sr=8-10
post #19 of 33 Old 05-13-2019, 04:22 PM Thread Starter
mowergene's Avatar
No laptop and no smartphone. I'm from the flipphone era.
In the past:
In use:
post #20 of 33 Old 05-13-2019, 04:28 PM
The combination of already having 1,500 hours on the machine and the date on the airbox would make me feel pretty comfortable it has the steel gear. John Deere had obviously identified the plastic cam gears as an issue prior to Feb. 1998 so can't imagine they would intentionally install an engine built like that in June or later of '98. I would be surprised if they had 4-6 months worth of engines sitting around in a warehouse, and even if they did it is pretty common for manufacturers to go through any old inventory and update the part before installing it in the machine.
6.2Blazer is offline
post #21 of 33 Old 05-13-2019, 08:28 PM Thread Starter
mowergene's Avatar
That's the kind of thinkin' I'm holding on to. It certainly is a smooth runner!
In the past:
In use:
post #22 of 33 Old 05-16-2019, 07:34 AM
GPopper's Avatar
My 1994 had about 1100 hours on it and I caved to worry about cam gear and had it replaced with steel. The old one looked like the day it was made so I probably didn't need to worry at all. As I understand it no damage will happen to engine if it does fail. Its just a matter of convenience when to do it. You would hate to be down in the middle of either mowing or snow removal season.
GPopper is offline
post #23 of 33 Old 05-16-2019, 11:17 AM Thread Starter
mowergene's Avatar
Simply looking at plastic gives you no idea of how Brittle it is. I, personally, think all plastic parts should be banned from the inside of an engine which exposes it to extreme heating and cooling.
In the past:
In use:
post #24 of 33 Old 05-16-2019, 11:52 AM
inspectorudy's Avatar
I too thought that no damage would occur but there is a video on Youtube that shows one with all of the push rods bent after the cam gear failed.
inspectorudy is offline
post #25 of 33 Old 05-16-2019, 03:30 PM
According to what I am finding, it isn't supposed to be an interference engine..... so, cam gear failure should NOT lead to catastrophic damage...... But, as a LOT of folks have noted, both here, and elsewhere... You KNOW it's a problem, it is not an "if", it's a "when". Fix it when it is convenient for YOU. Otherwise, it will pick the worst possible moment to fail. (like when you are trying to blow out your driveway during the 30" snowfall..... Then you get to work on it out in the cold too. )
HeyYou is offline
post #26 of 33 Old 05-16-2019, 03:40 PM
Here is the video and the four pushrods that are bent from the cam failure.
post #27 of 33 Old 05-16-2019, 04:00 PM
Interesting video.... I note that all four pushrods appear to be bent? Yet there is zero evidence on the piston tops, that they smacked anything at all.....
I don't think that the cam gear failure can account for all four pushrods being bent.... that would require the cam gear to have failed when all four valves were off the seat. I am unsure if that is ever the actual case though.....
HeyYou is offline
post #28 of 33 Old 05-16-2019, 04:02 PM
Like the old song, "Nothing like your lying eyes."
post #29 of 33 Old 05-16-2019, 04:06 PM
Huh? Are you seeing something I am not?
HeyYou is offline
post #30 of 33 Old 05-16-2019, 04:08 PM
It's possible the cam could fail by several teeth breaking or wearing so that it could skip several teeth, then momentum would keep everything spinning so all the valves get hit by the pistons...
dave_r is offline
What was the last year for the Kawasaki plastic cam gear? ggsteve John Deere Forum 5 12-18-2018 10:32 AM
John Deere 445 Plasric Cam Gear tjcski John Deere Forum 22 10-30-2018 09:12 AM
345 Plastic Cam Gear & Transmission Oil Change Pjs1inc John Deere Forum 2 04-22-2018 07:30 PM
345 steel cam gear upgrade rags John Deere Forum 15 11-05-2017 09:59 AM
RECALL - Kawasaki engines & Honda generators BRAKER Safety Forum 0 11-16-2012 09:26 PM
