X748 3PH question.. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-10-2019, 05:59 PM Thread Starter
FTWingRiders's Avatar
X748 3PH question..
Hello all.
I'm in the market for a 3PH for my 2011 X748, talked to the dealer yesterday.. part BUC10169 for $735 plus installation if I want it. Service said the hydraulic cylinder doesn't need to be relocated..
Talked to Bill at Ruegg, he said I do need to relocate it, $475 plus (I believe said) $85 for the relocation kit plus $35 shipping..$595 total.
So... do conflicting information and was wondering if anyone could let me know if they needed the relocation kit?
Also, I'm leaning towards OEM, but if anyone with real world experience would offer an opinion, I'd appreciate it!
I read a few threads about it, but still confused.. (Not really a shocker..LOL)
Thanks! Forrest
Forrest
X748 2011 with 45 loader, 3PH, remote valve, rear hydro, 54" mulching deck, custom hard cab and R4's
455 with 48' deck with PF and Hydraulic tilt dump, 26" HDAP's, front 18" HDAPs on 10" wheels
John Deere Cab
54" deck
54" blower with metal Impeller, chute rotation and flapper mod, 36T sprocket.
Laded 26" HDAPs for winter duty
54" blade with extensions.
51" rotary broom
3 quick hitches
Front mount dethatcher
Titan forks
SOLD:425, X585
FTWingRiders is offline
post #2 of 10 Old 05-10-2019, 06:49 PM
burned300's Avatar
Re: X748 3PH question..
I like my Deere three point and yes cylinder will need relocated
Sent from my iPhone using Tapatalk Pro
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is offline
post #3 of 10 Old 05-10-2019, 10:03 PM
Red Cap Club
nick4030's Avatar
Yep it has to move. I have a Deere hitch on my x748, but a ruegg on my 332 and it's identical to Deere for all intents and purposes. Id buy from him again.
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is online now
post #4 of 10 Old 05-10-2019, 11:36 PM
AKA Moses Lawnagan
KHodges's Avatar
The Deere 3 point does require the cylinder to move, there is a reciprocal arm that goes back to the deck lift so the cylinder can operate both the mid and rear lift arms, with a mechanical rear lockout/height adjustment connecting them. I had my dealer install mine when I bought the tractor.
For the price difference, if the Ruegg installs the same way, I'd go that route. Aren't the lift arms straight on the Ruegg setup? Never have understood why the Deere arms are bent so many times.
Proud owner of :
'08 JD X748SE, 54C deck
3-pt hitch, rear PTO
Power Flow and MC519 cart
LP RTR0550 rototiller
?? 60" box blade
45 Loader
3-point PTO DR wood chipper
'02 JD GT235, 48C deck
'84 JD 318, 50" deck
'86 JD 214, 46" deck
'86 JD 212, 38" deck
KHodges is offline
post #5 of 10 Old 05-11-2019, 06:00 PM
I had to relocate the cylinder on my x748. It isn't too hard to do it yourself. I did mine in an afternoon. The only bad part is if you have large hands some of the bolts/nuts you have to attach are in some pretty tight places. I might have invented some new curse words when I did mine.
winchester is offline
post #6 of 10 Old 05-11-2019, 11:36 PM Thread Starter
Thank you all for the replies.. I guess I just have to decide whether OEM or Ruegg.. I have it all apart for other work so now is the time to do it. I'm leaning toward OEM but I'll sleep on it and order one of them Monday morning. Thanks again!!
Forrest
John Deere Cab
54" deck
51" rotary broom
3 quick hitches
Titan forks
SOLD:425, X585
post #7 of 10 Old 05-12-2019, 09:41 PM
The lift arms are bent because the back of the optional Curtis Cab will limit how high the rockshaft bracket for the top link will rotate. Because of the custom cab may be wise to make sure that the back of the cab does not interfere with the full range of both OEM and Ruegg rockshaft. Your custom cab rear may sit further down than the Curtis Cab.
When I had my x749 with Curtis cab, the oem bent lift arms were missing, but the BM23882 3 point rockshaft was on the x749. I ordered the arms from Ruegg and the straight arms did not give the same amount of lift, so had to get a local welder to cut and weld the last 6 inches at a 60 degree bend to get suitable lift. Notice Ruegg x4, x5 ad on Ebay specifically states that his 3 point will not fit on tractor with cab.
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is offline
post #8 of 10 Old 05-13-2019, 12:41 AM Thread Starter
Thank you!! That really made up my mind and I just ordered OEM. I don't believe my custom cab goes lower than the curtis or limits how high the rockshaft will rotate, but I'm not going to chance it. Having the bend will also allow for a higher lift.
Forrest
John Deere Cab
54" deck
51" rotary broom
3 quick hitches
Titan forks
SOLD:425, X585
post #9 of 10 Old 05-14-2019, 09:16 PM
burned300's Avatar
My big tip to relocating cylinder is... after you install kit on cylinder and go to install cylinder on tractor. DO NOT attach cylinder to tractor first. The first thing you do is start hoses/lines finger tight, then attach cylinder to tractor then tighten hoses with wrenches
1970 112
1975 200
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
Brinly cat 0 plow
post #10 of 10 Old 05-14-2019, 09:24 PM Thread Starter
Thats a tip I will take to heart! I installed the Auxhyd remote valve this weekend.. according to the instructions, theres a hose with coupler coming off the cylinder that you disconnect the hard tube and attach the supplied line to, but on mine the coupler is directly off the 45 degree coming off the cylinder..not easy access at all!.. if that makes sense..lol The kit is all installed except for that, I'm waiting for the 3ph to arrive at my dealer and I hope to tackle it this weekend..
Forrest
John Deere Cab
54" deck
51" rotary broom
3 quick hitches
Titan forks
SOLD:425, X585
New x758 3PH Help! EddieLee24 John Deere Forum 14 09-05-2018 04:06 PM
X748 hydraulics question dinomax John Deere Forum 20 03-08-2013 09:28 PM
317 3ph cylinder question jpatkison John Deere Forum 3 01-22-2013 09:58 AM
Question for x748 and x728 owners dinomax John Deere Forum 14 12-29-2012 12:30 PM
X748 with 60D 7 iron owners, need a pic please and cut depth mechanism question jpa2002 John Deere Forum 11 12-18-2012 10:42 PM
