Don't do me wrong man! 332 - Page 6 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #76 of 82 Old 06-21-2019, 05:30 PM Thread Starter
Parts collector
mopar65pa's Avatar
Re: Don't do me wrong man! 332
Alrighty then............. So my OCD would not let me get just one tire so I bought 2. Plus I hate fighting with these small tires and I bought the HF small tire changer.
Now to get the tires swapped out. Then I need to mow the back 40!
I figure I'll get a fuel filter and some diesel "cleaner" and throw a little in ever fill up since I plane on running 50/50 diesel and WVO.
1970 140 H1
1977 300 H2
1983 314 H1 for sale
110 parts tractor for sale
198? 332 50" deck
300 series #33 tiller
Single piston dirt/snow plow
piston lift snow blower
Hand made pintle hitch
mopar65pa is offline
post #77 of 82 Old 06-21-2019, 07:00 PM
Still lovin' the 322!
PA318Guy's Avatar
Probably a good idea to change them out together. I have a large tire changer and don't have it bolted down, it's always interesting to change them when you're also fighting to keep the device upright. So if you can bolt it down to something.
Current Machine JD 322
PA318Guy is offline
post #78 of 82 Old 06-21-2019, 08:13 PM Thread Starter
Parts collector
mopar65pa's Avatar
I have an old coats 40/40 tire changer for my "bigger stuff" but it will not do my 8" rims for the tractors. The 40/40 is not bolted down but I have not had a problem yet. I have changed so many tires it's not funny. BUT I will need to bolt down the mini. now to figure out where?
1970 140 H1
1977 300 H2
198? 332 50" deck
post #79 of 82 Old 06-23-2019, 12:21 PM Thread Starter
Parts collector
mopar65pa's Avatar
Well he did me wrong. I was going to swap out the lift rods from the 314 to the 332 and found that there is no rocker shaft and no lift piston! WHAT!
I contacted him and he got mad at me. Really? You couldn't tell me it didn't have this stuff on it before I bought it? heck I could have bought the one up the street ready to mow for $2K but no I bought this basket case for $900 with a bad deck and not way to lift a deck, along with a hacked wiring harness. he tells me he has them and is willing to give them to me. Also said he has a 330 that he is parting out and that I can buy the front axle and spindles. Not sure they will fit though and he hasn't given me a price yet.
Well I used the new HF tire changer and it worked pretty well. beads broke VERY easy tires came off easy, but putting the new ones on was a pain. I'm going to have to modify things. I clamped it in my bench vise for now until I find a permanent place to mount it.
The tires are still holding air so I guess I'm good.
I put 3+hrs of seat time in yesterday, filled it with fresh diesel and she ran great! chomped up all the new grass and the "hay" laying on top. I need to make a mount for my trac-vac so I can get all the "hay" off the yard.
1970 140 H1
1977 300 H2
198? 332 50" deck
post #80 of 82 Old 06-23-2019, 01:14 PM
PA318Guy's Avatar
Yep any of the "closed" rear end models don't have the same setup for lifting implements. You can't use 300, 312, 314, Kohler 316, or 317 for those purposes. See below that front axles are not same PN. They are the same as a 318 though.
332 Front Axle PN: 23 - FRONT AXLE
Part Number
M85069
Qty Req
1
300 Front Axle PN: 9 - FRONT AXLE
Part Number
AM33887
Qty Req
1
Remarks
(MARKED M46260)
318 Front Axle PN: 24 - Front Axle
Part Number
AM39297
Qty Req
1
Remarks
SUB M85069 AND M83541
info_outline
This part has been substituted. View Details or add to cart to see substitute part information.
PA318Guy is offline
post #81 of 82 Old 06-23-2019, 02:36 PM Thread Starter
Parts collector
mopar65pa's Avatar
Well he did me right again. He gave me a complete rockershaft assembly and lift piston, and was going to give me an axle off a 330 but I made him take $60.
now to get them on.
1970 140 H1
1977 300 H2
198? 332 50" deck
post #82 of 82 Old 07-14-2019, 07:06 PM Thread Starter
Parts collector
mopar65pa's Avatar
ok the front axle is in, I had to swap the 332 front spindles into the 330 front axle and they well weren't in the best shape but the wheel bearings wer a different size and the steering spindle didn't have a long enough spline shaft for the power steering connection.
But it together and steering SO much better.
It was my bad the thing did have the rocker arm. I didn't know it was in the back so now I have an extra shaft and piston. Gonna try and use the piston for my 48" plow blade to make it angle.
I still can't figure out how the deck is supposed to lift. I'm not a dummy, the piston moves, but the arms don't and the lift rods are way off as far as I can see.
I'll have to research it and figure it out.
I fixed the wiring for the starter but as I was reaching to turn the key it snapped off at the head.
I put a new Kevlar PTO belt on it and sharpened the blades too. I just need to figure out how to get the lift rods in the right spot to lift the deck.
ID:	2386585   Click image for larger version
ID:	2386587   Click image for larger version
ID:	2386589   Click image for larger version
1970 140 H1
1977 300 H2
198? 332 50" deck
332 Smoke issues Orv1988332 John Deere Forum 45 06-27-2019 07:26 PM
Man vs stump (spoiler alert - man wins!) steddy Landscape and Yard Discussions 1 04-30-2018 11:30 PM
We might have an issue with the new 332. Deere 332 John Deere Forum 33 12-04-2017 06:35 PM
John Deere 332 To Buy or not Tony bachler John Deere Forum 3 11-24-2017 09:45 PM
318 vs 332 CT-JD318 John Deere Forum 34 12-15-2012 10:57 AM
