X Series Snowblower fitment - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 05-06-2019, 05:32 PM Thread Starter
Learning the hard way
kb4212's Avatar
I just purchased a X728 that came with a snow plow. I would like to also get a 2-stage snowblower. Ideally, I would buy another unit with the snowblower and re-sell w/o snowblower. What models cross over? Is there a different set up 4WD vs. 2WD?
Thanks.
2004 Simplicity Legacy XL 4x4 27HP Diesel with 48" deck, 60" 4-way snow/dirt plow, 46" 2-stage snow blower, 3-point, rear PTO, and FEL
1950 Ford 8n Sherman Step-up (in the family since new) and Dearborn 19-5 rear blade
https://www.youtube.com/user/W1WEASEL
kb4212 is offline
post #2 of 8 Old 05-06-2019, 08:02 PM
ggsteve's Avatar
Re: X Series Snowblower fitment
I believe every X from the X465 to the X758 can be outfitted with the Model 47 blower along with the 4X5 series. You are right, the 4 wheel drive models have a different set of drive shafts than the 2WD models do, the quick hitches are the same, but the hydraulic hoses are different on the 4X5 series.
ggsteve
80 Cart
78 JD 316K 49 blower
Woods box blade
ggsteve is offline
post #3 of 8 Old 05-06-2019, 08:52 PM
Thanks.
All Quick-Tatch Model M0147X and M047SBX will fit from 332, 4x5, X4, X5, X7
Above Model numbers must be on the serial tag. 2 Stage 47 blowers with black plastic chutes are not compatible.
Caveat being Quick Hitch/Tatch, driveshaft and upstop. Noted in this discussion link. Since you already have the Quick Hitch, only caveat is the snowblower driveshaft, PTO driveshaft doesn't matter.
https://www.mytractorforum.com/12-jo...aft-issue.html
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is online now
post #4 of 8 Old 05-06-2019, 08:59 PM
RT3360's Avatar
Model 47 or Model 54 I believe are the same attachment. Correct about 2wd -vs- 4wd. Shaft on a 2wd goes from the rear axle to in front of front axle with a mounting bracket. Shaft on a 4wd goes from the rear axle to the rear of front axle. There’s a stub shaft male-male through the front axle. The male shaft on either then allows for the female quick coupler from the blower drive shaft to mate to it. I too believe the quick hitches to be the same for the X7xx’s. I don’t have any experience with the 4X5 series.
Craftsman DLT2000, 48”
Ariens ST824 snowblower
RT3360 is offline
post #5 of 8 Old 05-06-2019, 09:31 PM
Jimbochap's Avatar
Thanks.
https://sheboygan.craigslist.org/grd...832751332.html
John Deere X495
54" Mower Deck
Front Hitch w/ 54" Snowblade
Buford Bucket
Click N'Go Bracket
Rear Weight Bar
6 Suit Case Weights
Cast Iron Rear Wheel Weights
JD 345 SOLD
JD GX325 SOLD
JD265 SOLD
JD 160SOLD
Jimbochap is offline
post #6 of 8 Old 05-06-2019, 10:28 PM
FTWingRiders's Avatar
I was just comparing my 2 54" blowers, one from my 455 and the other from my X748, I was wondering whether they would cross work without any changes. The stub shafts coming off the blowers look identical, except the 4x5 ones is 6' long, and the X's is 8"s. I assume at this point either would work on either tractor unless someone knows otherwise... ?
Forrest
X748 2011 with 45 loader, 3PH, remote valve, rear hydro, 54" mulching deck, custom hard cab and R4's
455 with 48' deck with PF and Hydraulic tilt dump, 26" HDAP's, front 18" HDAPs on 10" wheels
John Deere Cab
54" deck
54" blower with metal Impeller, chute rotation and flapper mod, 36T sprocket.
Laded 26" HDAPs for winter duty
54" blade with extensions.
51" rotary broom
3 quick hitches
Front mount dethatcher
Titan forks
SOLD:425, X585
FTWingRiders is offline
post #7 of 8 Old 05-06-2019, 11:19 PM
See my post above, link to discuss differences in driveshafts 4x5 vs X
JD 445 54 deck
JD 316, 46 deck
post #8 of 8 Old 05-07-2019, 04:44 PM Thread Starter
kb4212's Avatar
Thanks for all the good information!!!
kb4212 is offline
Single stage snowblower on a x700 series Dakotabobcat John Deere Forum 6 06-21-2018 07:30 AM
X500 series snowblower attachment size ? yzf125 John Deere Forum 4 04-26-2018 10:16 PM
John Deere D110 outfitted with L100 series 42" snowblower? ryeguy Lawn and Garden Tractor Accessories 2 04-25-2018 09:05 AM
Snowblower question for 400 Series Artpb Gravely 3 12-09-2012 04:49 PM
