Can my D140 pull this without breaking? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 16 Old 05-06-2019, 11:31 AM Thread Starter
Hi all,
I am going to aerate my lawn. I would much prefer to use a tow behind plug aerator instead of rending the push ones. I see many warnings about towing too much with these level machines, but also many people saying that it is fine. Some say the plugger is not 'ground engaging'. Not sure what to believe here.
So I am asking you lot of experienced fellows: Can my D140 pull this pluggable aerator?
Link to tool: https://robinrents.com/product/aerator-36-plugger/
Image attached also, not sure how it's going to show here though.
sdyarnell is offline
post #2 of 16 Old 05-06-2019, 12:54 PM
Red Cap Club
nick4030's Avatar
Re: Can my D140 pull this without breaking?
How big and how flat is your yard?
2007 John Deere X748
1991 John Deere 332
1973 John Deere 140 H3
1973 John Deere 110
1974 Case 646
1961 Cub Cadet Original
nick4030 is offline
post #3 of 16 Old 05-06-2019, 01:33 PM
That Guy
oefveteran's Avatar
You're looking at renting this? In that case I'm guessing you'll just be using it once and returning it?
If that's the case I don't see any harm.
I wouldn't drag it around on a weekly basis, however. 🤣
Cub Cadet XT3 GSX
John Deere 10P Yard Cart
oefveteran is offline
post #4 of 16 Old 05-06-2019, 02:19 PM Thread Starter
Attached. The back yard (second pic) is pretty flat. The front lawn has some slope for sure...
ID:	2375407   Click image for larger version
post #5 of 16 Old 05-06-2019, 05:10 PM
L120/G110 Hybridizer
ryanpf's Avatar
I pull a 30" plug aerator with 150# weight with my L120 with both the K46 and K66 hydro. No problems, still running at 585 hours on the meter. If those are 5 gal weight cans in the picture, you're looking at 240# max, so that might be a factor. Just fill them 3/4 full if you're worried.
I'll give you my standard reply: If you can pull it by hand across the lawn, it's okay to tow with the L/LA/D/E series.
HTH,
Paul
Massey GC1710 - A little red diesel with a loader in front, a backhoe in the rear and a big smile in the middle -
John Deere L120/K66 with Berco 30" tiller, John Deere 44" Snowblower, Johnny Products Sleeve Hitch and
JB Jr bucket. Plus Brinly-Hardy 10" plow, 7-Tine Cultivator, 40" Plug Aerator, 40" Dethatcher, E-I-E-I-O...
ryanpf is offline
post #6 of 16 Old 05-06-2019, 05:18 PM
20,000 Posts & Climbing
HTH,
Paul
What he said. ^^
TUDOR is offline
post #7 of 16 Old 05-07-2019, 12:25 PM Thread Starter
Thanks for the assistance everyone. Unfortunately, when I arrived the tow behind one was actually broken and needed a new weld, so I was jerked around by a self-propelled one for a while.
post #8 of 16 Old 05-07-2019, 01:11 PM
Wfburton159's Avatar
I will mention that there is no way that you are pulling a plug aerator weighted up by hand. It ends up being a decent load on the hydro. Also worth noting is that the self propelled unit probably did a much better job than the tow behind unit will/can do.
2003 John Deere X485
647 tiller
54c deck w/ mulch kit and power flow bagger
75# wheel weights and chains
John Deere 14SB
Wfburton159 is offline
post #9 of 16 Old 05-07-2019, 01:49 PM
I rented that exact aerator this spring, pulled it with my 116. Which is a gear drive lawn tractor. It pulled fine on flat areas, but quickly ran out of traction on slopes. I had to plan my plan of attack for the lawn so I was always going downhill on anything over a very mild slope.
The aerator did a much better job than the Brinley I used to own. It was well worth the $35 for a day rental.
TWG1572 is offline
post #10 of 16 Old 05-07-2019, 02:45 PM
Here is a picture of a 318 I used to have with my Brinley. I have basically zero slope in my yard. At a lower drain spot that is dirt when dry but slick when wet the 318 would not pull it past the mud point. Tires had mud on them from just running over the plugs and quickly lost traction. It isn't easy on the tractor.
647 tiller
John Deere 14SB
post #11 of 16 Old 05-16-2019, 01:45 PM
Midnightt's Avatar
I have a D140 and pull a Brinley with mine. I do not use that much weight. 2 cinder blocks and a few days after the rain. Pulls 2"= plugs and doesn't get muddy enough to cause issues. Yard is mostly flat with a slight slope on one side. I run length wise. Once I get moving I try not to stop. Usually do mine and my neighbors yard at the same time. I've done it 2x per year for 4 years.
Midnightt is offline
post #12 of 16 Old 05-16-2019, 01:48 PM
I pulled an aerator with 60lbs bags of concrete on it with my L111 5 or 6 times on my hill yard. Didn't seem to mind - although it definitely wasn't happy with that plus my 230lbs butt.
SycoCell is offline
post #13 of 16 Old 05-16-2019, 02:04 PM
JD X585 owner
gtunney's Avatar
Next time you get to aerating, I think you will be fine on your lot. I used to pull an Ohio Steel 42CP with my L118 with about 150 lbs on it and it was fine. Always made sure to do it on cooler days.
Sent from my SCH-I545 using Tapatalk
My toys
2002 JD X585
45 Loader, 47 Blower, 54C Deck, 14 Bushel bagger & Power Flow, 13 Steel Dump Cart, JD Front Mount Thatcher, 36" steel roller, Ohio Steel 42CP Aerator
2003 New Holland TC29D
Technically the TC29 is my Dad's and lives with him 6 miles from me. I own the backhoe unit since that's the 1/3rd I paid for as I insisted he would want/need it eventually.
Previous
2005 JD L118 Lawn Tractor (sold 21 Feb 2016)
gtunney is offline
post #14 of 16 Old 05-18-2019, 10:47 PM
I pull a similar size aerator with my X380, seems to do fine. I make sure to run at near full throttle and set the cruise control for a slow speed, this way it doesn't strain the transmission with varying speeds. If you're only doing this once or twice a year, and you go slow, you shouldn't have a problem, JD makes a snow plow for your machine, and that must put a similar strain on the transmission.
mllc413 is offline
post #15 of 16 Old 05-19-2019, 12:44 AM
Nor even close. Traction on dirt with a minimal ballast load is better than traction on snow, which is iffy even with a full ballast load and chains on an LT.
TUDOR is offline
Draw bar pull force eKretz Backyard Round Table - L & G Tractor Related Topics 8 04-25-2019 08:34 PM
Deer 68 - Pull String issus Moed321 Introductions 1 08-15-2018 09:19 PM
Western Pa. Garden Tractor Association Plow, Pull and Show Day May 4, 2013 wally_471 Tractor Shows, Events, Pulls and Racing... 3 12-01-2013 08:30 PM
GT pull in Ga. belt drive mafia The Pulling Club 0 03-03-2013 11:40 AM
