Engine Stalls on 180 when PTO engaged - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 05-05-2019, 08:02 AM Thread Starter
Craig01's Avatar
Help Engine Stalls on 180 when PTO engaged
John Deere 180 5 Speed
Engine runs great, until you turn the PTO on.
PTO clicks when the engine is off and ignition switch is the on position and PTO switch is tuned on.
Things I have tried so far.
1) Deck belt is disconnected
2) Power is getting to the PTO
3) Tried a different ignition switch from another working tractor
4) Tried a different PTO switch from another tractor
5) Disconnected the seat switch, nothing changed
6) Jumped the seat switch, nothing changed
7) Disconnected the transaxle switch, nothing changed
8) Jumped the transaxle switch, nothing changed
I am out of ideas. What am I missing or doing wrong?
Is there another switch somewhere?
Bad PTO?
Could I have a short somewhere?
This thing is driving me crazy.
Craig01 is offline
post #2 of 7 Old 05-05-2019, 08:39 AM
Re: Engine Stalls on 180 when PTO engaged
I don't know much about a 180, nothing actually, but I'm familiar with the pto's. Disconnect wire from pto, start tractor, and engage (disconnected) pto. If tractor continues to run, problem is coil windings partially shorted, or weak battery. Perhaps someone can post ohm value of your coil. If tractor stalls, possibly bad wiring from pto switch to pto...otherwise no ideas! Bob
rwmeyer is online now
post #3 of 7 Old 05-06-2019, 11:17 PM
no2498's Avatar
seat switch or bad battery
john
no2498 is offline
post #4 of 7 Old 05-07-2019, 08:25 AM
Firstly, is the engine stopping like you turned off the key or does it instantly lock up ?
If it's the first then you need to isolate the ignition system from the rest of the wiring harness. I think this mower has a Kawasaki motor and I think they have magic boxes instead of a simple coil/magneto. If it had a coil/magneto just disconnecting the kill wire would isolate the ign and you could then try to find the wiring issue.
If it has a battery powered ign you are going to have to figure out the wiring so that you can add a jumper wire to power the ign. Screwing up could fry the ign.
Good luck
rayjay is offline
post #5 of 7 Old 05-07-2019, 10:59 AM
JD-285's Avatar
180 is a mag.
285 "Wife's"
285 "The Ames"
165 "The 165" (Upgrade to FC420V from 170)
111H "Baby B."
445 “Braille”
X500
JD-285 is offline
post #6 of 7 Old 05-07-2019, 07:29 PM
B440's Avatar
What do you mean by "jumped the switch"? Modern safety switches are designed to be tamper proof. You could think you have it bypassed, but it is not.
B440 is offline
post #7 of 7 Old 05-07-2019, 09:12 PM
The Admin from... Nowhere
littletractorguy's Avatar
Load test your battery if you can... Engaging the PTO with the engine running puts a huge electrical load on your charging system. Having a weak battery will likely cause it to die like that...
littletractorguy is offline
STX 38 engine lightly seized... Did it overheat? tranks John Deere Forum 20 08-23-2018 09:33 PM
20G PTO Lever Suribachi Gravely 7 01-14-2018 07:07 PM
3184 PTO Won't Stay Engaged vortec Cub Cadet Forum 1 12-12-2017 10:40 PM
John Deere 318 - Engine stalls when throttle is increased at cold start a312 John Deere Forum 4 11-30-2017 09:20 AM
Need Electrical Help - New (to me) late 80's GT II 18hp B&S, no charging Sarge_ Craftsman/Sears Forum 89 04-19-2013 12:45 AM
