John Deere 445 Hydraulics question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 26 Old 05-01-2019, 12:58 PM Thread Starter
Profound Ag's Avatar
Excuse my ignorance all you guru's and experts I have a question you'll all probably think is a dumb question, but I'm going to ask anyway haha. I have a 3pt on my 445 and I very rarely take the 60" deck off. Is there a valve or something I need so I can control the 3pt separate from the deck hydraulics? Its not all that handy to have the deck to also be lowered when I use the 3pt blade to level the gravel driveway and other 3pt tasks. What do I need to install? I'm pretty mechanically inclined but have done almost 0 monkeying with this 445 beyond normal servicing.
There is no substitute for hard work- Thomas Edison
Profound Ag is offline
post #2 of 26 Old 05-01-2019, 01:08 PM
Re: John Deere 445 Hydraulics question
Mower height control, raise mower to lock. Number 7 to lock.
7. To lock mower in completely raised position:
Raise mower as high as it will go using the hydraulic control lever.
Crank height control clockwise until it is tight. Close crank.
Operating Mower Height Control
JD 455 3 pt rear pto 60 deck
JD 445 54 deck
JD 316, 46 deck
JD 425 parts tractor
Cockshutt 1465 parts tractor
pipsqueek is offline
post #3 of 26 Old 05-01-2019, 01:12 PM
I'll offer my 2 cents since I'm a dummy too!
Maybe this will help though. Growing up one tractor we had was a Farmall Cub with a belly mower. Grandad wanted to still use 3 point hitch and keep mower on at times, so he just put a chain on mower deck, raised it all the way and hooked it to an S hook hanging from tractor. Actually two small chains going either side of deck so it stayed up out of the way and balanced.
Very simple and it worked.
Sent from my Bell Rotary
Sevenhills1952 is offline
post #4 of 26 Old 05-01-2019, 01:14 PM
Likes Vintage JDs
UrbanTractor's Avatar
Depending what you are trying to achieve, a lock-out valve might be a nice upgrade:
4x5 by Aux Hydraulics
SOLD: 1966 JD 110 Round Fender Integral Sleeve Hitch, Model 42 Blade,
1972 JD 140 H3, 1972 Cozy Cab Model 14 JDX (2nd Ed.), Front-, Mid-, and Rear-PTOs, Model 54/48" 4-Way Blade, Model 48 MMM, 542 Front PTO, 3-Point-Hitch, Heavy-Hitch, a bunch of Model 80 Carts, MTF Dec. 2013 Machine of the Month
UrbanTractor is offline
post #5 of 26 Old 05-01-2019, 01:15 PM Thread Starter
Then I have to re adjust every time I mow? That sounds like a pain in the arse haha
post #6 of 26 Old 05-01-2019, 01:21 PM Thread Starter
That is more along the lines of what I'm after. I want the deck to stay up while I'm monkeying around with 3pt attachments (blade, hitch, sprayer, etc)
Old 05-01-2019, 02:26 PM
pipsqueek
This message has been deleted by pipsqueek. Reason: wrong link
Old 05-01-2019, 02:29 PM
pipsqueek
post #7 of 26 Old 05-01-2019, 03:31 PM
FTWingRiders's Avatar
The auxhyd.com is quality stuff. I used it on my 425.
Forrest
X748 2011 with 45 loader, 3PH, remote valve, rear hydro, 54" mulching deck, custom hard cab and R4's
455 with 48' deck with PF and Hydraulic tilt dump, 26" HDAP's, front 18" HDAPs on 10" wheels
John Deere Cab
54" deck
54" blower with metal Impeller, chute rotation and flapper mod, 36T sprocket.
Laded 26" HDAPs for winter duty
54" blade with extensions.
51" rotary broom
3 quick hitches
Front mount dethatcher
Titan forks
SOLD:425, X585
FTWingRiders is offline
post #8 of 26 Old 05-01-2019, 05:35 PM
Hummer.2012's Avatar
Shouldn't have to do any adusting, just make sure the deck is all the way up, turn the height adjustment back to your desired mowing height, lower the deck and mow. Takes anywhere from 15 to 30 seconds to complete the task and begin mowing.
Sent from my SM-G900R4 using Tapatalk
2014 - X758SE w/Block Heater, Rear PTO, 3-point, 54"HC Deck
2013 - Heavy Hitch w/sleeve hitch option, 647 Tiller
2013 - Ohio Steel core aerator, curtis cab w/heater
2012 - JD X748SE w/Block Heater, Bercomac 48" Snow Blower
2012 - 60" 7-Iron Mower ,3-point, Rear PTO, IMatch
Help support White Paws German Shepherd Rescue when you order from Amazon. Click here to find out how.
Video:
http://www.youtube.com/watch?v=y_3ss8GsSlo
Hummer.2012 is offline
post #9 of 26 Old 05-01-2019, 07:06 PM Thread Starter
It has been awhile since I monkeyed with the deck adjustment (something like 3 years) but I was thinking once you move that crank you would have to readjust the deck height all over again, not as easy as just putting on "setting 3" or anything. Now I gotta trudge through the mud to go look, maybe I'm thinking of an entirely different machine
post #10 of 26 Old 05-01-2019, 07:14 PM
I am not sure that the lockout valve is what you want, as the deck cylinder is typically what operates the 3PH, so you need it to be working.
The lockout valve is for when you have external hoses plugged into system (such as a loader, blower, etc), which puts 2 cylinders in parallel.
tractorPete is offline
post #11 of 26 Old 05-01-2019, 07:34 PM
mowergene's Avatar
When you turn the crank upward to hold the deck up, count the number of turns it took. WRITE THIS NUMBER DOWN! Now you know exactly where to take it.
In the past:
In use:
mowergene is offline
post #12 of 26 Old 05-01-2019, 07:51 PM
burned300's Avatar
the old deere's like the 110's 210's 318's 420's had no "setting" you just set the depth control to where ever.
1970 112
1975 200
Gannon Earthgavator graderbox
#40 EZ Rake Vac
#40 EZ Rake Vac
#70 EZ Rake Vac
1977 MTD 990 Parts Tractor
Ohio Steel yard cart
Brinly cat 0 plow
John Deere cat 1 plow
Innovative brand, Grapple
burned300 is online now
post #13 of 26 Old 05-01-2019, 07:51 PM Thread Starter
Write it down but then you expect me to remember where I wrote it down?
post #14 of 26 Old 05-01-2019, 07:53 PM Thread Starter
Ahhhh. I bet I'm thinking of the 317 the 445 replaced! That and growing up running a 317 and later a 318 for Dad nearly every day all summer long.
post #15 of 26 Old 05-01-2019, 07:56 PM
Likes Vintage JDs
You make a good point. I keep forgetting that my 140 has dedicated separate cylinders for the 3PH and rockshaft deck lift, which is unusual. You get extra stuff like that with 3 spools of hydraulics!
John Deere LA120 Combined with Johnny Bucket Jr. Question Mightyanchove Electric & Alternative Powered Machinery 4 04-23-2019 06:58 PM
Parting 2001 John Deere 445 (Long Island) Lkosl46305 For Sale & Wanted to Buy (Your Location) 2 07-01-2018 05:56 PM
John deere 400 power question graystang88 John Deere Forum 4 06-24-2018 09:31 PM
John Deere 420 good buy? Lucas in Alaska John Deere Forum 36 02-14-2013 10:47 AM
john deere 445 spark plugs Lexmark500ho John Deere Forum 1 11-30-2012 05:52 PM
